Freqout
Hi all,
I'm looking for some data on FreqOut
I noticed there was an article on it, but cannot find the article.
Maybe I'm just having a bad day searching, but can someone point me
towards more information regarding FreqOut ?
Dave
(not Freq'in Out yet)
Dave
and click on INDEX. type FREQOUT
this should help somewhat...
At 07:34 PM 1/29/2004 +0000, you wrote:
>Hi all,
>Dave
>To UNSUBSCRIBE, just send mail to:
>from the same email address that you subscribed. Text in the Subject and
>Body of the message will be ignored.
>Yahoo! Groups Links
>To visit your group on the web, go to:
> http://groups.yahoo.com/group/basicstamps/
>To unsubscribe from this group, send an email to:
>Your use of Yahoo! Groups is subject to:
> http://docs.yahoo.com/info/terms/
davemucha@j... writes:
What do you want to know, Dave.
Sid
> In a message dated 1/29/2004 6:38:56 PM Eastern Standard Time,
me
> Sid
There was a nut-n-volts article that went in-depth on FreqOut. I
have not used this command and wanted more information on it for a
project that might benefit from it's use.
Dave
for a certain time. Typical values (BS2)
are 40 KHz for 1 mSec. BS2sx can send
shorter amounts of time (400 uSec).
The BS2p can send even shorter times.
This is useful for:
1. Outputting SONY IR pulses (40 KHz for
1.2 mSec is a '1', 600 uSec is a '0')
2. Sound.
3. Using their IR board as a simple ranging
system. It turns out a 40 kHz receiver has
different sensitivities when receiving
36 KHz, 38 KHz, etc. So you can send 4
pulses at different frequencies, and sample
the IR Reciever to see if it triggered.
4. 'Bot to 'Bot communication. One Bot can
send a 1 mS 40 Khz Freqout out an IR LED.
The other 'Bot can recieve this on a 40 KHz
IR reciever using 'PULSIN' to determine the length
of the pulse. You then use long (1 mSec) and
short (2 mSec) pulses to send data.
--- In basicstamps@yahoogroups.com, "Dave Mucha" <davemucha@j...>
point
> me
> > Sid
> Dave
