Interfacing a Serial Port Enabled DMM with a Basic Stamp — Parallax Forums
edited 2004-02-04 19:45 in General Discussion
I am building a test box that uses a BS2P40 microcontroller. I
purchased a Metex DMM with a serial port. The Metex meter does an
excellent job of communicating with a PC when used in conjunction
with the interface software provided with the meter. [noparse][[/noparse]So good, I
would like to ask the following question...]
Does anyone in this group have any experience interfacing a serial
port enabled DMM with a Basic Stamp? If so, I would like to ask for
some amplifying details.
I am hoping to use the meter for running a calibration routine on the
test box and any ideas would be greatly appreciated.
Thank you for your help.
Eric in Japan
    edited 2004-02-04 04:02
    I am having a similar problem. I have a Radio Shack DMM (cat # 22-805) with
    PC interface. the software works fine even under Windows 2000. the problem
    is, the DMM uses a odd protocol of 600 baud 7 bits, no parity, 2 stop bits.
    I can't figure out how to setup the BS2 to read that protocol. anyone have
    any ideas? I checked the help file but it doesn't mention how to configure
    the stop bits.
    ummm, just now thought about it. since the DMM data word is 14 bytes if
    there is no way to do it using SERIN then maybe I could just us SHIFTIN to
    clock in 14 bytes
    >Eric in Japan
    >from the same email address that you subscribed. Text in the Subject and
    >Body of the message will be ignored.
    >Yahoo! Groups Links
    >To visit your group on the web, go to:
    > http://groups.yahoo.com/group/basicstamps/
    >To unsubscribe from this group, send an email to:
    >Your use of Yahoo! Groups is subject to:
    edited 2004-02-04 06:39
    Daryl,
    Try this:
    You can calculate 600 baud with the appropiate fornulae for your BS.
    You can treat the 7,N,2 as 8,N,1 because a stopbit is a logical 0.
    This means shifting all command codes 1 bit to the left before sending
    them to the DMM. Whatever you read from the DMM must then shift
    1 bit to the right to get the proper response codes.
    success.
    regards peter
    Sent: Wednesday, February 04, 2004 5:02 AM
    Subject: Re: [noparse][[/noparse]basicstamps] Interfacing a Serial Port Enabled DMM with a
    Basic Stamp
    with
    problem
    bits.
    configure
    > the stop bits.
    > clock in 14 bytes
    > >Eric in Japan
    > >Yahoo! Groups Links
    > Yahoo! Groups Links
    edited 2004-02-04 12:11
    Wow, thats being creative. never thought about protocol conversion before.
    I'll try something like that.
    thanks
    At 12:39 AM 2/4/2004, you wrote:
    >Daryl,
    >Try this:
    >success.
    >regards peter
    >From: "Daryl Berryhill" <djberry@h...>
    >Basic Stamp
    >with
    >problem
    >bits.
    >configure
    > > the stop bits.
    > > clock in 14 bytes
    > > >Eric in Japan
    > > >Yahoo! Groups Links
    > > Yahoo! Groups Links
    >Yahoo! Groups Links
    hello has anyone got it to work with three wires
    i beleave it draws power from the interface from dtr
    rts i never got it going with just the three
    > the stop bits.
    > word is 14 bytes if
    > clock in 14 bytes
    > microcontroller. I
    > Metex meter does an
    > in conjunction
    > appreciated.
    > >Eric in Japan
    > >Yahoo! Groups Links
    > Text in the Subject and Body of the message will be
    > ignored.
    > Yahoo! Groups Links
    __________________________________
    Do you Yahoo!?
    Yahoo! SiteBuilder - Free web site building tool. Try it!
    http://webhosting.yahoo.com/ps/sb/
