convert 12 bit parallel to outputdata for SHIFTOUT — Parallax Forums
edited 2004-04-16 18:14 in General Discussion
How could I convert 12 bit parallel to OutputData for SHIFTOUT function?
Can I have a little example showing how to do that?
Lee
    edited 2004-04-14 00:36
    In a message dated 4/13/2004 7:33:59 PM Eastern Daylight Time,
    huy_le123@y... writes:
    The shiftout command will only handle bytes. If your variable is a word, you
    could shiftout variable.high byte, variable .lowbyte.
    Sid
    edited 2004-04-14 01:39
    Sure...
    SHIFTOUT Dpin, Cpin, Mode, [noparse][[/noparse]someData\12]
    This is covered in the manual (hint) and the help file (hint).
    -- Jon Williams
    -- Dallas Office
    From: huy_le123 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=ijSpI5qREiI3RptnyAG3FjsemKFfVPFnDVYOFypmdkFF4tGEsIL7Jg8MmMyktPUV-kww34hPq3ZrvUUT]huy_le123@y...[/url
    Sent: Tuesday, April 13, 2004 6:33 PM
    Subject: [noparse][[/noparse]basicstamps] convert 12 bit parallel to outputdata for
    SHIFTOUT
    Lee
    edited 2004-04-14 01:40
    Not so, Sid, SHIFTOUT can handle up to 16 bits. If you desire something
    other than 8 bits, then you must specify the bit count with the \
    parameter after the output data.
    SHIFTOUT Dpin, Cpin, Mode, [noparse][[/noparse]outputData\12]
    -- Jon Williams
    -- Dallas Office
    From: Newzed@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=jOWdEsJKfGmbr4yTroU-UrSy7YSUQMGYLzO3l1TygCLQnCoUuzNJWJm-uJzsBN1FkP5T2T8kAfc]Newzed@a...[/url
    Sent: Tuesday, April 13, 2004 6:36 PM
    Subject: Re: [noparse][[/noparse]basicstamps] convert 12 bit parallel to outputdata for
    SHIFTOUT
    > function?
    word, you
    Sid
    edited 2004-04-14 08:29
    Thanks a lot for your help.
    Another issue, there are 36 clocks required to clock all the data,
    but my data is only 8 bit. What can i do?
    here is little sample code i wrote to generate 8 clock pulses while
    writing each bit, but i need some helps to generate 36 clock pulse
    DAC_CE CON 0
    DAC_DATA CON 1
    DAC_CLK CON 2
    wTemp VAR BYTE
    LOW DAC_CE
    wTemp = $100
    SHIFTOUT DAC_DATA,DAC_CLK,msbfirst,[noparse][[/noparse]wTemp]
    HIGH DAC_CE
    I appreciate for your helps,
    Lee
    --- In basicstamps@yahoogroups.com, "Jon Williams" <jwilliams@p...>
    wrote:
    > Sure...
    > -- Jon Williams
    > -- Dallas Office
    > From: huy_le123 [noparse][[/noparse]mailto:huy_le123@y...]
    > SHIFTOUT
    function?
    > Thanks,
    > Lee
    edited 2004-04-14 14:17
    What device are you working with?
    -- Jon Williams
    -- Dallas Office
    From: huy_le123 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=cHlvsyf5kUNoSITjK6sSZEe8LDOkqDr3CoPrnLO_LJ9zZtQ4OFS6R2T-gyfe-k6IwMenyWz493j8TBo]huy_le123@y...[/url
    Sent: Wednesday, April 14, 2004 2:29 AM
    Subject: [noparse][[/noparse]basicstamps] Re: convert 12 bit parallel to outputdata for
    SHIFTOUT
    DAC_CE CON 0
    DAC_DATA CON 1
    DAC_CLK CON 2
    wTemp VAR BYTE
    LOW DAC_CE
    wTemp = $100
    HIGH DAC_CE
    Lee
    wrote:
    > Sure...
    > -- Jon Williams
    > -- Dallas Office
    > SHIFTOUT
    function?
    > Thanks,
    > Lee
    Yahoo! Groups Links
    This message has been scanned by WebShield. Please report SPAM to
    abuse@p....
    edited 2004-04-14 15:39
    I'm using Basic Stamp 2p40 module. Thanks
    Lee
    > -- Jon Williams
    > -- Dallas Office
    > SHIFTOUT
    > DAC_CE CON 0
    > DAC_DATA CON 1
    > DAC_CLK CON 2
    > wTemp VAR BYTE
    > LOW DAC_CE
    > wTemp = $100
    > HIGH DAC_CE
    > Lee
    > wrote:
    > > Sure...
    > > -- Jon Williams
    > > -- Dallas Office
    > > SHIFTOUT
    > function?
    > > Thanks,
    > > Lee
    Subject
    > Yahoo! Groups Links
    > abuse@p...
    edited 2004-04-14 17:08
    We knew that part ... what are you trying to communicate with?
    -- Jon Williams
    -- Dallas Office
    From: huy_le123 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=pUp0p5WRO4OY3H_R8X0rY5rBq91uXoe5quFSX7f4qe-DA45DhuFIFvDui7Nv2CPq97HUGy4xJNIVXg]huy_le123@y...[/url
    Sent: Wednesday, April 14, 2004 9:40 AM
    SHIFTOUT
    Lee
    > -- Jon Williams
    > -- Dallas Office
    > SHIFTOUT
    > DAC_CE CON 0
    > DAC_DATA CON 1
    > DAC_CLK CON 2
    > wTemp VAR BYTE
    > LOW DAC_CE
    > wTemp = $100
    > HIGH DAC_CE
    > Lee
    > wrote:
    > > Sure...
    > > -- Jon Williams
    > > -- Dallas Office
    > > SHIFTOUT
    > function?
    > > Thanks,
    > > Lee
    Subject
    > Yahoo! Groups Links
    > abuse@p...
    Yahoo! Groups Links
    abuse@p....
    edited 2004-04-14 17:29
    Sorry, i'm trying to comunicate with 4 digit 7 segment LED display with Serial
    driver from :
    http://www.barcodemall.com/b14m04nr.html (please take a quick look at the
    datasheet from this page).
    Lee
    > -- Jon Williams
    > -- Dallas Office
    > SHIFTOUT
    > Lee
    > > -- Jon Williams
    > > -- Dallas Office
    > > SHIFTOUT
    > > DAC_CE CON 0
    > > DAC_DATA CON 1
    > > DAC_CLK CON 2
    > > wTemp VAR BYTE
    > > LOW DAC_CE
    > > wTemp = $100
    > > HIGH DAC_CE
    > > Lee
    > > wrote:
    > > > Sure...
    > > > -- Jon Williams
    > > > -- Dallas Office
    > > > SHIFTOUT
    > > function?
    > > > Thanks,
    > > > Lee
    > Subject
    > > Yahoo! Groups Links
    > > abuse@p...
    > Yahoo! Groups Links
    > abuse@p...
    edited 2004-04-14 17:57
    Someone else was having trouble with that part back in January and I
    posted a fragment that I believe with work. Luckily, SHIFTOUT is very
    flexible and can deal with the needs of this device. I believe this
    will work for you (refer to the docs):
    LOW CE
    SHIFTOUT Dpin, Cpin, LSBFIRST, [noparse][[/noparse]1\1, segs0\8, segs1\8, segs2\8,
    segs3\8, an1\1, an2\1, 0\1]
    HIGH CE
    The docs don't make clear if the start bit is supposed to be a 1 or 0,
    so you may have to change the initial 1 in the output steam above to 0.
    Note that the \8 additions are not required (the function defaults to
    eight bits), I'm just doing it as good form to be absolutely clear. The
    variables called segs0 - segs3 will contain the bit patterns for your
    segments. You can use a LOOKUP table to convert a number into the
    proper segment bit pattern.
    -- Jon Williams
    -- Dallas Office
    From: huy_le123 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=MKhFmI9IXYKs02AE2ARdNCrW61ivSqjJABWU0hJ86SDajhv-bBE9z61G1BCjd8HcXWGr1sv6uDGU]huy_le123@y...[/url
    Sent: Wednesday, April 14, 2004 11:29 AM
    SHIFTOUT
    Serial driver from :
    the datasheet from this page).
    Lee
    > -- Jon Williams
    > -- Dallas Office
    > SHIFTOUT
    > Lee
    > > -- Jon Williams
    > > -- Dallas Office
    > > SHIFTOUT
    > > DAC_CE CON 0
    > > DAC_DATA CON 1
    > > DAC_CLK CON 2
    > > wTemp VAR BYTE
    > > LOW DAC_CE
    > > wTemp = $100
    > > HIGH DAC_CE
    > > Lee
    > > wrote:
    > > > Sure...
    > > > -- Jon Williams
    > > > -- Dallas Office
    > > > SHIFTOUT
    > > function?
    > > > Thanks,
    > > > Lee
    > Subject
    > > Yahoo! Groups Links
    > > abuse@p...
    > Yahoo! Groups Links
    > abuse@p...
    Yahoo! Groups Links
    abuse@p....
    edited 2004-04-16 17:25
    I have tested it out with the way you suggested. It works great. I would like
    to say thank you and appreciate all the helps.
    Lee
    > LOW CE
    > HIGH CE
    > -- Jon Williams
    > -- Dallas Office
    > SHIFTOUT
    > Thanks,
    > Lee
    > > -- Jon Williams
    > > -- Dallas Office
    > > SHIFTOUT
    > > Lee
    > > > -- Jon Williams
    > > > -- Dallas Office
    > > > SHIFTOUT
    > > > DAC_CE CON 0
    > > > DAC_DATA CON 1
    > > > DAC_CLK CON 2
    > > > wTemp VAR BYTE
    > > > LOW DAC_CE
    > > > wTemp = $100
    > > > HIGH DAC_CE
    > > > Lee
    > > > wrote:
    > > > > Sure...
    > > > > -- Jon Williams
    > > > > -- Dallas Office
    > > > > SHIFTOUT
    > > > function?
    > > > > Thanks,
    > > > > Lee
    > > Subject
    > > > Yahoo! Groups Links
    > > > abuse@p...
    > > Yahoo! Groups Links
    > > abuse@p...
    > Yahoo! Groups Links
    > abuse@p...
    You're welcome. Perhaps you could encourage the vendor to include a bit
    of source code in their documentation.
    -- Jon Williams
    -- Dallas Office
    From: huy_le123 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=0c-mXK-BDAvZLKcnjA5zp3GHPEMJ6KWuP6p5ON9bWD8f8yjdvtIndU3ev9Ti1Upb8v5xz_jgym9TK8Ng]huy_le123@y...[/url
    Sent: Friday, April 16, 2004 11:26 AM
    SHIFTOUT
    would like to say thank you and appreciate all the helps.
    Lee
    > LOW CE
    > HIGH CE
    > 0. Note that the \8 additions are not required (the function defaults
    > to eight bits), I'm just doing it as good form to be absolutely clear.
    > The variables called segs0 - segs3 will contain the bit patterns for
    > your segments. You can use a LOOKUP table to convert a number into
    > the proper segment bit pattern.
    > -- Jon Williams
    > -- Dallas Office
    > SHIFTOUT
    > with Serial driver from :
    > Thanks,
    > Lee
