rubber band tires on Boebot and MiniSumo
A good rubber glue is "Plyobond" which is made by Goodyear avalaible on almost
every hardware store.
Rene
altengnw32 a
Rene
altengnw32 a
wheels and sometimes they come off.
Has anyone tried gluing them on?
If so, what glue did you use?
Tbanks,
Lawrence
Alternative Enegy Now
altengnw@c... writes:
> I have trouble keeping the rubber band tires centered on the
It's tough to get those rubber bands centered, but once you do they pretty
well stay in place. If you want to use a glue, use regular contact cement, two
little dots 180 degrees apart.
Sid Weaver
W4EKQ
Port Richey, FL
if you need to.
Regards
Dave Evartt
American Hovercraft
