Multiplying decs with a Stamp
Sitting around waiting for parts so thought I would post something for the
benefit of the newer fellows on the block. This has to do with multiplying a
number by a decimal. This works on anything from a BS2 on up.
Suppose you want to multiply 56 by 1.47. The Stamp won't accept decimals so
we have to use a way around it. The tool we use is the star/slash operator:
Here's how we do it. First, we convert 1.47 to a 4-digit hex number.
1 = $01 - that was easy. Now we need to convert the '.47' to a hex number.
Multiply 256 by .47 = 120.32. Now convert 120 to hex = 78 (we drop the .32).
So for this purpose 1.47 in hex = $0178
Then we write
a = 56
a = a*/$0178
debug "a = ", dec a, cr
The screen will display "82". 56 * 1.47 = 82.32, so that's pretty close.
However, we can improve on that tremendously by writing:
a = 56
a = a * 100
a = a*/$0178
If we write
debug "a = ", dec a/100, ".", dec2 a, cr
we get a = 82.25. Now that's CLOSE!
Just remember - a * 100 can not exceed 65535. That's the biggest number
Stamp can handle.
Hope this helps someone out there.
Sid Weaver
Making things easier.....
http://www.visualmuses.com/chipcircuit/index.html
Then we write
a = 56
a = a*/$0178
a = 56
a = a * 100
a = a*/$0178
If we write
Stamp can handle.
Sid Weaver
In your example, you can get even closer to the exact answer with,
a=56
y=a */ 37632 ' equiv to a * 1.47
debug dec y/100,".",dec2 y ' prints 82.32
'works for values of a: {0 <= a < 446}
The constant 37632 comes from 1.47*100*256.
Background, we are finding the constant, K, that satisfies this proportion:
K/256 = 147/100 ' k=376 or k=$0178
Just as "1.47" is shorthand for 147/100, the Stamp thinks in binary
arithmetic, approximating the same proportion as K/256.
Inside the Stamp, it does "a * y" to get a 32 bit product, and then
shifts that product 8 bits right, which is the same as dividing by
256.
Or, for better accuracy, in decimal times 100:
K/256 = 14700/100 ' k=37632 or k=$9300
The number base you use for the */ factor does not matter.
Note that
y = a */ 376
is good for values of a from 0 to 44581, while
y = a */ 37632
is good only for values of a from 0 to 445, and there are more
significant figures in y then there are in a, a dubious situation. A
compromise is,
y = a */ 3763
debug dec y/10,".",dec1 y
which is good for values of a from 0 to 4458, with answer y from 0 to
6552.9, and that gives a good basis for roundoff back to 4
significant digits.
By tthe way, the */ operator is commutative. That is, a */ k = k */
a. The proof is left to the end of the chapter!
-- Tracy
>Then we write
>a = 56
>a = a*/$0178
>a = 56
>a = a * 100
>a = a*/$0178
>If we write
>Stamp can handle.
>Sid Weaver
>To UNSUBSCRIBE, just send mail to:
>from the same email address that you subscribed. Text in the
>Subject and Body of the message will be ignored.
>Yahoo! Groups Links
go find that 2by4 to knock myself with! haha
Well Done Tracy....
Original Message
To: <basicstamps@yahoogroups.com>
Sent: Thursday, April 22, 2004 12:46 PM
Subject: Re: [noparse][[/noparse]basicstamps] Multiplying decs with a Stamp
> Hi Sid,
> a=56
proportion:
> 256.
> Note that
> y = a */ 376
> y = a */ 37632
> compromise is,
> y = a */ 3763
> significant digits.
> -- Tracy
the
multiplying a
so
operator:
number.
.32).
> >Then we write
> >a = 56
> >a = a*/$0178
close.
> >a = 56
> >a = a * 100
> >a = a*/$0178
> >If we write
> >Stamp can handle.
> >Sid Weaver
> >Yahoo! Groups Links
> from the same email address that you subscribed. Text in the Subject and
> Yahoo! Groups Links
