Help with debugging count command please! — Parallax Forums
edited 2004-04-16 21:52 in General Discussion
I have the following snippet in my code:
Ign VAR Word 'Declare variable to hold number of pulses
Ign = 0
Main:
'Count pulses on input pin
COUNT 1,1000,Ign
DEBUG Ign 'Debugging - output the variable amount.
To test it I have put in the debug command as shown, but nothing
appears. I tried commenting out the Count command, thinking that it
should at least show zero as shown, but it doesn't. Other debug stuff
is fine (i.e. Debug "Hello world"!) but this isn't doing a thing. Bit
stumped, help!
James
    edited 2004-04-16 20:55
    You need to tell the DEBUG window what format to use when you want to
    display number -- you have to covnert numeric values to an ASCII string
    before sending to DEBUG. Change your DEBUG line to this:
    DEBUG DEC ign
    Any value less that 32 that gets sent to the DEBUG window will be
    interpreted as a control code. Using the DEC (or HEX or BIN) modifier
    changes the value to an ASCII string that can be displayed without
    trouble.
    -- Jon Williams
    -- Dallas Office
    From: james.billings@n... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=-givI406EUQ1tuYaIXc-RYFlIm8m5Enuwe_HDR5ku7CHzq2LkUccK0Y4KByaARXzMNS0gKLRJEZsVVsuJ_rZ1FSZkAoViA]james.billings@n...[/url
    Sent: Friday, April 16, 2004 2:41 PM
    Subject: [noparse][[/noparse]basicstamps] Help with debugging count command please!
    Ign = 0
    Main:
    COUNT 1,1000,Ign
    stumped, help!
    James
    edited 2004-04-16 21:01
    Thanks Jon, that worked a treat. Just need to get it to actually
    count now - thats more of a circuit problem I think though. One
    question - the instructions say Count treats a single count as a 0-1-
    0 type signal - does the 0 need to be an actual grounded voltage? I
    am trying to use it to measure a pulsed 12v voltage and my circuit
    goes through an opto isolator, but I am wondering if nothing-12v-
    nothing is going to be different to 0v-12v-0v?
    James
    --- In basicstamps@yahoogroups.com, "Jon Williams" <jwilliams@p...>
    to
    string
    > DEBUG DEC ign
    modifier
    > trouble.
    The BASIC Stamp 0-1 switching threshold is about 1.5 volts. You need to
    make sure that your zero swing is below that (ideally, ground), and your
    1 swing above it (ideally, +5). You should probably make sure your
    "nothing" becomes ground by using a pull-down -- don't let it float as
    this will probably give you unreliable results.
    -- Jon Williams
    -- Dallas Office
    From: james.billings@n... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=gTnaE_NDl1hzxfPViBSRn0XNaEcTocrfli65eETczxUVSZ5ALpFQ9JDStSaoptvAviWMLa7hX9ZvV6DB5JdMQSTYjKD4]james.billings@n...[/url
    Sent: Friday, April 16, 2004 3:02 PM
    Subject: [noparse][[/noparse]basicstamps] Re: Help with debugging count command please!
    question - the instructions say Count treats a single count as a 0-1- 0
    nothing is going to be different to 0v-12v-0v? James
    to
    string
    > DEBUG DEC ign
    modifier
    > trouble.
    Yahoo! Groups Links
    This message has been scanned by WebShield. Please report SPAM to
    abuse@p....
