Is there any common IC chip that can be used as buffer?
Am wondering if there is any IC chip that I can use as a buffer. Not
having a buffer is a real pain in the tuckus for my project. Any
comment would be greatly appreciated.
Eric
Eric
the Stamp - I really don't know why they wouldn't work with the Stamp and I
will probably try one or both at some point.
Original Message
From: Eric Berg [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=MIflFwzkqutwP0GtNXaO0wylKi5Qi1fiokYTBSm0mnB3T5lL1eKF9Ejv4nlOD124Q72NdUMdBms]khufumen@y...[/url
Sent: Monday, July 19, 2004 5:25 PM
To: basicstamps@yahoogroups.com
Subject: [noparse][[/noparse]basicstamps] Is there any common IC chip that can be used as
buffer?
Eric
To UNSUBSCRIBE, just send mail to:
basicstamps-unsubscribe@yahoogroups.com
from the same email address that you subscribed. Text in the Subject and
Yahoo! Groups Links
the spelling?
Eric
--- In basicstamps@yahoogroups.com, "BH" <okay_2@c...> wrote:
> For a buffer, I have used the 74LC244 & 74LC245 for projects not
involving
Stamp and I
Original Message
> From: Eric Berg [noparse][[/noparse]mailto:khufumen@y...]
used as
> buffer?
Not
> Eric
Subject and
> Yahoo! Groups Links
moment), sorry.
Original Message
From: Eric Berg [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=NxQyBWejbctrMofV3lgpoakJrELk403OBVkICoYkfZoaKmMiM18MuvHexGO4X-Bhc1ySRSpnlOIq8A]khufumen@y...[/url
Sent: Monday, July 19, 2004 5:40 PM
Subject: [noparse][[/noparse]basicstamps] Re: Is there any common IC chip that can be used
as buffer?
Can't find those chips at Newark or Digikey. Are you certain about
the spelling?
Eric
involving
Stamp and I
Original Message
used as
> buffer?
Not
> Eric
Subject and
> Yahoo! Groups Links
Yahoo! Groups Links
of bytes of data coming in over the serial port.
Eric
--- BH <okay_2@c...> wrote:
> Whoops!!! What I meant was 74LS244 or 74LS245,
> (must have had a senior
> moment), sorry.
Original Message
> From: Eric Berg [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=6VJ-RkqDXbwHrelbiUiKjcHmS-IQz8SYp_pU3iYkxcR4h33Ypeo2Q1TUDJXIWX8xxsuuov0b674N6ieg]khufumen@y...[/url
> as buffer?
> certain about
> the spelling?
> Eric
> for projects not
> involving
> work with the
> Stamp and I
Original Message
> that can be
> used as
> > buffer?
> use as a buffer.
> Not
> my project. Any
> > Eric
> Text in the
> Subject and
> > Yahoo! Groups Links
> Yahoo! Groups Links
> Text in the Subject and Body of the message will be
> ignored.
> Yahoo! Groups Links
I am not sure what you are referring to as far as a buffer. Do you mean a
Serial Buffer ?? or are you referring to some chip to drive an output and
isolate it from the stamp? If you are referring to a Serial Buffer there
is a great one made by S Parks and all the info for it's construction is in
the files section of this site. This ia a 1K PIC based serial buffer that
is really neat and works great.
Another Eric
Original Message
To: <basicstamps@yahoogroups.com>
Sent: Monday, July 19, 2004 8:25 PM
buffer?
> Eric
> Yahoo! Groups Links
Yes, I'm looking for a serial buffer. I looked under the files
section and saw a text file for a serial buffer saying to refer to
Peter H. Anderson's web site for purchasing. When I went to the web
site I did not find the pic in question. Any help you can offer?
Eric
--- In basicstamps@yahoogroups.com, "Eric Adams" <hugs102@b...>
wrote:
> Hi Eric:
you mean a
output and
Buffer there
construction is in
buffer that
> Another Eric
Original Message
> From: "Eric Berg" <khufumen@y...>
used as
> buffer?
Not
> > Eric
Subject and
> > Yahoo! Groups Links
>For a buffer, I have used the 74LC244 & 74LC245 for projects not involving
I'm guessing that you mean "HC" or "LS" rather than "LC" in the above part
numbers. Of the two, the HC parts are better for just about all
situations. Much lower current consumption and about double the output
drive capability than the "LS" parts.
dwayne
Dwayne Reid <dwayner@p...>
Trinity Electronics Systems Ltd Edmonton, AB, CANADA
(780) 489-3199 voice (780) 487-6397 fax
Celebrating 20 years of Engineering Innovation (1984 - 2004)
Do NOT send unsolicited commercial email to this email address.
This message neither grants consent to receive unsolicited
commercial email nor is intended to solicit commercial email.
good to hear about the "HC" line. I have seen the "HC" part numbers but I
guess I was just stuck in a rut. I appreciate your input...
Original Message
From: Dwayne Reid [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=YS8Fy71hMUkKeKE-xmzuSQZemJXVCpPK5674BFXojugDED8HaD4hfUv2Ec-SHQHQbG-evLd2Bn9qQzbrPNM]dwayner@p...[/url
Sent: Monday, July 19, 2004 7:49 PM
Subject: RE: [noparse][[/noparse]basicstamps] Is there any common IC chip that can be used
as buffer?
dwayne
Yahoo! Groups Links
some time last year. Check further if you cannot find it then let me know
it is really neat. Steve is a regular on this site and always has some great
info.
Eric A
Original Message
Sent: Monday, July 19, 2004 10:06 PM
Subject: [noparse][[/noparse]basicstamps] Re: Is there any common IC chip that can be used as
buffer?
> Eric,
> Eric
> wrote:
> > Hi Eric:
> you mean a
> output and
> Buffer there
> construction is in
> buffer that
> > Another Eric
Original Message
> used as
> > buffer?
> Not
> > > Eric
> Subject and
> > > Yahoo! Groups Links
> Yahoo! Groups Links
Original Message
Sent: Monday, July 19, 2004 11:26 PM
Subject: Re: [noparse][[/noparse]basicstamps] Re: Is there any common IC chip that can be used
as buffer?
> The serial buffer was designed by S Parkis and was put in the file system
great
> info.
> Eric A
Original Message
> buffer?
> > Eric,
> > Eric
> > wrote:
> > > Hi Eric:
> > you mean a
> > output and
> > Buffer there
> > construction is in
> > buffer that
> > > Another Eric
Original Message
> > used as
> > > buffer?
> > Not
> > > > Eric
> > Subject and
> > > > Yahoo! Groups Links
and
> > Yahoo! Groups Links
> Yahoo! Groups Links
There is also the MAX3100, which is a UART and 8 byte fifo buffer
that connects to the Stamp via SERIN/SEROUT. App note and links at
this URL: <http://www.emesystems.com/BS2IrDA.htm>. The URL
emphasizes the IrDA capability of the chip, but it is just as capable
of straight RS232.
Al Williams
AWC
* New Kits: http://www.awce.com/kits.htm
Original Message
From: Tracy Allen [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=RxM36yoY0tFwp0YQToaZIMOx18Z9NqSU7b9ZIzm6waPlKvbndhDhLulBeLyrx3AbG0IQrrpVS8NpcLn7]tracy@e...[/url
Sent: Tuesday, July 20, 2004 9:28 AM
buffer?
>Eric,
There is also the MAX3100, which is a UART and 8 byte fifo buffer that
connects to the Stamp via SERIN/SEROUT. App note and links at this URL:
<http://www.emesystems.com/BS2IrDA.htm>. The URL emphasizes the IrDA
capability of the chip, but it is just as capable of straight RS232.
Yahoo! Groups Links
http://www.protean-logic.com/tickit/rsb509CX_HTML_Cutsheet.htm
Not sure if it is still available.
regards peter
Original Message
Sent: Tuesday, July 20, 2004 4:27 PM
buffer?
> >Eric,
> of straight RS232.
> Yahoo! Groups Links
http://www.proteanlogic.com/product_periph_rs232.shtml
regards peter
Original Message
Sent: Tuesday, July 20, 2004 5:55 PM
Subject: **SPAM: Re: [noparse][[/noparse]basicstamps] Re: Is there any common IC chip that can
be used as buffer?
> Here is a 32 byte serial buffer chip.
> regards peter
maxim chip. I talked to the owner of protean-logic and
the rs232 serial buffer chips are still in the beta
stage.
Eric
> regards peter
Original Message
> From: "Tracy Allen" <tracy@e...>
> buffer?
> > >Eric,
> byte fifo buffer
> note and links at
> > this URL:
> is just as capable
> > of straight RS232.
> > Yahoo! Groups Links
> ignored.
> Yahoo! Groups Links
