Interfacing a Serial Port Enabled DMM with a Basic Stamp
I am building a test box that uses a BS2P40 microcontroller. I
purchased a Metex DMM with a serial port. The Metex meter does an
excellent job of communicating with a PC when used in conjunction
with the interface software provided with the meter. [noparse][[/noparse]So good, I
would like to ask the following question...]
Does anyone in this group have any experience interfacing a serial
port enabled DMM with a Basic Stamp? If so, I would like to ask for
some amplifying details.
I am hoping to use the meter for running a calibration routine on the
test box and any ideas would be greatly appreciated.
Thank you for your help.
Eric in Japan
Eric in Japan
PC interface. the software works fine even under Windows 2000. the problem
is, the DMM uses a odd protocol of 600 baud 7 bits, no parity, 2 stop bits.
I can't figure out how to setup the BS2 to read that protocol. anyone have
any ideas? I checked the help file but it doesn't mention how to configure
the stop bits.
ummm, just now thought about it. since the DMM data word is 14 bytes if
there is no way to do it using SERIN then maybe I could just us SHIFTIN to
clock in 14 bytes
>Eric in Japan
>To UNSUBSCRIBE, just send mail to:
>from the same email address that you subscribed. Text in the Subject and
>Body of the message will be ignored.
>Yahoo! Groups Links
>To visit your group on the web, go to:
> http://groups.yahoo.com/group/basicstamps/
>To unsubscribe from this group, send an email to:
>Your use of Yahoo! Groups is subject to:
> http://docs.yahoo.com/info/terms/
Try this:
You can calculate 600 baud with the appropiate fornulae for your BS.
You can treat the 7,N,2 as 8,N,1 because a stopbit is a logical 0.
This means shifting all command codes 1 bit to the left before sending
them to the DMM. Whatever you read from the DMM must then shift
1 bit to the right to get the proper response codes.
success.
regards peter
Original Message
To: <basicstamps@yahoogroups.com>
Sent: Wednesday, February 04, 2004 5:02 AM
Subject: Re: [noparse][[/noparse]basicstamps] Interfacing a Serial Port Enabled DMM with a
Basic Stamp
> I am having a similar problem. I have a Radio Shack DMM (cat # 22-805)
with
problem
bits.
configure
> the stop bits.
> clock in 14 bytes
> >Eric in Japan
> >Yahoo! Groups Links
> Yahoo! Groups Links
I'll try something like that.
thanks
At 12:39 AM 2/4/2004, you wrote:
>Daryl,
>Try this:
>success.
>regards peter
Original Message
>From: "Daryl Berryhill" <djberry@h...>
>Basic Stamp
>with
>problem
>bits.
>configure
> > the stop bits.
> > clock in 14 bytes
> > >Eric in Japan
> > >Yahoo! Groups Links
> > Yahoo! Groups Links
>Yahoo! Groups Links
i beleave it draws power from the interface from dtr
rts i never got it going with just the three
> DMM (cat # 22-805) with
> the stop bits.
> word is 14 bytes if
> clock in 14 bytes
> microcontroller. I
> Metex meter does an
> in conjunction
> appreciated.
> >Eric in Japan
> >Yahoo! Groups Links
> Text in the Subject and Body of the message will be
> ignored.
> Yahoo! Groups Links
__________________________________
Do you Yahoo!?
Yahoo! SiteBuilder - Free web site building tool. Try it!
http://webhosting.yahoo.com/ps/sb/
