convert 12 bit parallel to outputdata for SHIFTOUT
How could I convert 12 bit parallel to OutputData for SHIFTOUT function?
Can I have a little example showing how to do that?
Lee
Lee
huy_le123@y... writes:
The shiftout command will only handle bytes. If your variable is a word, you
could shiftout variable.high byte, variable .lowbyte.
Sid
SHIFTOUT Dpin, Cpin, Mode, [noparse][[/noparse]someData\12]
This is covered in the manual (hint) and the help file (hint).
-- Jon Williams
-- Applications Engineer, Parallax
-- Dallas Office
Original Message
From: huy_le123 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=ijSpI5qREiI3RptnyAG3FjsemKFfVPFnDVYOFypmdkFF4tGEsIL7Jg8MmMyktPUV-kww34hPq3ZrvUUT]huy_le123@y...[/url
Sent: Tuesday, April 13, 2004 6:33 PM
To: basicstamps@yahoogroups.com
Subject: [noparse][[/noparse]basicstamps] convert 12 bit parallel to outputdata for
SHIFTOUT
Lee
other than 8 bits, then you must specify the bit count with the \
parameter after the output data.
SHIFTOUT Dpin, Cpin, Mode, [noparse][[/noparse]outputData\12]
-- Jon Williams
-- Dallas Office
Original Message
From: Newzed@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=jOWdEsJKfGmbr4yTroU-UrSy7YSUQMGYLzO3l1TygCLQnCoUuzNJWJm-uJzsBN1FkP5T2T8kAfc]Newzed@a...[/url
Sent: Tuesday, April 13, 2004 6:36 PM
Subject: Re: [noparse][[/noparse]basicstamps] convert 12 bit parallel to outputdata for
SHIFTOUT
In a message dated 4/13/2004 7:33:59 PM Eastern Daylight Time,
> function?
word, you
Sid
Another issue, there are 36 clocks required to clock all the data,
but my data is only 8 bit. What can i do?
here is little sample code i wrote to generate 8 clock pulses while
writing each bit, but i need some helps to generate 36 clock pulse
DAC_CE CON 0
DAC_DATA CON 1
DAC_CLK CON 2
wTemp VAR BYTE
LOW DAC_CE
wTemp = $100
SHIFTOUT DAC_DATA,DAC_CLK,msbfirst,[noparse][[/noparse]wTemp]
HIGH DAC_CE
I appreciate for your helps,
Lee
--- In basicstamps@yahoogroups.com, "Jon Williams" <jwilliams@p...>
wrote:
> Sure...
> -- Jon Williams
> -- Dallas Office
Original Message
> From: huy_le123 [noparse][[/noparse]mailto:huy_le123@y...]
> SHIFTOUT
function?
> Thanks,
> Lee
-- Jon Williams
-- Dallas Office
Original Message
From: huy_le123 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=cHlvsyf5kUNoSITjK6sSZEe8LDOkqDr3CoPrnLO_LJ9zZtQ4OFS6R2T-gyfe-k6IwMenyWz493j8TBo]huy_le123@y...[/url
Sent: Wednesday, April 14, 2004 2:29 AM
Subject: [noparse][[/noparse]basicstamps] Re: convert 12 bit parallel to outputdata for
SHIFTOUT
Thanks a lot for your help.
DAC_CE CON 0
DAC_DATA CON 1
DAC_CLK CON 2
wTemp VAR BYTE
LOW DAC_CE
wTemp = $100
HIGH DAC_CE
Lee
wrote:
> Sure...
> -- Jon Williams
> -- Dallas Office
Original Message
> SHIFTOUT
function?
> Thanks,
> Lee
To UNSUBSCRIBE, just send mail to:
basicstamps-unsubscribe@yahoogroups.com
from the same email address that you subscribed. Text in the Subject
and Body of the message will be ignored.
Yahoo! Groups Links
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
Lee
wrote:
> What device are you working with?
> -- Jon Williams
> -- Dallas Office
Original Message
> SHIFTOUT
> DAC_CE CON 0
> DAC_DATA CON 1
> DAC_CLK CON 2
> wTemp VAR BYTE
> LOW DAC_CE
> wTemp = $100
> HIGH DAC_CE
> Lee
> wrote:
> > Sure...
> > -- Jon Williams
> > -- Dallas Office
Original Message
> > SHIFTOUT
> function?
> > Thanks,
> > Lee
Subject
> Yahoo! Groups Links
> abuse@p...
-- Jon Williams
-- Dallas Office
Original Message
From: huy_le123 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=pUp0p5WRO4OY3H_R8X0rY5rBq91uXoe5quFSX7f4qe-DA45DhuFIFvDui7Nv2CPq97HUGy4xJNIVXg]huy_le123@y...[/url
Sent: Wednesday, April 14, 2004 9:40 AM
SHIFTOUT
I'm using Basic Stamp 2p40 module. Thanks
Lee
> -- Jon Williams
> -- Dallas Office
Original Message
> SHIFTOUT
> DAC_CE CON 0
> DAC_DATA CON 1
> DAC_CLK CON 2
> wTemp VAR BYTE
> LOW DAC_CE
> wTemp = $100
> HIGH DAC_CE
> Lee
> wrote:
> > Sure...
> > -- Jon Williams
> > -- Dallas Office
Original Message
> > SHIFTOUT
> function?
> > Thanks,
> > Lee
Subject
> Yahoo! Groups Links
> abuse@p...
Yahoo! Groups Links
abuse@p....
driver from :
http://www.barcodemall.com/b14m04nr.html (please take a quick look at the
datasheet from this page).
Lee
--- In basicstamps@yahoogroups.com, "Jon Williams" <jwilliams@p...> wrote:
> We knew that part ... what are you trying to communicate with?
> -- Jon Williams
> -- Dallas Office
Original Message
> SHIFTOUT
> Lee
> > -- Jon Williams
> > -- Dallas Office
Original Message
> > SHIFTOUT
> > DAC_CE CON 0
> > DAC_DATA CON 1
> > DAC_CLK CON 2
> > wTemp VAR BYTE
> > LOW DAC_CE
> > wTemp = $100
> > HIGH DAC_CE
> > Lee
> > wrote:
> > > Sure...
> > > -- Jon Williams
> > > -- Dallas Office
Original Message
> > > SHIFTOUT
> > function?
> > > Thanks,
> > > Lee
> Subject
> > Yahoo! Groups Links
> > abuse@p...
> Yahoo! Groups Links
> abuse@p...
posted a fragment that I believe with work. Luckily, SHIFTOUT is very
flexible and can deal with the needs of this device. I believe this
will work for you (refer to the docs):
LOW CE
SHIFTOUT Dpin, Cpin, LSBFIRST, [noparse][[/noparse]1\1, segs0\8, segs1\8, segs2\8,
segs3\8, an1\1, an2\1, 0\1]
HIGH CE
The docs don't make clear if the start bit is supposed to be a 1 or 0,
so you may have to change the initial 1 in the output steam above to 0.
Note that the \8 additions are not required (the function defaults to
eight bits), I'm just doing it as good form to be absolutely clear. The
variables called segs0 - segs3 will contain the bit patterns for your
segments. You can use a LOOKUP table to convert a number into the
proper segment bit pattern.
-- Jon Williams
-- Dallas Office
Original Message
From: huy_le123 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=MKhFmI9IXYKs02AE2ARdNCrW61ivSqjJABWU0hJ86SDajhv-bBE9z61G1BCjd8HcXWGr1sv6uDGU]huy_le123@y...[/url
Sent: Wednesday, April 14, 2004 11:29 AM
SHIFTOUT
Sorry, i'm trying to comunicate with 4 digit 7 segment LED display with
Serial driver from :
the datasheet from this page).
Lee
> -- Jon Williams
> -- Dallas Office
Original Message
> SHIFTOUT
> Lee
> > -- Jon Williams
> > -- Dallas Office
Original Message
> > SHIFTOUT
> > DAC_CE CON 0
> > DAC_DATA CON 1
> > DAC_CLK CON 2
> > wTemp VAR BYTE
> > LOW DAC_CE
> > wTemp = $100
> > HIGH DAC_CE
> > Lee
> > wrote:
> > > Sure...
> > > -- Jon Williams
> > > -- Dallas Office
Original Message
> > > SHIFTOUT
> > function?
> > > Thanks,
> > > Lee
> Subject
> > Yahoo! Groups Links
> > abuse@p...
> Yahoo! Groups Links
> abuse@p...
Yahoo! Groups Links
abuse@p....
to say thank you and appreciate all the helps.
Lee
> Someone else was having trouble with that part back in January and I
> LOW CE
> HIGH CE
> -- Jon Williams
> -- Dallas Office
Original Message
> SHIFTOUT
> Thanks,
> Lee
> > -- Jon Williams
> > -- Dallas Office
Original Message
> > SHIFTOUT
> > Lee
> > > -- Jon Williams
> > > -- Dallas Office
Original Message
> > > SHIFTOUT
> > > DAC_CE CON 0
> > > DAC_DATA CON 1
> > > DAC_CLK CON 2
> > > wTemp VAR BYTE
> > > LOW DAC_CE
> > > wTemp = $100
> > > HIGH DAC_CE
> > > Lee
> > > wrote:
> > > > Sure...
> > > > -- Jon Williams
> > > > -- Dallas Office
Original Message
> > > > SHIFTOUT
> > > function?
> > > > Thanks,
> > > > Lee
> > Subject
> > > Yahoo! Groups Links
> > > abuse@p...
> > Yahoo! Groups Links
> > abuse@p...
> Yahoo! Groups Links
> abuse@p...
of source code in their documentation.
-- Jon Williams
-- Dallas Office
Original Message
From: huy_le123 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=0c-mXK-BDAvZLKcnjA5zp3GHPEMJ6KWuP6p5ON9bWD8f8yjdvtIndU3ev9Ti1Upb8v5xz_jgym9TK8Ng]huy_le123@y...[/url
Sent: Friday, April 16, 2004 11:26 AM
SHIFTOUT
I have tested it out with the way you suggested. It works great. I
would like to say thank you and appreciate all the helps.
Lee
> LOW CE
> HIGH CE
> 0. Note that the \8 additions are not required (the function defaults
> to eight bits), I'm just doing it as good form to be absolutely clear.
> The variables called segs0 - segs3 will contain the bit patterns for
> your segments. You can use a LOOKUP table to convert a number into
> the proper segment bit pattern.
> -- Jon Williams
> -- Dallas Office
Original Message
> SHIFTOUT
> with Serial driver from :
> Thanks,
> Lee
