Multiplying decs with a Stamp — Parallax Forums
edited 2004-04-23 03:03 in General Discussion
Sitting around waiting for parts so thought I would post something for the
benefit of the newer fellows on the block. This has to do with multiplying a
number by a decimal. This works on anything from a BS2 on up.
Suppose you want to multiply 56 by 1.47. The Stamp won't accept decimals so
we have to use a way around it. The tool we use is the star/slash operator:
Here's how we do it. First, we convert 1.47 to a 4-digit hex number.
1 = $01 - that was easy. Now we need to convert the '.47' to a hex number.
Multiply 256 by .47 = 120.32. Now convert 120 to hex = 78 (we drop the .32).
So for this purpose 1.47 in hex = $0178
Then we write
a = 56
a = a*/$0178
debug "a = ", dec a, cr
The screen will display "82". 56 * 1.47 = 82.32, so that's pretty close.
However, we can improve on that tremendously by writing:
a = 56
a = a * 100
a = a*/$0178
If we write
debug "a = ", dec a/100, ".", dec2 a, cr
we get a = 82.25. Now that's CLOSE!
Just remember - a * 100 can not exceed 65535. That's the biggest number
Stamp can handle.
Hope this helps someone out there.
Sid Weaver
Making things easier.....
http://www.visualmuses.com/chipcircuit/index.html
    edited 2004-04-22 17:46
    Hi Sid,
    In your example, you can get even closer to the exact answer with,
    a=56
    y=a */ 37632 ' equiv to a * 1.47
    debug dec y/100,".",dec2 y ' prints 82.32
    'works for values of a: {0 <= a < 446}
    The constant 37632 comes from 1.47*100*256.
    Background, we are finding the constant, K, that satisfies this proportion:
    K/256 = 147/100 ' k=376 or k=$0178
    Just as "1.47" is shorthand for 147/100, the Stamp thinks in binary
    arithmetic, approximating the same proportion as K/256.
    Inside the Stamp, it does "a * y" to get a 32 bit product, and then
    shifts that product 8 bits right, which is the same as dividing by
    256.
    Or, for better accuracy, in decimal times 100:
    K/256 = 14700/100 ' k=37632 or k=$9300
    The number base you use for the */ factor does not matter.
    Note that
    y = a */ 376
    is good for values of a from 0 to 44581, while
    y = a */ 37632
    is good only for values of a from 0 to 445, and there are more
    significant figures in y then there are in a, a dubious situation. A
    compromise is,
    y = a */ 3763
    debug dec y/10,".",dec1 y
    which is good for values of a from 0 to 4458, with answer y from 0 to
    6552.9, and that gives a good basis for roundoff back to 4
    significant digits.
    By tthe way, the */ operator is commutative. That is, a */ k = k */
    a. The proof is left to the end of the chapter!
    -- Tracy
    >Then we write
    >a = 56
    >a = a*/$0178
    >a = 56
    >a = a * 100
    >a = a*/$0178
    >If we write
    >Stamp can handle.
    >Sid Weaver
    >from the same email address that you subscribed. Text in the
    >Subject and Body of the message will be ignored.
    >Yahoo! Groups Links
    I think that was english....I DID read it....and I think I'll quit now and
    go find that 2by4 to knock myself with! haha
    Well Done Tracy....
    Sent: Thursday, April 22, 2004 12:46 PM
    Subject: Re: [noparse][[/noparse]basicstamps] Multiplying decs with a Stamp
    > Hi Sid,
    > a=56
    proportion:
    > 256.
    > Note that
    > y = a */ 376
    > y = a */ 37632
    > compromise is,
    > y = a */ 3763
    > significant digits.
    > -- Tracy
    the
    multiplying a
    so
    operator:
    number.
    .32).
    > >Then we write
    > >a = 56
    > >a = a*/$0178
    close.
    > >a = 56
    > >a = a * 100
    > >a = a*/$0178
    > >If we write
    > >Stamp can handle.
    > >Sid Weaver
    > >Yahoo! Groups Links
    > Yahoo! Groups Links
