SERIN Help Please
Hi Everyone!
My project is going really well! I think I am down to just one
technical hicup for my little robot.
Currently reading a DigiTape Plus electronic measuring tape. It has
a serial port on it.
Looks like I am getting probably all the information. Am having a
little problem and it is probably related to my variable and/or SERIN
formatting.
Example Input String:
" 5 ft 2 1/16 in"
I added the quotes so you would know exactly what it looks like.
Already wrote code to parse the string. Have to have it for another
part of the project.
My code looks something like:
Loop:
SEROUT .... 'Request data
SERIN TapeIn, N1200, ????????
'.... process'
GOTO Loop:
Please include how you would define the variable to hold the string.
Thanks!
Take care,
Frank
formatting.
" 5 ft 2 1/16 in"
Loop:
'.... process'
GOTO Loop:
Thanks!
Take care,
Frank
your example. If that's the case, I think you're stuck. The problem is
you just don't have enough variable space to capture the string and deal
with. My favorite Stamp for capturing and parsing text strings is the
BS2p or BS2pe which can capture any serial input to the Scratchpad RAM
for processing later, without consuming any variable space.
If you're using any of the BS2 family you can do it like this:
buffer VAR Byte(16)
Main:
' request data
SERIN TapeIn, 17197, [noparse][[/noparse]buffer\16]
' process data
-- Jon Williams
-- Parallax
Original Message
From: franksmith512 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=0UucCl9RxCONxkUJbuikf-hHl8b_o7PW6nHqfieXO4juuQ0VniSx7P3tekTf3IwBtvTdKdky5fNuvFKoig]franksmith512@y...[/url
Sent: Sunday, January 11, 2004 2:52 PM
To: basicstamps@yahoogroups.com
Subject: [noparse][[/noparse]basicstamps] SERIN Help Please
Hi Everyone!
formatting.
" 5 ft 2 1/16 in"
Loop:
'.... process'
GOTO Loop:
Thanks!
Take care,
Frank
To UNSUBSCRIBE, just send mail to:
basicstamps-unsubscribe@yahoogroups.com
from the same email address that you subscribed. Text in the Subject
and Body of the message will be ignored.
Yahoo! Groups Links
To visit your group on the web, go to:
http://groups.yahoo.com/group/basicstamps/
To unsubscribe from this group, send an email to:
Your use of Yahoo! Groups is subject to:
http://docs.yahoo.com/info/terms/
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
jwilliams@p... writes:
> buffer VAR Byte(16)
> Main:
> ' request data
> ' process data
Jon, what happens if the incoming string is less than 16 bytes. I was
getting ready to tell him the same thing, but then I couldn't answer the above
question.
Sid
array to be filled with zeros; if you don't SERIN will wait until enough
bytes arrive.
-- Jon Williams
-- Parallax
Original Message
From: Newzed@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=k13eCK5BGWhlkKS6W4lifZNCwfGa8m04nlD-pRIqDy7LL5ucJ9RE904c7HDvAbtiotFVbw]Newzed@a...[/url
Sent: Sunday, January 11, 2004 3:38 PM
Subject: Re: [noparse][[/noparse]basicstamps] SERIN Help Please
In a message dated 1/11/2004 4:35:35 PM Eastern Standard Time,
> buffer VAR Byte(16)
> Main:
> ' request data
> ' process data
above
question.
Sid
Yahoo! Groups Links
abuse@p....
> You can specify an ending character that will cause the rest of the
> bytes arrive.
Jon, wouldn't the sending string have to have the same ending character.
From what I understand the output of his electronic tape is cast in stone.
Sid
that appears in his string and after the second portion of his
measurement.
-- Jon Williams
-- Parallax
Original Message
From: Newzed@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=IzJfS_TVm9wv8MwXcqgsgTZSiXjaAWMSTmdza7ZsK46q0c0KXHVqU4JvKmLpcdKZgj-_fPbU0g]Newzed@a...[/url
Sent: Sunday, January 11, 2004 6:10 PM
In a message dated 1/11/2004 6:36:06 PM Eastern Standard Time,
> enough bytes arrive.
stone.
Sid
Yahoo! Groups Links
abuse@p....
> Based on his original post, he might use "n" as the ending character --
> measurement.
Good thought, Jon [noparse]:)[/noparse])
