solenoid valve at 12v
Hi
I am new to all of this and I want to use a BS2 to control a solenoid valve at
12v.
What do I need to interface it with the BOE since it is at 5v?
Help
Kevin
12v.
Help
Kevin
the mean time a no brainer solution is get a MOSFET......IRL520.
Connect stamp output directly to the GATE
Connect 1 meg from the GATE to ground
Connect the SOURCE to ground
Connect the DRAIN to the solenoid minus terminal
Connect the solenoid positive terminal to 12 volts
DONE.......overkill but DONE....ie....no brainer
see www.glitchbuster.com
I am not affiliated with glitch buster at all, but inexpensive shipping.
ken
Hi
at
12v.
Help
Kevin
The no brainer solution is almost there but left off what I believe to
be one critical component to prevent the inductive kick from the
solonoid coil from killing your MOSFET. You need to add a garden
variety power diode (ie, 1N4001....4005) reverse biased across the
solonoid coil, or from drain to source.
Case 1: diode anode to Drain, cathode to +12Volts
Case 2: diode anote to (source)ground, diode cathode to Drain
Either one should keep your MOSFET from going west the first time you
release the solonoid.
Call this the "brainer" solution. Actually, it comes from years of
experience. Have fun.
Horace
--- In basicstamps@yahoogroups.com, smartdim@a... wrote:
> I am SURE someplace in one of the parallax tutorials this is
covered.....In
shipping.
> ken
> Hi
solenoid valve
> at
> 12v.
> Help
> Kevin
Regarding case 2, it is intrinsic to the IRL520. Diode is built in to the
IRL520, anode to source and cathode to drain.
Case 1 is the prefered method IMHO
Ken\
Horace
Looks like I spoke too quickly. I just looked up specs for the IRL520
MOSFET and found that they have already built in the diode (case2)
right into the FET so that you don't need to add an external one. In
the old days, to go without the diode was circuit suicide, but it is
becoming much more common to see them added internal to the device
itself as a self protection feature. I found specs at:
http://www.fairchildsemi.com/ds/IR/IRL520A.pdf
The reason for the diode is as I stated. It gives the current in the
solonoid coil a place to go once you turn off the FET. Remember, laws
of physics says you can't instantly change current through an inductor
(the coil). This gives the current a path throught the diode and lets
it drop gradually to zero without developing a giant reverse voltage
spike that can damage devices. Anyway, score 1 for no-brainer!
Horace
--- In basicstamps@yahoogroups.com, "xibm65" <cce@t...> wrote:
> Kevin,
> or
> Horace
> covered.....In
> shipping.
> > ken
> > Hi
> solenoid valve
> > at
> > 12v.
> > Help
> > Kevin
Thanks for all the info.
Kevin
> Kevin, Ken,
> Horace
> > Kevin,
> > or
> > Horace
> > covered.....In
> > shipping.
> > > ken
> > > Hi
> > solenoid valve
> > > at
> > > 12v.
> > > Help
> > > Kevin
My first question is what is the current ? AC or DC ?
All the responses have been for DC solenoids.
Second, is the resistance of the coil of the unit ?
I have some 1.5 watt solenoids. 12 volts, 1.5 watts is near 700 mA
and is way too much for a PN2222.
I have relays that pull closer to 200mA.
Also, depending on how often you change state of the coil, a coil
for a solenoid or relay will use one current to operate and another
to hold. Typically, half the rating is needed to hold the coil in
posistion. Overheating of the semi may occur over time, but for
short bursts a lower rated device might get you by.
Here you are subject to manufacturinrs claims and spec sheets. One
may rate the coil for holding current, another for actuation current.
I've been successful on temporary project to use the 2222 for much
larger coils than they should handle, but would use a higher rated
MOSFET if putting out a full circuit of more than just testing.
Dave
> Kevin, Ken,
IRL520
laws
inductor
lets
> Horace
> > Kevin,
believe to
> > or
you
> > Horace
> > covered.....In
> > shipping.
> > > ken
> > > Hi
> > solenoid valve
> > > at
> > > 12v.
> > > Help
> > > Kevin
the solenoid valve is 12v dc and says watt rating 6.9/F
made by www.ascovalve.com
part U8225B2V/DC
Kevin
--- In basicstamps@yahoogroups.com, "Dave Mucha" <davemucha@j...> wrote:
> Hi Kevin,
> Dave
> > Kevin, Ken,
> IRL520
> laws
> inductor
> lets
> > Horace
> > > Kevin,
> believe to
> > > or
> you
> > > Horace
> > > covered.....In
> > > shipping.
> > > > ken
> > > > Hi
> > > solenoid valve
> > > > at
> > > > 12v.
> > > > Help
> > > > Kevin
> HI Dave
> part U8225B2V/DC
> Thanks
> Kevin
12VDC @ 7 watts is 580mA or a tad too high for a PN2222 with a 500mA
rating.
For testing (while waiting for the MOSFETS to arrive) I would use a
PN2222.
for a final curcuit, use the MOSFETS listed or even a TIP120 (122?)
that also has an internal diode.
Dave
wrote:
> > Hi Kevin,
mA
coil
another
in
One
current.
much
rated
> > Dave
> > > Kevin, Ken,
> > IRL520
(case2)
one. In
it is
device
in the
Remember,
> > laws
> > inductor
and
> > lets
voltage
> > > Horace
> > > > Kevin,
> > believe to
the
garden
across the
> > > > or
time
> > you
years of
> > > > Horace
> > > > covered.....In
MOSFET......IRL520.
inexpensive
> > > > shipping.
> > > > > ken
> > > > > Hi
> > > > solenoid valve
> > > > > at
> > > > > 12v.
5v?
> > > > > Help
> > > > > Kevin
