RF for communicating between Stamp and PC?
Does anyone have any ideas/suggestions on using RF transceivers to
communicate between a Stamp (Javelin preferably) and a PC?
Russ
Russ
implement all the protocols.
Or you can check Chipcon.com if you want to use serial IO only. Manchester
in hardware is done.
Antonio Sergio Sena
> Russ
I'm using the Parallax A/7 Bluetooth eb500 transceiver to communicate
between a Stamp (Boe-Bot, with a BS2), and my pc. On the pc I have a
Bluetooth wireless USB adapter. The Bluetooth USB adapters are usually
available at stores that sell computers.
I just started using the Bluetooth transceivers. So far, I have the Boe-Bot
running on remote control. Right now I'm working on the Boe-Bot sending the
pc information from the IR sensors. If I get that to work, I'm going to
order a Parallax Devantech SRF04 Ultrasonic Range Finder and see if I can
get the pc to control the Boe-Bot using data from the Range Finder.
Steve
______
Original Message
To: <basicstamps@yahoogroups.com>
Sent: Saturday, January 31, 2004 9:37 AM
Subject: [noparse][[/noparse]basicstamps] RF for communicating between Stamp and PC?
> Russ
> To UNSUBSCRIBE, just send mail to:
> from the same email address that you subscribed. Text in the Subject and
> Yahoo! Groups Links
> To visit your group on the web, go to:
> http://groups.yahoo.com/group/basicstamps/
> To unsubscribe from this group, send an email to:
> Your use of Yahoo! Groups is subject to:
> http://docs.yahoo.com/info/terms/
> Hello Russ,
Boe-Bot
sending the
I can
> Steve
> ______
Original Message
> From: "russranshaw" <home.rr@c...>
> > Russ
Subject and
> > Yahoo! Groups Links
Thanks, Steve!
I looked for the eb600 on the Parallax site and didn't find it. What
is it and where do I buy it?
My application requires that I communicate between my PC in one part
of the house with a system in the basement. I could run a cable, but
that could be a problem for long-term use withoug tearing up the walls!
So, what I actually need to do is communicate with something other
than the Javelin. It is a piece of electrical gear that has an RS232
port which communicates with their own "remote monitor panel".
My ultimate goal is to have the Javelin actually monitor the gear and
in fact to control it. To do this I have to uncover the protocol used
by the gear to communicate with the remote monitor. (The company has
steadfastly refused my requests for the protocol.)
Toward this end I will write a program that watches the RS232 traffic
using two ports on the pc.
Russ
Sounds like an interesting project!
On the Parallax web site the Bluetooth EmbeddedBlue eb500 Tansceiver AppMod
is:
http://www.parallax.com/detail.asp?product_id=30068
(or, under PRODUCTS, choose Accessories, and then Communications and RF)
Steve
_______
Original Message
Sent: Saturday, January 31, 2004 1:48 PM
Subject: [noparse][[/noparse]basicstamps] Re: RF for communicating between Stamp and PC?
> --- In basicstamps@yahoogroups.com, "Steve Nelick" <s.nelick@v...> wrote:
> > Hello Russ,
> Boe-Bot
> sending the
> I can
> > Steve
> > ______
Original Message
> > > Russ
> Subject and
> > > Yahoo! Groups Links
> Thanks, Steve!
> Russ
> Yahoo! Groups Links
A company called Wireless Cables Inc sells a bluetooth ready wireless RS232
solution called AirCable for $129.00.
http://www.aircable.net/
Serial to serial is the one I think you are after.
I've had one running for a couple of months with no problems. Each end comes
with it's own power module to plug into 120vac.
Dennis
Houston
In a message dated 2/1/04 9:15:04 AM Central Standard Time,
basicstamps@yahoogroups.com writes:
> Message: 3
> Date: Sat, 31 Jan 2004 18:48:17 -0000
> Subject: Re: RF for communicating between Stamp and PC?
> Thanks, Steve!
> Russ
