Freqout — Parallax Forums
Freqout
edited 2004-01-30 13:10 in General Discussion
Hi all,
I'm looking for some data on FreqOut
I noticed there was an article on it, but cannot find the article.
Maybe I'm just having a bad day searching, but can someone point me
towards more information regarding FreqOut ?
Dave
(not Freq'in Out yet)
    edited 2004-01-29 19:48
    Did you try the help menu of the basic stamp editor. launch the help menu
    and click on INDEX. type FREQOUT
    this should help somewhat...
    At 07:34 PM 1/29/2004 +0000, you wrote:
    >Hi all,
    >Dave
    >from the same email address that you subscribed. Text in the Subject and
    >Body of the message will be ignored.
    >Yahoo! Groups Links
    >To visit your group on the web, go to:
    > http://groups.yahoo.com/group/basicstamps/
    >To unsubscribe from this group, send an email to:
    >Your use of Yahoo! Groups is subject to:
    edited 2004-01-29 23:42
    In a message dated 1/29/2004 6:38:56 PM Eastern Standard Time,
    davemucha@j... writes:
    What do you want to know, Dave.
    Sid
    edited 2004-01-30 03:45
    me
    > Sid
    There was a nut-n-volts article that went in-depth on FreqOut. I
    have not used this command and wanted more information on it for a
    project that might benefit from it's use.
    Dave
    Freqout lets you send a certain frequency
    for a certain time. Typical values (BS2)
    are 40 KHz for 1 mSec. BS2sx can send
    shorter amounts of time (400 uSec).
    The BS2p can send even shorter times.
    This is useful for:
    1. Outputting SONY IR pulses (40 KHz for
    1.2 mSec is a '1', 600 uSec is a '0')
    2. Sound.
    3. Using their IR board as a simple ranging
    system. It turns out a 40 kHz receiver has
    different sensitivities when receiving
    36 KHz, 38 KHz, etc. So you can send 4
    pulses at different frequencies, and sample
    the IR Reciever to see if it triggered.
    4. 'Bot to 'Bot communication. One Bot can
    send a 1 mS 40 Khz Freqout out an IR LED.
    The other 'Bot can recieve this on a 40 KHz
    IR reciever using 'PULSIN' to determine the length
    of the pulse. You then use long (1 mSec) and
    short (2 mSec) pulses to send data.
    --- In basicstamps@yahoogroups.com, "Dave Mucha" <davemucha@j...>
    point
    > me
    > > Sid
    > Dave
