solenoid valve at 12v — Parallax Forums
edited 2004-03-13 19:51 in General Discussion
Hi
I am new to all of this and I want to use a BS2 to control a solenoid valve at
12v.
What do I need to interface it with the BOE since it is at 5v?
Help
Kevin
    edited 2004-03-13 16:03
    I am SURE someplace in one of the parallax tutorials this is covered.....In
    the mean time a no brainer solution is get a MOSFET......IRL520.
    Connect stamp output directly to the GATE
    Connect 1 meg from the GATE to ground
    Connect the SOURCE to ground
    Connect the DRAIN to the solenoid minus terminal
    Connect the solenoid positive terminal to 12 volts
    DONE.......overkill but DONE....ie....no brainer
    see www.glitchbuster.com
    I am not affiliated with glitch buster at all, but inexpensive shipping.
    ken
    Hi
    at
    12v.
    Help
    Kevin
    edited 2004-03-13 16:31
    Kevin,
    The no brainer solution is almost there but left off what I believe to
    be one critical component to prevent the inductive kick from the
    solonoid coil from killing your MOSFET. You need to add a garden
    variety power diode (ie, 1N4001....4005) reverse biased across the
    solonoid coil, or from drain to source.
    Case 1: diode anode to Drain, cathode to +12Volts
    Case 2: diode anote to (source)ground, diode cathode to Drain
    Either one should keep your MOSFET from going west the first time you
    release the solonoid.
    Call this the "brainer" solution. Actually, it comes from years of
    experience. Have fun.
    Horace
    covered.....In
    shipping.
    > ken
    > Hi
    solenoid valve
    > at
    > 12v.
    > Help
    > Kevin
    edited 2004-03-13 17:01
    Horace brings up an important and very valid point.
    Regarding case 2, it is intrinsic to the IRL520. Diode is built in to the
    IRL520, anode to source and cathode to drain.
    Case 1 is the prefered method IMHO
    Ken\
    Horace
    edited 2004-03-13 17:07
    Kevin, Ken,
    Looks like I spoke too quickly. I just looked up specs for the IRL520
    MOSFET and found that they have already built in the diode (case2)
    right into the FET so that you don't need to add an external one. In
    the old days, to go without the diode was circuit suicide, but it is
    becoming much more common to see them added internal to the device
    itself as a self protection feature. I found specs at:
    http://www.fairchildsemi.com/ds/IR/IRL520A.pdf
    The reason for the diode is as I stated. It gives the current in the
    solonoid coil a place to go once you turn off the FET. Remember, laws
    of physics says you can't instantly change current through an inductor
    (the coil). This gives the current a path throught the diode and lets
    it drop gradually to zero without developing a giant reverse voltage
    spike that can damage devices. Anyway, score 1 for no-brainer!
    Horace
    --- In basicstamps@yahoogroups.com, "xibm65" <cce@t...> wrote:
    > Kevin,
    > or
    > Horace
    > covered.....In
    > shipping.
    > > ken
    > > Hi
    > solenoid valve
    > > at
    > > 12v.
    > > Help
    > > Kevin
    edited 2004-03-13 17:22
    Hi
    Thanks for all the info.
    Kevin
    > Kevin, Ken,
    > Horace
    > > Kevin,
    > > or
    > > Horace
    > > covered.....In
    > > shipping.
    > > > ken
    > > > Hi
    > > solenoid valve
    > > > at
    > > > 12v.
    > > > Help
    > > > Kevin
    edited 2004-03-13 17:58
    Hi Kevin,
    My first question is what is the current ? AC or DC ?
    All the responses have been for DC solenoids.
    Second, is the resistance of the coil of the unit ?
    I have some 1.5 watt solenoids. 12 volts, 1.5 watts is near 700 mA
    and is way too much for a PN2222.
    I have relays that pull closer to 200mA.
    Also, depending on how often you change state of the coil, a coil
    for a solenoid or relay will use one current to operate and another
    to hold. Typically, half the rating is needed to hold the coil in
    posistion. Overheating of the semi may occur over time, but for
    short bursts a lower rated device might get you by.
    Here you are subject to manufacturinrs claims and spec sheets. One
    may rate the coil for holding current, another for actuation current.
    I've been successful on temporary project to use the 2222 for much
    larger coils than they should handle, but would use a higher rated
    MOSFET if putting out a full circuit of more than just testing.
    Dave
    > Kevin, Ken,
    IRL520
    laws
    inductor
    lets
    > Horace
    > > Kevin,
    believe to
    > > or
    you
    > > Horace
    > > covered.....In
    > > shipping.
    > > > ken
    > > > Hi
    > > solenoid valve
    > > > at
    > > > 12v.
    > > > Help
    > > > Kevin
    edited 2004-03-13 19:15
    HI Dave
    the solenoid valve is 12v dc and says watt rating 6.9/F
    made by www.ascovalve.com
    part U8225B2V/DC
    Kevin
    --- In basicstamps@yahoogroups.com, "Dave Mucha" <davemucha@j...> wrote:
    > Hi Kevin,
    > Dave
    > > Kevin, Ken,
    > IRL520
    > laws
    > inductor
    > lets
    > > Horace
    > > > Kevin,
    > believe to
    > > > or
    > you
    > > > Horace
    > > > covered.....In
    > > > shipping.
    > > > > ken
    > > > > Hi
    > > > solenoid valve
    > > > > at
    > > > > 12v.
    > > > > Help
    > > > > Kevin
    --- In basicstamps@yahoogroups.com, "Kev" <kevinhjones@h...> wrote:
    > HI Dave
    > part U8225B2V/DC
    > Thanks
    > Kevin
    12VDC @ 7 watts is 580mA or a tad too high for a PN2222 with a 500mA
    rating.
    For testing (while waiting for the MOSFETS to arrive) I would use a
    PN2222.
    for a final curcuit, use the MOSFETS listed or even a TIP120 (122?)
    that also has an internal diode.
    Dave
    wrote:
    > > Hi Kevin,
    mA
    coil
    another
    in
    One
    current.
    much
    rated
    > > Dave
    > > > Kevin, Ken,
    > > IRL520
    (case2)
    one. In
    it is
    device
    in the
    Remember,
    > > laws
    > > inductor
    and
    > > lets
    voltage
    > > > Horace
    > > > > Kevin,
    > > believe to
    the
    garden
    across the
    > > > > or
    time
    > > you
    years of
    > > > > Horace
    > > > > covered.....In
    MOSFET......IRL520.
    inexpensive
    > > > > shipping.
    > > > > > ken
    > > > > > Hi
    > > > > solenoid valve
    > > > > > at
    > > > > > 12v.
    5v?
    > > > > > Help
    > > > > > Kevin
