OEM module question...
I have 4 OEM module kits, and I have two left to solder (the completed ones work great by the way, I highly recommend the OEM's [noparse];)[/noparse] ) and I was wondering if it would be safe to use the ColdHeat soldering "tool" for this (coldheat.com/) I raise this question because when using the coldheat on other projects, the tool produces a spark sometimes when you first touch the tool to the component/solder pad. I do not think this is a static spark, but that is not the only problem. I also notice that the tools tip temperature goes from 45oF to 900oF in less than 1 second. This seems a bit scary when your soldering the resonator/power supply/transistors onto the board. Anyway, if anyone has a thought on this, I'd love to hear it!
Thank you,
Justin
Thank you,
Justin
Terry
Hope my review helped [noparse];)[/noparse]
-justin
I have a 25 Watt Iron, and a 40 Watt Iron...I use each where applicable, and I tend to use Silver Solder on the more important connections.· I also have a Soldapult Solder Sucker, and only use braid if absolutely necessary.
Oh, and so my post isn't entirely off topic, I too am a fan of the OEM Modules over the standard modules, however I know they aren't for everyone.· My main thing is they easily go into projects without have to add anything for a regulator or programming hardware.· I usually mount the DB9 to the side of the case, and inside the SIP header connects to the rest of the circuitry.· And I can always count on Parallax to have them on Sale when I am getting low on them.
Chris Savage
Knight Designs
324 West Main Street
P.O. Box 97
Montour Falls, NY 14865
(607) 535-6777
Business Page:·· http://www.knightdesigns.com
Personal Page:··· http://www.lightlink.com/dream/chris
Designs Page:··· http://www.lightlink.com/dream/designs
