Have a look at http://www.wd5gnr.com/stampfaq.htm?article=12
I cut and pasted this out of the stampsinclass message board. It may
answer your questions. There are some other responses to the relay
question also. Look in the January '04 postings.
--- In basicstamps@yahoogroups.com, "Brian E Boothe" <subrian@m...>
wrote:
> Does anyone Have Schematics Of hooking up relays to the inputs and
> outputs to the basic stamp, ??
Parallax has a document call 'Steroids for the Stamp' that
answers your questions.
---- Original message ----
>Date: Tue, 20 Jan 2004 11:42:09 -0600
>From: "Brian E Boothe" <subrian@m...>
>Subject: [noparse][[/noparse]basicstamps] Relay schematics (!!Help!!)
>To: <basicstamps@yahoogroups.com>
inputs and
>To UNSUBSCRIBE, just send mail to:
>from the same email address that you subscribed. Text in
the Subject and Body of the message will be ignored.
>Yahoo! Groups Links
>To visit your group on the web, go to:
> http://groups.yahoo.com/group/basicstamps/
>To unsubscribe from this group, send an email to:
>Your use of Yahoo! Groups is subject to:
> http://docs.yahoo.com/info/terms/
Regards
Figure your coil voltage and current.
select a darlington, Pn2222 or TIP120, to drive it. The TIP120 has
an internal diode so that helps, but is a larger TO220 package than
the T092 of the 2222.
inputs ?
1,000 ohms from the 5V to the contacts then back to your input pin.
change the parts to fit your needs, but the transistor takes the 5V
and 'swithces' the relay coil voltage. The relay CONTACT voltage is
isolated so if you have 1 volt or 1,000 volts the Stamp never sees it.
>inputs ?
>Dave
>Dave
>from the same email address that you subscribed. Text in the Subject and
>Yahoo! Groups Links
inputs ?
Dave
Dave
To UNSUBSCRIBE, just send mail to: basicstamps-unsubscribe@yahoogroups.com
In a message dated 1/20/2004 3:17:25 PM Eastern Standard Time, subrian@m... writes:
You don't hook relays to the input/output pins a Stamp - you will blow it.
You have to go via a shift register or a Darlington.
Sid Weaver
W4EKQ
Port Richey, FL
inputs and
>Yahoo! Groups Links
Regards
Dave Evartt
American Hovercraft
inputs ?
Dave
Dave
http://www.turbodeuce.com/images/bs2_to_relay.jpg
>inputs ?
>Dave
>Dave
>Yahoo! Groups Links
http://www.geocities.com/jimforkin2003/
jim
Original Message
From: Dave Mucha [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=Cdczwxur-xWFi5TyBiwaiP8CRGdRXtSqq7yK5x6Pv__YBLOstOEEGgHvj7mtr_w_6g55-EMf8KXng2Y]davemucha@j...[/url
Sent: Tuesday, January 20, 2004 12:51 PM
To: basicstamps@yahoogroups.com
Subject: [noparse][[/noparse]basicstamps] Re: Relay schematics (!!Help!!)
inputs ?
Dave
Dave
Yahoo! Groups Links
Sid Weaver
W4EKQ
Port Richey, FL
If you use the above circuit will will have to add a clamping diode.
Sid Weaver
W4EKQ
Port Richey, FL
jim
Original Message
From: Newzed@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=-XMvqUrSr1VI01CWfaAlVx3blu1UGW1_5MKtY_baXSI9glBku3rUcQr2SD6487LQ23BXsC-JTNk]Newzed@a...[/url
Sent: Tuesday, January 20, 2004 3:20 PM
Subject: Re: [noparse][[/noparse]basicstamps] Relay schematics (!!Help!!)
Sid Weaver
W4EKQ
Port Richey, FL
Yahoo! Groups Links
