Fwd: URGENT, anyone from parallex reply? — Parallax Forums
edited 2004-06-14 16:06 in General Discussion
¶}©lÂà±H¶l¥ó¡G
> ±H¥ó¤H: Annie Wan <o_wan@y...>
> ¤é´Á: 2004¦~06¤ë10¤é ¤U¤È07®É42¤À37¬í
> ¦¬¥ó¤H: basicstamps@yahoogroups.com
> ¼ÐÃD: Re: [noparse][[/noparse]basicstamps] eb500
> ¦^Âе¹: basicstamps@yahoogroups.com
> it doesn't blink but my BT dongle detect eb500 with the device name
> eb500, I tried to switch from command mode to data mode but it fails,
> I believe that there's some problem but not totally dead, can anyone
> from parallex reply this email?
> Can I get a new one, I've just brought it and shipped to me this week
> and I definitely need to use it ASAP.
> Annie
> ©ó 2004¦~6¤ë9¤é ¤U¤È10:30 ®É¡AJonathan Peakall ´£¨ì¡G
>> Slim,
>> Does the EB500 status LED blink when you power on the unit? If not, it
>> might
>> be dead. If it does, post the code you are trying to use.
>> Jonathan
>> www.madlabs.info
>> From: "Annie Wan" <o_wan@y...>
>> To: <basicstamps@yahoogroups.com>
>> Sent: Wednesday, June 09, 2004 1:07 PM
>> Subject: Re: [noparse][[/noparse]basicstamps] eb500
>>> hi,
>>> yup exactly, I think hooking up BS and eb500 is the 1st step, I'm
>>> still
>>> in there, not even talking with the bt USB dongle
>>> I've done what you've told me but even the USB bt can't detect
>>> another
>>> bt exist and there's no light flashing or being lit in the eb500.
>>>>>>>> eb500 PIN 1 to BS2 GND
>>>>>>>> eb500 PIN 3 to BS2 Rx
>>>>>>>> eb500 PIN 4 to BS2 Tx
>>>>>>>> eb500 PIN 20 to BS2 VSS
>>> ©ó 2004¦~6¤ë9¤é ¤U¤È9:35 ®É¡AJonathan Peakall ´£¨ì¡G
>>>> Slim,
>>>> OK, I have done exactly waht you want to do, so I know it can be
>>>> done.
>>>> I
>>>> have a Stamp and EB500 hooked up on my desk right now. If I
>>>> understand
>>>> you
>>>> correctly, you are having trouble getting the EB500 and the Stamp to
>>>> work
>>>> together.
>>>> Did you try all the things I listed in the first message? When you
>>>> send a
>>>> command to the EB500, do you get and ACK or NCK?
>>>> Post the code you are using. It sounds like the problem is there.
>>>> Jonathan
>>>> www.madlabs.info
>>>> Sent: Wednesday, June 09, 2004 9:12 AM
>>>>> I want to attach the eb500 to BS and then using a bluetooth USB
>>>>> dongle
>>>>> in PC, I suppose the eb500 act ac a serial module replacement, am I
>>>>> buying the right stuff?
>>>>> ©ó 2004¦~6¤ë9¤é ¤U¤È4:10 ®É¡AJonathan Peakall ´£¨ì¡G
>>>>>> Slim,
>>>>>> I'm not quite sure what you are trying to do. Is it:
>>>>>> BS2+EB500
EB500+PC
>>>>>> Are you saying you can't get two EB500s to talk to each other? Or
>>>>>> are
>>>>>> you
>>>>>> saying that you can't get the BS2 to talk to an EB500?
>>>>>> Jonathan
>>>>>> Sent: Tuesday, June 08, 2004 11:16 AM
>>>>>>> hi,
>>>>>>> I did that already but still there's no response, BTW, do I need
>>>>>>> to
>>>>>>> connect the eb500 to a serial port first and config it, then
>>>>>>> connect
>>>>>>> the eb500 to BS?
>>>>>>> or just connect eb500 to BS directly? how can I configure it
>>>>>>> then?
>>>>>>> ©ó 2004¦~6¤ë7¤é ¤U¤È8:54 ®É¡AJonathan Peakall ´£¨ì¡G
>>>>>>>> Slim,
>>>>>>>> Looks like you have the TX/RX backwards. Have you tried
>>>>>>>> reversing
>>>>>>>> them? The
>>>>>>>> Stamp should SEROUT to pin 4 of the EB500, and SERIN on pin 3.
>>>>>>>> If
>>>>>>>> that
>>>>>>>> doesn't work, have you:
>>>>>>>> Checked the baud rate.
>>>>>>>> Reset to default baud rate.
>>>>>>>> Made sure the code is using the correct pins.
>>>>>>>> Removed all checks on the Connection Status pin since you are
>>>>>>>> not
>>>>>>>> using it.
>>>>>>>> Looked with a 'scope to see if you are getting anything.
>>>>>>>> Removed any SERIN statements that wait for the ACK.
>>>>>>>> HTH,
>>>>>>>> Jonathan
>>>>>>>> www.madlabs.info
>>>>>>>> Sent: Monday, June 07, 2004 9:53 AM
>>>>>>>> Subject: [noparse][[/noparse]basicstamps] eb500
>>>>>>>>> hi,
>>>>>>>>> did anyone try to connect eb500 directly to BS2 without any
>>>>>>>>> parallex
>>>>>>>>> boards? I've tried to connect
>>>>>>>>> eb500 PIN 3 to BS2 TX
>>>>>>>>> eb500 PIN 4 to BS2 RX
>>>>>>>>> But it seems not working, not light at all, any clues?
>>>>>>>>> slimboyfatboyslim
>>>>>>>>> http://www.slimboyfatboyslim.org
>>>>>>>>> To UNSUBSCRIBE, just send mail to:
>>>>>>>>> basicstamps-unsubscribe@yahoogroups.com
>>>>>>>>> from the same email address that you subscribed. Text in the
>>>>>>>>> Subject
>>>>>>>>> and
>>>>>>>> Body of the message will be ignored.
>>>>>>>>> Yahoo! Groups Links
>>>>>>>> Subject
>>>>>>>> and Body of the message will be ignored.
>>>>>>>> Yahoo! Groups Links
>>>>>>> slimboyfatboyslim
>>>>>>> [noparse][[/noparse]Non-text portions of this message have been removed]
>>>>>>> Subject
>>>>>>> and
>>>>>>> Yahoo! Groups Links
>>>>>> Subject
>>>>>> Yahoo! Groups Links
>>>>> slimboyfatboyslim
>>>>> Subject
>>>>> and
>>>>> Yahoo! Groups Links
>>>> Subject
>>>> Yahoo! Groups Links
>>> slimboyfatboyslim
>>> from the same email address that you subscribed. Text in the Subject
>>> and
>>> Yahoo! Groups Links
>> Yahoo! Groups Links
> slimboyfatboyslim
> Yahoo! Groups Links
slimboyfatboyslim
    edited 2004-06-11 17:42
    Annie,
    If the dongle is detecting the unit, it may be OK. What happens when you
    try to load some code into the Stamp to try to use the EB500?
    Jonathan
    www.madlabs.info
    Sent: Friday, June 11, 2004 8:04 AM
    Subject: [noparse][[/noparse]basicstamps] Fwd: URGENT, anyone from parallex reply?
    > ¶}©lÂà±H¶l¥ó¡G
    > > Annie
    > >> Slim,
    > >> might
    > >> Jonathan
    > >> www.madlabs.info
    > >>> hi,
    > >>> still
    > >>> another
    > >>>> Slim,
    > >>>> done.
    > >>>> I
    > >>>> understand
    > >>>> you
    > >>>> work
    > >>>> together.
    > >>>> send a
    > >>>> Jonathan
    > >>>> www.madlabs.info
    > >>>>> dongle
    > >>>>>> Slim,
    > >>>>>> BS2+EB500
    EB500+PC
    > >>>>>> are
    > >>>>>> you
    > >>>>>> Jonathan
    > >>>>>>> hi,
    > >>>>>>> to
    > >>>>>>> connect
    > >>>>>>> the eb500 to BS?
    > >>>>>>> then?
    > >>>>>>>> Slim,
    > >>>>>>>> reversing
    > >>>>>>>> them? The
    > >>>>>>>> If
    > >>>>>>>> that
    > >>>>>>>> not
    > >>>>>>>> using it.
    > >>>>>>>> HTH,
    > >>>>>>>> Jonathan
    > >>>>>>>> www.madlabs.info
    > >>>>>>>>> hi,
    > >>>>>>>>> parallex
    > >>>>>>>>> slimboyfatboyslim
    > >>>>>>>>> Subject
    > >>>>>>>>> and
    > >>>>>>>>> Yahoo! Groups Links
    > >>>>>>>> Subject
    > >>>>>>>> Yahoo! Groups Links
    > >>>>>>> slimboyfatboyslim
    > >>>>>>> Subject
    > >>>>>>> and
    > >>>>>>> Yahoo! Groups Links
    > >>>>>> Subject
    > >>>>>> Yahoo! Groups Links
    > >>>>> slimboyfatboyslim
    > >>>>> Subject
    > >>>>> and
    > >>>>> Yahoo! Groups Links
    > >>>> Subject
    > >>>> Yahoo! Groups Links
    > >>> slimboyfatboyslim
    > >>> and
    > >>> Yahoo! Groups Links
    > >> Yahoo! Groups Links
    > > slimboyfatboyslim
    > > Yahoo! Groups Links
    > slimboyfatboyslim
    > Yahoo! Groups Links
    edited 2004-06-11 17:49
    but it's not perfect, isn't it? they suppose to send me a perfect
    product, parallex people, please reply.
    ©ó 2004¦~6¤ë11¤é ¤U¤È6:42 ®É¡AJonathan Peakall ´£¨ì¡G
    > Annie,
    > you
    > Jonathan
    > www.madlabs.info
    >> ¶}©lÂà±H¶l¥ó¡G
    >>> Annie
    >>>> Slim,
    >>>> it
    >>>> might
    >>>> Jonathan
    >>>> www.madlabs.info
    >>>>> hi,
    >>>>> still
    >>>>> another
    >>>>>> Slim,
    >>>>>> done.
    >>>>>> I
    >>>>>> understand
    >>>>>> you
    >>>>>> to
    >>>>>> work
    >>>>>> together.
    >>>>>> send a
    >>>>>> Jonathan
    >>>>>> www.madlabs.info
    >>>>>>> dongle
    >>>>>>> am I
    >>>>>>>> Slim,
    >>>>>>>> BS2+EB500
    EB500+PC
    >>>>>>>> Or
    >>>>>>>> are
    >>>>>>>> you
    >>>>>>>> Jonathan
    >>>>>>>>> hi,
    >>>>>>>>> need
    >>>>>>>>> to
    >>>>>>>>> connect
    >>>>>>>>> the eb500 to BS?
    >>>>>>>>> then?
    >>>>>>>>>> Slim,
    >>>>>>>>>> reversing
    >>>>>>>>>> them? The
    >>>>>>>>>> If
    >>>>>>>>>> that
    >>>>>>>>>> not
    >>>>>>>>>> using it.
    >>>>>>>>>> HTH,
    >>>>>>>>>> Jonathan
    >>>>>>>>>> www.madlabs.info
    >>>>>>>>>>> hi,
    >>>>>>>>>>> parallex
    >>>>>>>>>>> slimboyfatboyslim
    >>>>>>>>>>> Subject
    >>>>>>>>>>> and
    >>>>>>>>>>> Yahoo! Groups Links
    >>>>>>>>>> Subject
    >>>>>>>>>> Yahoo! Groups Links
    >>>>>>>>> slimboyfatboyslim
    >>>>>>>>> Subject
    >>>>>>>>> and
    >>>>>>>>> Yahoo! Groups Links
    >>>>>>>> Subject
    >>>>>>>> Yahoo! Groups Links
    >>>>>>> slimboyfatboyslim
    >>>>>>> Subject
    >>>>>>> and
    >>>>>>> Yahoo! Groups Links
    >>>>>> Subject
    >>>>>> Yahoo! Groups Links
    >>>>> slimboyfatboyslim
    >>>>> Subject
    >>>>> and
    >>>>> Yahoo! Groups Links
    >>>> Subject
    >>>> Yahoo! Groups Links
    >>> slimboyfatboyslim
    >>> Yahoo! Groups Links
    >> slimboyfatboyslim
    >> and
    >> Yahoo! Groups Links
    > Yahoo! Groups Links
    slimboyfatboyslim
    edited 2004-06-13 17:42
    If you believe you have a defective unit, contact support@p... for instructions on returning for an exchange.
    -- Jon Williams
    -- Dallas Office
    From: Annie Wan [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=8m0_fWXZZQjG3gRZUURYmf6cHb6IfZ_dZ2HQNkg8VfzukrPlTzOXUXCxEvLVzxJtiRlrPh7qss8bEA]o_wan@y...[/url
    Sent: Friday, June 11, 2004 10:05 AM
    ³«»ÏíÛ´ó͹·ï¡§
    > ´ó·ï¿Í: Annie Wan <o_wan@y...>
    > Æü´ü: 2004ǯ06·î10Æü ²¼¸á07»þ42ʬ37ÉÃ
    > ÚÀ·ï¿Í: basicstamps@yahoogroups.com
    > ɸÂê: Re: [noparse][[/noparse]basicstamps] eb500
    > ²óʤµë: basicstamps@yahoogroups.com
    > from parallex reply this email? Can I get a new one, I've just brought
    > it and shipped to me this week and I definitely need to use it ASAP.
    > Annie
    > ±÷ 2004ǯ6·î9Æü ²¼¸á10:30 »þ¡¤Jonathan Peakall ÄóÅþ¡§
    >> Slim,
    >> it might be dead. If it does, post the code you are trying to use.
    >> Jonathan
    >> www.madlabs.info
    >>> hi,
    >>> still in there, not even talking with the bt USB dongle
    >>> another
    >>> ±÷ 2004ǯ6·î9Æü ²¼¸á9:35 »þ¡¤Jonathan Peakall ÄóÅþ¡§
    >>>> Slim,
    >>>> done. I
    >>>> understand
    >>>> you
    >>>> work
    >>>> together.
    >>>> send a command to the EB500, do you get and ACK or NCK?
    >>>> Jonathan
    >>>> www.madlabs.info
    >>>>> dongle in PC, I suppose the eb500 act ac a serial module
    >>>>> replacement, am I buying the right stuff?
    >>>>> ±÷ 2004ǯ6·î9Æü ²¼¸á4:10 »þ¡¤Jonathan Peakall ÄóÅþ¡§
    >>>>>> Slim,
    >>>>>> BS2+EB500
    EB500+PC
    >>>>>> are you
    >>>>>> Jonathan
    >>>>>>> hi,
    >>>>>>> to connect the eb500 to a serial port first and config it, then
    >>>>>>> connect
    >>>>>>> the eb500 to BS?
    >>>>>>> then?
    >>>>>>> ±÷ 2004ǯ6·î7Æü ²¼¸á8:54 »þ¡¤Jonathan Peakall ÄóÅþ¡§
    >>>>>>>> Slim,
    >>>>>>>> reversing
    >>>>>>>> them? The
    >>>>>>>> If
    >>>>>>>> that
    >>>>>>>> not
    >>>>>>>> using it.
    >>>>>>>> HTH,
    >>>>>>>> Jonathan
    >>>>>>>> www.madlabs.info
    >>>>>>>>> hi,
    >>>>>>>>> parallex boards? I've tried to connect
    >>>>>>>>> slimboyfatboyslim
    >>>>>>>>> Subject and
    >>>>>>>>> Yahoo! Groups Links
    >>>>>>>> Subject and Body of the message will be ignored.
    >>>>>>>> Yahoo! Groups Links
    >>>>>>> slimboyfatboyslim
    >>>>>>> Subject and
    >>>>>>> Yahoo! Groups Links
    >>>>>> Yahoo! Groups Links
    >>>>> slimboyfatboyslim
    >>>>> Subject and
    >>>>> Yahoo! Groups Links
    >>>> Subject
    >>>> Yahoo! Groups Links
    >>> slimboyfatboyslim
    >>> Subject and
    >>> Yahoo! Groups Links
    >> Yahoo! Groups Links
    > slimboyfatboyslim
    > Yahoo! Groups Links
    slimboyfatboyslim
    from the same email address that you subscribed. Text in the Subject and Body of the message will be ignored.
    Yahoo! Groups Links
    This message has been scanned by WebShield. Please report SPAM to abuse@p....
    Dear Annie,
    Please contact our customer service department at 888 512-1024 or sales@p... and one of our representatives will assist you.
    For any other similar inquiries, please contact us directly so we can assist you as soon as possible. It would be unfortunate if we missed your posting and were unable to react quickly. In this case, our office was closed all day on Friday.
    Erik Wood
    Get started with the BASIC Stamp(r) microcontroller!
    Parallax Summer Special is only $79
    Visit www.parallax.com for details
    From: Annie Wan [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=tfSYvE-watfQXTpOR4stVBkXsrw37eCeYAPHp6oR0lIW7z2Gl47fpCHfiz7wXmhAK2lGdsvclKO7geXs]o_wan@y...[/url
    Sent: Friday, June 11, 2004 9:50 AM
    Subject: Re: [noparse][[/noparse]basicstamps] Fwd: URGENT, anyone from parallex reply?
    ±÷ 2004ǯ6·î11Æü ²¼¸á6:42 »þ¡¤Jonathan Peakall ÄóÅþ¡§
    > Annie,
    > you
    > Jonathan
    > www.madlabs.info
    >> ³«»ÏíÛ´ó͹·ï¡§
    >>> Annie
    >>>> Slim,
    >>>> it
    >>>> might
    >>>> Jonathan
    >>>> www.madlabs.info
    >>>>> hi,
    >>>>> still
    >>>>> another
    >>>>>> Slim,
    >>>>>> done.
    >>>>>> I
    >>>>>> understand
    >>>>>> you
    >>>>>> to
    >>>>>> work
    >>>>>> together.
    >>>>>> send a
    >>>>>> Jonathan
    >>>>>> www.madlabs.info
    >>>>>>> dongle
    >>>>>>> am I
    >>>>>>>> Slim,
    >>>>>>>> BS2+EB500
    EB500+PC
    >>>>>>>> Or
    >>>>>>>> are
    >>>>>>>> you
    >>>>>>>> Jonathan
    >>>>>>>>> hi,
    >>>>>>>>> need
    >>>>>>>>> to
    >>>>>>>>> connect
    >>>>>>>>> the eb500 to BS?
    >>>>>>>>> then?
    >>>>>>>>>> Slim,
    >>>>>>>>>> reversing
    >>>>>>>>>> them? The
    >>>>>>>>>> If
    >>>>>>>>>> that
    >>>>>>>>>> not
    >>>>>>>>>> using it.
    >>>>>>>>>> HTH,
    >>>>>>>>>> Jonathan
    >>>>>>>>>> www.madlabs.info
    >>>>>>>>>>> hi,
    >>>>>>>>>>> parallex
    >>>>>>>>>>> slimboyfatboyslim
    >>>>>>>>>>> Subject
    >>>>>>>>>>> and
    >>>>>>>>>>> Yahoo! Groups Links
    >>>>>>>>>> Subject
    >>>>>>>>>> Yahoo! Groups Links
    >>>>>>>>> slimboyfatboyslim
    >>>>>>>>> Subject
    >>>>>>>>> and
    >>>>>>>>> Yahoo! Groups Links
    >>>>>>>> Subject
    >>>>>>>> Yahoo! Groups Links
    >>>>>>> slimboyfatboyslim
    >>>>>>> Subject
    >>>>>>> and
    >>>>>>> Yahoo! Groups Links
    >>>>>> Subject
    >>>>>> Yahoo! Groups Links
    >>>>> slimboyfatboyslim
    >>>>> Subject
    >>>>> and
    >>>>> Yahoo! Groups Links
    >>>> Subject
    >>>> Yahoo! Groups Links
    >>> slimboyfatboyslim
    >>> Yahoo! Groups Links
    >> slimboyfatboyslim
    >> and
    >> Yahoo! Groups Links
    > Yahoo! Groups Links
    slimboyfatboyslim
    Yahoo! Groups Links
