ds2450 power pull down on bs2p40 board
Hi guys,
I just picked up my bs2p40 demo board and have been playing a little bit
with some temp sensors.
So, I know the stamp works well enough.
Now, I picked up a ds2450 1-wire quad A-D converter.
My mistake was getting the 8pin surface mount (SOIC?) rather than the DIP
package.
So anyhow, I solder tacked some wire wrap to each pin and then to a dip
socket and then put that in the demo board.
When I apply power to the ds2450 I can see the power LED dim. So I tossed
on a DMM and can see the power go from 5V down to 2.3! the longer I hold it
there the higher it gets...BUT, I can smell heat (you know the smell I mean)
coming from the board ( regulator? ).
The other items I have on my board that are powered are an LM35 (this is
what I want to use the ds2450 with) and a ds1620 digital therm.
seem only when I connect power to the A-D converter that the power
foldsback. Could my regulator be bad? I think so! Just wanna get some
advice.
My next question after this is sorted will be....how the heck do I use the
ds2450!! lol
package.
advice.
ds2450!! lol
it
mean)
That is the blue smoke trying to get out. If you let it get out, the
device won't
work anymore!!<VBG>
Tom Fisher
BigD
If you disconnect the DS2450, are the other components working properly?
Does the power LED still go dim? If not, then more than likely you have
a short surrounding the DS2450 chip in your circuit. If you have any
more questions please feel free to e-mail us.
Dave Andreae
Tech Support
PH. 916-624-8333
Stamp Support/ stamptech@p...
Javelin Support/ javelinsupport@p...
SX-Support/ sxtech@p...
websites
parallax.com
stampsinclass.com
Original Message
From: SB [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=suOfy44cLzpWTZNot2wDAt3mKqddBI2z_zkaeMe2zFjVOEcCdMXYxDdrZa9Zzj-R-p2SK-CsOSf-S5qdio0]steve.brady@r...[/url
Sent: Thursday, April 29, 2004 3:18 PM
To: basicstamps@yahoogroups.com
Subject: [noparse][[/noparse]basicstamps] ds2450 power pull down on bs2p40 board
Hi guys,
DIP
package.
tossed
hold it
mean)
advice.
the
ds2450!! lol
To UNSUBSCRIBE, just send mail to:
basicstamps-unsubscribe@yahoogroups.com
from the same email address that you subscribed. Text in the Subject
and Body of the message will be ignored.
Yahoo! Groups Links
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
as soon as I disconnect the ds2450, the voltage (and LED) all go back to a
normal state.
I'm unsure about the DS2450....popped something on the inside maybe....which
is loading down the regulator.
Original Message
To: <basicstamps@yahoogroups.com>
Sent: Thursday, April 29, 2004 6:39 PM
Subject: RE: [noparse][[/noparse]basicstamps] ds2450 power pull down on bs2p40 board
> Hello,
> Dave Andreae
> Tech Support
> PH. 916-624-8333
> websites
> parallax.com
> stampsinclass.com
Original Message
> From: SB [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=Ue6MnK3LvBy9f4YKgEKkUdhFkLWz3Grq6joWHw77zByvche2cNFAEPPMmp9q83FEoPY9aHhMCXLOPoBgCpQRCg]steve.brady@r...[/url
> Hi guys,
> DIP
> package.
> tossed
> hold it
> mean)
> advice.
> the
> ds2450!! lol
> Yahoo! Groups Links
> abuse@p....
> from the same email address that you subscribed. Text in the Subject and
> Yahoo! Groups Links
It sounds like the chip is damaged, that could have been caused by a
short in the soldering or a mis-connected circuit or you received a bad
chip. We have the Philips PCF8591 4-channel A2D plus 1-channel D2A,
it's not a Dallas one-wire product, and it's a Philips IC2 product. If
you like I can send you the information regarding the wiring diagram and
sample code?
Dave
Dave Andreae
Tech Support
PH. 916-624-8333
websites
parallax.com
stampsinclass.com
Original Message
From: SB [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=78yHfpMtCDuRO3-P0fYyHMX_D3QDVdjpdL6kczGvpDSlxlOCDRpp25NCVrkYxAEvj8wd7gSEWamnG6nJCIPoGA]steve.brady@r...[/url
Sent: Thursday, April 29, 2004 3:46 PM
Subject: Re: [noparse][[/noparse]basicstamps] ds2450 power pull down on bs2p40 board
Hi Dave,
a
normal state.
maybe....which
Original Message
> Hello,
properly?
have
> Dave Andreae
> Tech Support
> PH. 916-624-8333
> websites
> parallax.com
> stampsinclass.com
Original Message
> Hi guys,
bit
> DIP
> package.
dip
> tossed
> hold it
> mean)
is
some
> advice.
> the
> ds2450!! lol
> Yahoo! Groups Links
> abuse@p....
and
> Yahoo! Groups Links
Yahoo! Groups Links
abuse@p....
answer back with a PRESENCE code!! lol couldn't find out what this was.
And what I got back was FF....which doesn't tell me anything more than that
the pull-up resistor is connected to 5volts!
I might have put too much heat to the chip while soldering too! those dam
little wire wrap wires break easy and I had to do it a couple times....I did
this a couple minutes before leaving for the day...I'll do some continuity
checks tomorrow....but I wasn't sure if the bs2p40 is so power hungry that
you couldn't power a bunch of other devices off of it's on board regulator.
But still this A-D doesn't use much for power if it's not converting!
Original Message
Sent: Thursday, April 29, 2004 7:18 PM
> Hi Steve,
> sample code?
> Dave
> Dave Andreae
> Tech Support
> PH. 916-624-8333
> websites
> parallax.com
> stampsinclass.com
Original Message
> From: SB [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=KWniidnxGqBPgxlnrzpSuxqv7W0sFKTA2dSF9NYkx4N5rHuBSL7iEhzTZAxqb8rY5SfBNltK8UscdWWzcebK51s]steve.brady@r...[/url
> Hi Dave,
> a
> normal state.
> maybe....which
Original Message
> From: "Dave Andreae" <dandreae@p...>
> > Hello,
> properly?
> have
> > Dave Andreae
> > Tech Support
> > PH. 916-624-8333
> > websites
> > parallax.com
> > stampsinclass.com
Original Message
> > Hi guys,
> bit
> > DIP
> > package.
> dip
> > tossed
> > hold it
> > mean)
> is
> some
> > advice.
> > the
> > ds2450!! lol
> > Yahoo! Groups Links
> > abuse@p....
> and
> > Yahoo! Groups Links
> Yahoo! Groups Links
> abuse@p....
> Yahoo! Groups Links
working electrically, you'll find demo code for the DS2450 in our Plus
Pack documentation.
-- Jon Williams
-- Applications Engineer, Parallax
-- Dallas Office
Original Message
From: SB [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=LPDJ6sORercCkRLHftQfYQLrZzREc-4qxXSHZNh3jeHUs7DkQATFrBBWQinN2Q7KLHLkJLwobHdXyznH]steve.brady@r...[/url
Sent: Thursday, April 29, 2004 5:18 PM
Hi guys,
with some temp sensors. So, I know the stamp works well enough. Now, I
DIP package. So anyhow, I solder tacked some wire wrap to each pin and
then to a dip socket and then put that in the demo board.
tossed on a DMM and can see the power go from 5V down to 2.3! the
longer I hold it there the higher it gets...BUT, I can smell heat (you
know the smell I mean) coming from the board ( regulator? ).
what I want to use the ds2450 with) and a ds1620 digital therm. seem
only when I connect power to the A-D converter that the power foldsback.
Could my regulator be bad? I think so! Just wanna get some advice.
the ds2450!! lol
-- Jon Williams
-- Dallas Office
Original Message
Sent: Thursday, April 29, 2004 7:39 PM
Perhaps you connected the DS2450 incorrectly?.... Once you get things
Pack documentation.
-- Jon Williams
-- Dallas Office
Original Message
From: SB [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=_apAB8BvZQRfNgHnfR3PvJ0gx-culovC4EctpfpvF2OVhKG0g1XvyWBNwAoaOWnCWN290nM9NgFObeS78Z-yTg]steve.brady@r...[/url
Hi guys,
the ds2450!! lol
Yahoo! Groups Links
abuse@p....
I just checked the datasheet and yes...vcc is pin1 and gnd is pin4. data
spits out of pin3.
I'm thinking I applied too much heat and popped one of the interconnect
wires on the inside....
Original Message
Sent: Thursday, April 29, 2004 8:42 PM
> Whoops ... my mistake, we have code for the DS2405 (switch).
> -- Jon Williams
> -- Dallas Office
Original Message
> From: Jon Williams
> Pack documentation.
> -- Jon Williams
> -- Dallas Office
Original Message
> From: SB [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=JbqpK8cMHoLcM2rTIVtSeBdoVx1z1q20Q2ql0jzlLj18JTXASNTm4yglm56wwSOVg65m4b3pLrhZwfIfQmpvGc0]steve.brady@r...[/url
> Hi guys,
> the ds2450!! lol
> Yahoo! Groups Links
> abuse@p....
> Yahoo! Groups Links
