Help with debugging count command please!
I have the following snippet in my code:
Ign VAR Word 'Declare variable to hold number of pulses
Ign = 0
Main:
'Count pulses on input pin
COUNT 1,1000,Ign
DEBUG Ign 'Debugging - output the variable amount.
To test it I have put in the debug command as shown, but nothing
appears. I tried commenting out the Count command, thinking that it
should at least show zero as shown, but it doesn't. Other debug stuff
is fine (i.e. Debug "Hello world"!) but this isn't doing a thing. Bit
stumped, help!
James
Ign = 0
Main:
COUNT 1,1000,Ign
stumped, help!
James
display number -- you have to covnert numeric values to an ASCII string
before sending to DEBUG. Change your DEBUG line to this:
DEBUG DEC ign
Any value less that 32 that gets sent to the DEBUG window will be
interpreted as a control code. Using the DEC (or HEX or BIN) modifier
changes the value to an ASCII string that can be displayed without
trouble.
-- Jon Williams
-- Applications Engineer, Parallax
-- Dallas Office
Original Message
From: james.billings@n... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=-givI406EUQ1tuYaIXc-RYFlIm8m5Enuwe_HDR5ku7CHzq2LkUccK0Y4KByaARXzMNS0gKLRJEZsVVsuJ_rZ1FSZkAoViA]james.billings@n...[/url
Sent: Friday, April 16, 2004 2:41 PM
To: basicstamps@yahoogroups.com
Subject: [noparse][[/noparse]basicstamps] Help with debugging count command please!
Ign = 0
Main:
COUNT 1,1000,Ign
stumped, help!
James
count now - thats more of a circuit problem I think though. One
question - the instructions say Count treats a single count as a 0-1-
0 type signal - does the 0 need to be an actual grounded voltage? I
am trying to use it to measure a pulsed 12v voltage and my circuit
goes through an opto isolator, but I am wondering if nothing-12v-
nothing is going to be different to 0v-12v-0v?
James
--- In basicstamps@yahoogroups.com, "Jon Williams" <jwilliams@p...>
wrote:
> You need to tell the DEBUG window what format to use when you want
to
string
> DEBUG DEC ign
modifier
> trouble.
make sure that your zero swing is below that (ideally, ground), and your
1 swing above it (ideally, +5). You should probably make sure your
"nothing" becomes ground by using a pull-down -- don't let it float as
this will probably give you unreliable results.
-- Jon Williams
-- Dallas Office
Original Message
From: james.billings@n... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=gTnaE_NDl1hzxfPViBSRn0XNaEcTocrfli65eETczxUVSZ5ALpFQ9JDStSaoptvAviWMLa7hX9ZvV6DB5JdMQSTYjKD4]james.billings@n...[/url
Sent: Friday, April 16, 2004 3:02 PM
Subject: [noparse][[/noparse]basicstamps] Re: Help with debugging count command please!
Thanks Jon, that worked a treat. Just need to get it to actually
question - the instructions say Count treats a single count as a 0-1- 0
nothing is going to be different to 0v-12v-0v? James
to
string
> DEBUG DEC ign
modifier
> trouble.
To UNSUBSCRIBE, just send mail to:
basicstamps-unsubscribe@yahoogroups.com
from the same email address that you subscribed. Text in the Subject
and Body of the message will be ignored.
Yahoo! Groups Links
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
