Stamp not responding......
--- In basicstamps@yahoogroups.com, "stepheee24" <stepheee24@y...>
wrote:
> Hi Everyone -
> My editor no longer detects my basic stamp module. I accidentally
> dropped the BOE bot from about 5 inches above my desk. When it
> fell, one of the batteries fell out. I accidentally stuck the
> battery back in the wrong way and tried to turn it on. That, of
> course, didn't work, so I realized the battery was in wrong and
> connected it correctly. Now, when I plug the battery back in, my
> green LED comes on, indicating there is power. However, when
> plugged in through the serial port, I get the "no basic stamps
> found" error. Do you think that I messed up the basic stamp when I
> dropped it or fried it somehow in this whole process? I'm just not
> sure how to troubleshoot this.
> Thanks,
> Stephanie Liese
I would check everything that might have loosened or shorted.
I assume that a 5" fall would not shake out any of the smoke, but a
few minutes of poking with a multi-meter should reveal if things that
are supposed to get power do, and things that are not supposed to do
not.
Dave
wrote:
> Hi Everyone -
> Thanks,
> Stephanie Liese
not.
Dave
desk and tumbled around with a few other small items. Initially there
appeared to be no damage (pins not bent, etc.) and I really didn't expect
any -- it wasn't that severe. However, "no Stamp found" was the result.
Upon *very close* inspection, it turned out that one of the tiny surface
mount transistors associated with the serial communication had been knocked
off and was missing.
At the time I wasn't comfortable doing those SOT surface mount transistors
so I called Parallax to see if they would repair it for a bit less than
their normal "cancelled Stamp" exchange price. As usual, they were a
pleasure to deal with, and my BS2 is still working fine today.
Randy
www.glitchbuster.com
> wrote:
> > Hi Everyone -
> > Thanks,
> > Stephanie Liese
> not.
> Dave
> wrote:
> > Hi Everyone -
accidentally
I
not
> > Thanks,
> > Stephanie Liese
that
do
> not.
> Dave
> wrote:
> > Hi Everyone -
accidentally
I
not
> > Thanks,
> > Stephanie Liese
that
do
> not.
> Dave
> wrote:
> > Hi Everyone -
accidentally
I
not
> > Thanks,
> > Stephanie Liese
that
do
> not.
> Dave
last night and after a little troubleshooting we found that the
problem was low batteries. There wasn't an indication of this before
the fall, so I was a little confused. At least it's up and running
now [noparse]:)[/noparse]
--- In basicstamps@yahoogroups.com, "Dave Mucha" <davemucha@j...>
> wrote:
> > Hi Everyone -
accidentally
I
not
> > Thanks,
> > Stephanie Liese
that
do
> not.
> Dave
