SERIN Help Please — Parallax Forums
SERIN Help Please
edited 2004-01-12 00:42 in General Discussion
Hi Everyone!
My project is going really well! I think I am down to just one
technical hicup for my little robot.
Currently reading a DigiTape Plus electronic measuring tape. It has
a serial port on it.
Looks like I am getting probably all the information. Am having a
little problem and it is probably related to my variable and/or SERIN
formatting.
Example Input String:
" 5 ft 2 1/16 in"
I added the quotes so you would know exactly what it looks like.
Already wrote code to parse the string. Have to have it for another
part of the project.
My code looks something like:
Loop:
SEROUT .... 'Request data
SERIN TapeIn, N1200, ????????
'.... process'
GOTO Loop:
Please include how you would define the variable to hold the string.
Thanks!
Take care,
Frank
    edited 2004-01-11 21:21
    Are you using a BS1? It would appear so from the N1200 parameter in
    your example. If that's the case, I think you're stuck. The problem is
    you just don't have enough variable space to capture the string and deal
    with. My favorite Stamp for capturing and parsing text strings is the
    BS2p or BS2pe which can capture any serial input to the Scratchpad RAM
    for processing later, without consuming any variable space.
    If you're using any of the BS2 family you can do it like this:
    buffer VAR Byte(16)
    Main:
    ' request data
    SERIN TapeIn, 17197, [noparse][[/noparse]buffer\16]
    ' process data
    -- Jon Williams
    -- Parallax
    From: franksmith512 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=0UucCl9RxCONxkUJbuikf-hHl8b_o7PW6nHqfieXO4juuQ0VniSx7P3tekTf3IwBtvTdKdky5fNuvFKoig]franksmith512@y...[/url
    Sent: Sunday, January 11, 2004 2:52 PM
    Subject: [noparse][[/noparse]basicstamps] SERIN Help Please
    Hi Everyone!
    formatting.
    " 5 ft 2 1/16 in"
    Loop:
    '.... process'
    GOTO Loop:
    Thanks!
    Take care,
    Frank
    Yahoo! Groups Links
    To visit your group on the web, go to:
    http://groups.yahoo.com/group/basicstamps/
    To unsubscribe from this group, send an email to:
    Your use of Yahoo! Groups is subject to:
    This message has been scanned by WebShield. Please report SPAM to
    abuse@p....
    edited 2004-01-11 21:38
    In a message dated 1/11/2004 4:35:35 PM Eastern Standard Time,
    jwilliams@p... writes:
    > buffer VAR Byte(16)
    > Main:
    > ' request data
    > ' process data
    Jon, what happens if the incoming string is less than 16 bytes. I was
    getting ready to tell him the same thing, but then I couldn't answer the above
    question.
    Sid
    edited 2004-01-11 23:32
    You can specify an ending character that will cause the rest of the
    array to be filled with zeros; if you don't SERIN will wait until enough
    bytes arrive.
    -- Jon Williams
    -- Parallax
    From: Newzed@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=k13eCK5BGWhlkKS6W4lifZNCwfGa8m04nlD-pRIqDy7LL5ucJ9RE904c7HDvAbtiotFVbw]Newzed@a...[/url
    Sent: Sunday, January 11, 2004 3:38 PM
    Subject: Re: [noparse][[/noparse]basicstamps] SERIN Help Please
    > buffer VAR Byte(16)
    > Main:
    > ' request data
    > ' process data
    above
    question.
    Sid
    Yahoo! Groups Links
    abuse@p....
    edited 2004-01-12 00:10
    In a message dated 1/11/2004 6:36:06 PM Eastern Standard Time,
    > bytes arrive.
    Jon, wouldn't the sending string have to have the same ending character.
    From what I understand the output of his electronic tape is cast in stone.
    Sid
    edited 2004-01-12 00:25
    Based on his original post, he might use "n" as the ending character --
    that appears in his string and after the second portion of his
    measurement.
    -- Jon Williams
    -- Parallax
    From: Newzed@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=IzJfS_TVm9wv8MwXcqgsgTZSiXjaAWMSTmdza7ZsK46q0c0KXHVqU4JvKmLpcdKZgj-_fPbU0g]Newzed@a...[/url
    Sent: Sunday, January 11, 2004 6:10 PM
    > enough bytes arrive.
    stone.
    Sid
    Yahoo! Groups Links
    abuse@p....
    In a message dated 1/11/2004 7:28:29 PM Eastern Standard Time,
    > measurement.
    Good thought, Jon [noparse]:)[/noparse])
