Fwd: URGENT, anyone from parallex reply?
¶}©lÂà±H¶l¥ó¡G
> ±H¥ó¤H: Annie Wan <o_wan@y...>
> ¤é´Á: 2004¦~06¤ë10¤é ¤U¤È07®É42¤À37¬í
> ¦¬¥ó¤H: basicstamps@yahoogroups.com
> ¼ÐÃD: Re: [noparse][[/noparse]basicstamps] eb500
> ¦^Âе¹: basicstamps@yahoogroups.com
> it doesn't blink but my BT dongle detect eb500 with the device name
> eb500, I tried to switch from command mode to data mode but it fails,
> I believe that there's some problem but not totally dead, can anyone
> from parallex reply this email?
> Can I get a new one, I've just brought it and shipped to me this week
> and I definitely need to use it ASAP.
> Annie
> ©ó 2004¦~6¤ë9¤é ¤U¤È10:30 ®É¡AJonathan Peakall ´£¨ì¡G
>> Slim,
>> Does the EB500 status LED blink when you power on the unit? If not, it
>> might
>> be dead. If it does, post the code you are trying to use.
>> Jonathan
>> www.madlabs.info
Original Message
>> From: "Annie Wan" <o_wan@y...>
>> To: <basicstamps@yahoogroups.com>
>> Sent: Wednesday, June 09, 2004 1:07 PM
>> Subject: Re: [noparse][[/noparse]basicstamps] eb500
>>> hi,
>>> yup exactly, I think hooking up BS and eb500 is the 1st step, I'm
>>> still
>>> in there, not even talking with the bt USB dongle
>>> I've done what you've told me but even the USB bt can't detect
>>> another
>>> bt exist and there's no light flashing or being lit in the eb500.
>>>>>>>> eb500 PIN 1 to BS2 GND
>>>>>>>> eb500 PIN 3 to BS2 Rx
>>>>>>>> eb500 PIN 4 to BS2 Tx
>>>>>>>> eb500 PIN 20 to BS2 VSS
>>> ©ó 2004¦~6¤ë9¤é ¤U¤È9:35 ®É¡AJonathan Peakall ´£¨ì¡G
>>>> Slim,
>>>> OK, I have done exactly waht you want to do, so I know it can be
>>>> done.
>>>> I
>>>> have a Stamp and EB500 hooked up on my desk right now. If I
>>>> understand
>>>> you
>>>> correctly, you are having trouble getting the EB500 and the Stamp to
>>>> work
>>>> together.
>>>> Did you try all the things I listed in the first message? When you
>>>> send a
>>>> command to the EB500, do you get and ACK or NCK?
>>>> Post the code you are using. It sounds like the problem is there.
>>>> Jonathan
>>>> www.madlabs.info
Original Message
>>>> Sent: Wednesday, June 09, 2004 9:12 AM
>>>>> I want to attach the eb500 to BS and then using a bluetooth USB
>>>>> dongle
>>>>> in PC, I suppose the eb500 act ac a serial module replacement, am I
>>>>> buying the right stuff?
>>>>> ©ó 2004¦~6¤ë9¤é ¤U¤È4:10 ®É¡AJonathan Peakall ´£¨ì¡G
>>>>>> Slim,
>>>>>> I'm not quite sure what you are trying to do. Is it:
>>>>>> BS2+EB500
EB500+PC
>>>>>> Are you saying you can't get two EB500s to talk to each other? Or
>>>>>> are
>>>>>> you
>>>>>> saying that you can't get the BS2 to talk to an EB500?
>>>>>> Jonathan
Original Message
>>>>>> Sent: Tuesday, June 08, 2004 11:16 AM
>>>>>>> hi,
>>>>>>> I did that already but still there's no response, BTW, do I need
>>>>>>> to
>>>>>>> connect the eb500 to a serial port first and config it, then
>>>>>>> connect
>>>>>>> the eb500 to BS?
>>>>>>> or just connect eb500 to BS directly? how can I configure it
>>>>>>> then?
>>>>>>> ©ó 2004¦~6¤ë7¤é ¤U¤È8:54 ®É¡AJonathan Peakall ´£¨ì¡G
>>>>>>>> Slim,
>>>>>>>> Looks like you have the TX/RX backwards. Have you tried
>>>>>>>> reversing
>>>>>>>> them? The
>>>>>>>> Stamp should SEROUT to pin 4 of the EB500, and SERIN on pin 3.
>>>>>>>> If
>>>>>>>> that
>>>>>>>> doesn't work, have you:
>>>>>>>> Checked the baud rate.
>>>>>>>> Reset to default baud rate.
>>>>>>>> Made sure the code is using the correct pins.
>>>>>>>> Removed all checks on the Connection Status pin since you are
>>>>>>>> not
>>>>>>>> using it.
>>>>>>>> Looked with a 'scope to see if you are getting anything.
>>>>>>>> Removed any SERIN statements that wait for the ACK.
>>>>>>>> HTH,
>>>>>>>> Jonathan
>>>>>>>> www.madlabs.info
Original Message
>>>>>>>> Sent: Monday, June 07, 2004 9:53 AM
>>>>>>>> Subject: [noparse][[/noparse]basicstamps] eb500
>>>>>>>>> hi,
>>>>>>>>> did anyone try to connect eb500 directly to BS2 without any
>>>>>>>>> parallex
>>>>>>>>> boards? I've tried to connect
>>>>>>>>> eb500 PIN 3 to BS2 TX
>>>>>>>>> eb500 PIN 4 to BS2 RX
>>>>>>>>> But it seems not working, not light at all, any clues?
>>>>>>>>> slimboyfatboyslim
>>>>>>>>> http://www.slimboyfatboyslim.org
>>>>>>>>> To UNSUBSCRIBE, just send mail to:
>>>>>>>>> basicstamps-unsubscribe@yahoogroups.com
>>>>>>>>> from the same email address that you subscribed. Text in the
>>>>>>>>> Subject
>>>>>>>>> and
>>>>>>>> Body of the message will be ignored.
>>>>>>>>> Yahoo! Groups Links
>>>>>>>> Subject
>>>>>>>> and Body of the message will be ignored.
>>>>>>>> Yahoo! Groups Links
>>>>>>> slimboyfatboyslim
>>>>>>> [noparse][[/noparse]Non-text portions of this message have been removed]
>>>>>>> Subject
>>>>>>> and
>>>>>>> Yahoo! Groups Links
>>>>>> Subject
>>>>>> Yahoo! Groups Links
>>>>> slimboyfatboyslim
>>>>> Subject
>>>>> and
>>>>> Yahoo! Groups Links
>>>> Subject
>>>> Yahoo! Groups Links
>>> slimboyfatboyslim
>>> from the same email address that you subscribed. Text in the Subject
>>> and
>>> Yahoo! Groups Links
>> Yahoo! Groups Links
> slimboyfatboyslim
> Yahoo! Groups Links
slimboyfatboyslim
> Annie
>> Slim,
>> might
>> Jonathan
>> www.madlabs.info
Original Message
>>> hi,
>>> still
>>> another
>>>> Slim,
>>>> done.
>>>> I
>>>> understand
>>>> you
>>>> work
>>>> together.
>>>> send a
>>>> Jonathan
>>>> www.madlabs.info
Original Message
>>>>> dongle
>>>>>> Slim,
>>>>>> BS2+EB500
EB500+PC
>>>>>> are
>>>>>> you
>>>>>> Jonathan
Original Message
>>>>>>> hi,
>>>>>>> to
>>>>>>> connect
>>>>>>> the eb500 to BS?
>>>>>>> then?
>>>>>>>> Slim,
>>>>>>>> reversing
>>>>>>>> them? The
>>>>>>>> If
>>>>>>>> that
>>>>>>>> not
>>>>>>>> using it.
>>>>>>>> HTH,
>>>>>>>> Jonathan
>>>>>>>> www.madlabs.info
Original Message
>>>>>>>>> hi,
>>>>>>>>> parallex
>>>>>>>>> slimboyfatboyslim
>>>>>>>>> Subject
>>>>>>>>> and
>>>>>>>>> Yahoo! Groups Links
>>>>>>>> Subject
>>>>>>>> Yahoo! Groups Links
>>>>>>> slimboyfatboyslim
>>>>>>> Subject
>>>>>>> and
>>>>>>> Yahoo! Groups Links
>>>>>> Subject
>>>>>> Yahoo! Groups Links
>>>>> slimboyfatboyslim
>>>>> Subject
>>>>> and
>>>>> Yahoo! Groups Links
>>>> Subject
>>>> Yahoo! Groups Links
>>> slimboyfatboyslim
>>> and
>>> Yahoo! Groups Links
>> Yahoo! Groups Links
> slimboyfatboyslim
> Yahoo! Groups Links
slimboyfatboyslim
If the dongle is detecting the unit, it may be OK. What happens when you
try to load some code into the Stamp to try to use the EB500?
Jonathan
www.madlabs.info
Original Message
Sent: Friday, June 11, 2004 8:04 AM
Subject: [noparse][[/noparse]basicstamps] Fwd: URGENT, anyone from parallex reply?
> ¶}©lÂà±H¶l¥ó¡G
> > Annie
> >> Slim,
> >> might
> >> Jonathan
> >> www.madlabs.info
Original Message
> >>> hi,
> >>> still
> >>> another
> >>>> Slim,
> >>>> done.
> >>>> I
> >>>> understand
> >>>> you
> >>>> work
> >>>> together.
> >>>> send a
> >>>> Jonathan
> >>>> www.madlabs.info
Original Message
> >>>>> dongle
> >>>>>> Slim,
> >>>>>> BS2+EB500
EB500+PC
> >>>>>> are
> >>>>>> you
> >>>>>> Jonathan
Original Message
> >>>>>>> hi,
> >>>>>>> to
> >>>>>>> connect
> >>>>>>> the eb500 to BS?
> >>>>>>> then?
> >>>>>>>> Slim,
> >>>>>>>> reversing
> >>>>>>>> them? The
> >>>>>>>> If
> >>>>>>>> that
> >>>>>>>> not
> >>>>>>>> using it.
> >>>>>>>> HTH,
> >>>>>>>> Jonathan
> >>>>>>>> www.madlabs.info
Original Message
> >>>>>>>>> hi,
> >>>>>>>>> parallex
> >>>>>>>>> slimboyfatboyslim
> >>>>>>>>> Subject
> >>>>>>>>> and
> >>>>>>>>> Yahoo! Groups Links
> >>>>>>>> Subject
> >>>>>>>> Yahoo! Groups Links
> >>>>>>> slimboyfatboyslim
> >>>>>>> Subject
> >>>>>>> and
> >>>>>>> Yahoo! Groups Links
> >>>>>> Subject
> >>>>>> Yahoo! Groups Links
> >>>>> slimboyfatboyslim
> >>>>> Subject
> >>>>> and
> >>>>> Yahoo! Groups Links
> >>>> Subject
> >>>> Yahoo! Groups Links
> >>> slimboyfatboyslim
> >>> and
> >>> Yahoo! Groups Links
> >> Yahoo! Groups Links
> > slimboyfatboyslim
> > Yahoo! Groups Links
> slimboyfatboyslim
> from the same email address that you subscribed. Text in the Subject and
> Yahoo! Groups Links
product, parallex people, please reply.
©ó 2004¦~6¤ë11¤é ¤U¤È6:42 ®É¡AJonathan Peakall ´£¨ì¡G
> Annie,
> you
> Jonathan
> www.madlabs.info
Original Message
>> ¶}©lÂà±H¶l¥ó¡G
>>> Annie
>>>> Slim,
>>>> it
>>>> might
>>>> Jonathan
>>>> www.madlabs.info
Original Message
>>>>> hi,
>>>>> still
>>>>> another
>>>>>> Slim,
>>>>>> done.
>>>>>> I
>>>>>> understand
>>>>>> you
>>>>>> to
>>>>>> work
>>>>>> together.
>>>>>> send a
>>>>>> Jonathan
>>>>>> www.madlabs.info
Original Message
>>>>>>> dongle
>>>>>>> am I
>>>>>>>> Slim,
>>>>>>>> BS2+EB500
EB500+PC
>>>>>>>> Or
>>>>>>>> are
>>>>>>>> you
>>>>>>>> Jonathan
Original Message
>>>>>>>>> hi,
>>>>>>>>> need
>>>>>>>>> to
>>>>>>>>> connect
>>>>>>>>> the eb500 to BS?
>>>>>>>>> then?
>>>>>>>>>> Slim,
>>>>>>>>>> reversing
>>>>>>>>>> them? The
>>>>>>>>>> If
>>>>>>>>>> that
>>>>>>>>>> not
>>>>>>>>>> using it.
>>>>>>>>>> HTH,
>>>>>>>>>> Jonathan
>>>>>>>>>> www.madlabs.info
Original Message
>>>>>>>>>>> hi,
>>>>>>>>>>> parallex
>>>>>>>>>>> slimboyfatboyslim
>>>>>>>>>>> Subject
>>>>>>>>>>> and
>>>>>>>>>>> Yahoo! Groups Links
>>>>>>>>>> Subject
>>>>>>>>>> Yahoo! Groups Links
>>>>>>>>> slimboyfatboyslim
>>>>>>>>> Subject
>>>>>>>>> and
>>>>>>>>> Yahoo! Groups Links
>>>>>>>> Subject
>>>>>>>> Yahoo! Groups Links
>>>>>>> slimboyfatboyslim
>>>>>>> Subject
>>>>>>> and
>>>>>>> Yahoo! Groups Links
>>>>>> Subject
>>>>>> Yahoo! Groups Links
>>>>> slimboyfatboyslim
>>>>> Subject
>>>>> and
>>>>> Yahoo! Groups Links
>>>> Subject
>>>> Yahoo! Groups Links
>>> slimboyfatboyslim
>>> Yahoo! Groups Links
>> slimboyfatboyslim
>> and
>> Yahoo! Groups Links
> Yahoo! Groups Links
slimboyfatboyslim
-- Jon Williams
-- Applications Engineer, Parallax
-- Dallas Office
Original Message
From: Annie Wan [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=8m0_fWXZZQjG3gRZUURYmf6cHb6IfZ_dZ2HQNkg8VfzukrPlTzOXUXCxEvLVzxJtiRlrPh7qss8bEA]o_wan@y...[/url
Sent: Friday, June 11, 2004 10:05 AM
To: basicstamps@yahoogroups.com
³«»ÏíÛ´ó͹·ï¡§
> ´ó·ï¿Í: Annie Wan <o_wan@y...>
> Æü´ü: 2004ǯ06·î10Æü ²¼¸á07»þ42ʬ37ÉÃ
> ÚÀ·ï¿Í: basicstamps@yahoogroups.com
> ɸÂê: Re: [noparse][[/noparse]basicstamps] eb500
> ²óʤµë: basicstamps@yahoogroups.com
> from parallex reply this email? Can I get a new one, I've just brought
> it and shipped to me this week and I definitely need to use it ASAP.
> Annie
> ±÷ 2004ǯ6·î9Æü ²¼¸á10:30 »þ¡¤Jonathan Peakall ÄóÅþ¡§
>> Slim,
>> it might be dead. If it does, post the code you are trying to use.
>> Jonathan
>> www.madlabs.info
Original Message
>>> hi,
>>> still in there, not even talking with the bt USB dongle
>>> another
>>> ±÷ 2004ǯ6·î9Æü ²¼¸á9:35 »þ¡¤Jonathan Peakall ÄóÅþ¡§
>>>> Slim,
>>>> done. I
>>>> understand
>>>> you
>>>> work
>>>> together.
>>>> send a command to the EB500, do you get and ACK or NCK?
>>>> Jonathan
>>>> www.madlabs.info
Original Message
>>>>> dongle in PC, I suppose the eb500 act ac a serial module
>>>>> replacement, am I buying the right stuff?
>>>>> ±÷ 2004ǯ6·î9Æü ²¼¸á4:10 »þ¡¤Jonathan Peakall ÄóÅþ¡§
>>>>>> Slim,
>>>>>> BS2+EB500
EB500+PC
>>>>>> are you
>>>>>> Jonathan
Original Message
>>>>>>> hi,
>>>>>>> to connect the eb500 to a serial port first and config it, then
>>>>>>> connect
>>>>>>> the eb500 to BS?
>>>>>>> then?
>>>>>>> ±÷ 2004ǯ6·î7Æü ²¼¸á8:54 »þ¡¤Jonathan Peakall ÄóÅþ¡§
>>>>>>>> Slim,
>>>>>>>> reversing
>>>>>>>> them? The
>>>>>>>> If
>>>>>>>> that
>>>>>>>> not
>>>>>>>> using it.
>>>>>>>> HTH,
>>>>>>>> Jonathan
>>>>>>>> www.madlabs.info
Original Message
>>>>>>>>> hi,
>>>>>>>>> parallex boards? I've tried to connect
>>>>>>>>> slimboyfatboyslim
>>>>>>>>> Subject and
>>>>>>>>> Yahoo! Groups Links
>>>>>>>> Subject and Body of the message will be ignored.
>>>>>>>> Yahoo! Groups Links
>>>>>>> slimboyfatboyslim
>>>>>>> Subject and
>>>>>>> Yahoo! Groups Links
>>>>>> Yahoo! Groups Links
>>>>> slimboyfatboyslim
>>>>> Subject and
>>>>> Yahoo! Groups Links
>>>> Subject
>>>> Yahoo! Groups Links
>>> slimboyfatboyslim
>>> Subject and
>>> Yahoo! Groups Links
>> Yahoo! Groups Links
> slimboyfatboyslim
> Yahoo! Groups Links
slimboyfatboyslim
from the same email address that you subscribed. Text in the Subject and Body of the message will be ignored.
Yahoo! Groups Links
This message has been scanned by WebShield. Please report SPAM to abuse@p....
Please contact our customer service department at 888 512-1024 or sales@p... and one of our representatives will assist you.
For any other similar inquiries, please contact us directly so we can assist you as soon as possible. It would be unfortunate if we missed your posting and were unable to react quickly. In this case, our office was closed all day on Friday.
Erik Wood
Get started with the BASIC Stamp(r) microcontroller!
Parallax Summer Special is only $79
Visit www.parallax.com for details
Original Message
From: Annie Wan [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=tfSYvE-watfQXTpOR4stVBkXsrw37eCeYAPHp6oR0lIW7z2Gl47fpCHfiz7wXmhAK2lGdsvclKO7geXs]o_wan@y...[/url
Sent: Friday, June 11, 2004 9:50 AM
Subject: Re: [noparse][[/noparse]basicstamps] Fwd: URGENT, anyone from parallex reply?
but it's not perfect, isn't it? they suppose to send me a perfect
±÷ 2004ǯ6·î11Æü ²¼¸á6:42 »þ¡¤Jonathan Peakall ÄóÅþ¡§
> Annie,
> you
> Jonathan
> www.madlabs.info
Original Message
>> ³«»ÏíÛ´ó͹·ï¡§
>>> Annie
>>>> Slim,
>>>> it
>>>> might
>>>> Jonathan
>>>> www.madlabs.info
Original Message
>>>>> hi,
>>>>> still
>>>>> another
>>>>>> Slim,
>>>>>> done.
>>>>>> I
>>>>>> understand
>>>>>> you
>>>>>> to
>>>>>> work
>>>>>> together.
>>>>>> send a
>>>>>> Jonathan
>>>>>> www.madlabs.info
Original Message
>>>>>>> dongle
>>>>>>> am I
>>>>>>>> Slim,
>>>>>>>> BS2+EB500
EB500+PC
>>>>>>>> Or
>>>>>>>> are
>>>>>>>> you
>>>>>>>> Jonathan
Original Message
>>>>>>>>> hi,
>>>>>>>>> need
>>>>>>>>> to
>>>>>>>>> connect
>>>>>>>>> the eb500 to BS?
>>>>>>>>> then?
>>>>>>>>>> Slim,
>>>>>>>>>> reversing
>>>>>>>>>> them? The
>>>>>>>>>> If
>>>>>>>>>> that
>>>>>>>>>> not
>>>>>>>>>> using it.
>>>>>>>>>> HTH,
>>>>>>>>>> Jonathan
>>>>>>>>>> www.madlabs.info
Original Message
>>>>>>>>>>> hi,
>>>>>>>>>>> parallex
>>>>>>>>>>> slimboyfatboyslim
>>>>>>>>>>> Subject
>>>>>>>>>>> and
>>>>>>>>>>> Yahoo! Groups Links
>>>>>>>>>> Subject
>>>>>>>>>> Yahoo! Groups Links
>>>>>>>>> slimboyfatboyslim
>>>>>>>>> Subject
>>>>>>>>> and
>>>>>>>>> Yahoo! Groups Links
>>>>>>>> Subject
>>>>>>>> Yahoo! Groups Links
>>>>>>> slimboyfatboyslim
>>>>>>> Subject
>>>>>>> and
>>>>>>> Yahoo! Groups Links
>>>>>> Subject
>>>>>> Yahoo! Groups Links
>>>>> slimboyfatboyslim
>>>>> Subject
>>>>> and
>>>>> Yahoo! Groups Links
>>>> Subject
>>>> Yahoo! Groups Links
>>> slimboyfatboyslim
>>> Yahoo! Groups Links
>> slimboyfatboyslim
>> and
>> Yahoo! Groups Links
> Yahoo! Groups Links
slimboyfatboyslim
Yahoo! Groups Links
