O/S and the Stamp(2)
So im going to need A SBC to run the Windows CE O/S Why not just use the
I/O off the SBC Serial and parallel Ports From the SBC, Why even
Include
The basic Stamp,,
Original Message
From: Allan Lane [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=ZEaezHzuWLQTxPvlS3bzwbmOHTQ3v2kwFREJ981XqLiDbc8u0ZVt0p5eln4NpwRBDYR1z1iFY--Qhlz9VJS04jwylQ]allan.lane@h...[/url
Sent: Tuesday, January 20, 2004 10:22 AM
To: basicstamps@yahoogroups.com
Subject: [noparse][[/noparse]basicstamps] Re: O/S and the Stamp
The BS2 contains its own pseudo-OS in the form
of its run-time code. As mentioned earlier, you
can easily interface its RS-232 port with a
larger platform -- in Files, AlDemo\BS2_VBDemo.zip
I have a complete small demo which does this
for the PC using Visual Basic 6.
You can easily do the same for WinCE, I assume.
The BS2 is such a small beast, it's really good
for doing small microprocessor interface things.
A full disk-based operating system for it would
be way overkill.
--- In basicstamps@yahoogroups.com, "Brian E Boothe" <subrian@m...>
wrote:
> Wondering if the Basic Stamp Can be Joined With the WindowsCE
Operating
> System, or if there are Operating Systems Built around the Basic
Stamp.
> Some sort of Custom O.S
To UNSUBSCRIBE, just send mail to:
basicstamps-unsubscribe@yahoogroups.com
from the same email address that you subscribed. Text in the Subject
and Body of the message will be ignored.
Yahoo! Groups Links
To visit your group on the web, go to:
http://groups.yahoo.com/group/basicstamps/
To unsubscribe from this group, send an email to:
Your use of Yahoo! Groups is subject to:
http://docs.yahoo.com/info/terms/
Include
The basic Stamp,,
Original Message
be way overkill.
Operating
Stamp.
Yahoo! Groups Links
ande you need an SBC, you might as well use the SBC
ports, the BS2 is entirely unsuitable
for you.
The BS2 was designed for stand-alone, battery
powered applications, which have very simple
user interfaces (button and LED, if needed).
It can be built into a very small and power
efficient data-logger. It gets around the
cumbersome nature of the PC operating systems.
It can work as a 'slave' processor doing things
in real-time for a PC 'master'. It can give
a robot platform an autonomous controller.
And it costs $50.00, with a $100.00 development
board to program and test it with (and a PC
to run the IDE on) for a complete solution.
If you are building an embedded system based
on Windows CE, then you are a few steps up the
system evolution ladder from the BS2.
And $150.00 is probably one-tenth what you're
going to spend.
use the
> Include
> The basic Stamp,,
Original Message
> From: Allan Lane [noparse][[/noparse]mailto:allan.lane@h...]
> be way overkill.
> Operating
> Stamp.
Subject
> Yahoo! Groups Links
