access to the reset pin
I've got a BS2P40 with the P40 professional demo board. Is there
anywhere on the board where I can tap into the RESET pin on the stamp
so I can reset it with an off-board switch?
-- Jon Williams
-- Parallax
Original Message
From: andy_watson5 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=54GIfvA08lx0u63WqJMD255Yf2kVirm3oEoE4OPmJ63TuOdPh1oKNicyl-JHq3h58q0DRjYYw7x_y_tDcmQ]andywatson@m...[/url
Sent: Thursday, February 26, 2004 2:52 PM
To: basicstamps@yahoogroups.com
Subject: [noparse][[/noparse]basicstamps] access to the reset pin
improvise. That's half the fun of designing anyway... [noparse]:)[/noparse]
--- In basicstamps@yahoogroups.com, "Jon Williams" <jwilliams@p...>
wrote:
> There is not *easy* way to do it (no wire socket like for other
IOs).
> -- Jon Williams
> -- Parallax
Original Message
> From: andy_watson5 [noparse][[/noparse]mailto:andywatson@m...]
stamp
reset pin via an inverting transistor. You can thus do a reset by
bringing DTR high on a PC, or do the same thing an external switch.
There might be some interaction if both a PC and a switch are active
at the same time. Some of the Parallax development boards have
capacitors between DB9 pin 4 and the Reset transistor, but I don't
know if that is true of the BS2p pro demo board. One way or the
other, it just changes the circuit picture a little.
By the way, notice that on the Debug screen, there is a check box to
set the state of the DTR line. You can use that during your
development to cause a reset.
-- Tracy
-- Tracy
>Hmmm. Okay, thanks for the info. Looks like I'll have to
>IOs).
>> -- Jon Williams
>> -- Parallax
Original Message
>stamp
demo board, isn't it? You could tap the reset line from the contacts
of the reset switch.
Regards
Adrian
but it works fine.
--- In basicstamps@yahoogroups.com, "Adrian Schneider"
<adrian.schneider@t...> wrote:
> Besides what Tracy mentionned, I think there is a reset button on
the
contacts
> Regards
> Adrian
