rubber band tires on Boebot and MiniSumo — Parallax Forums
edited 2004-01-10 20:31 in General Discussion
A good rubber glue is "Plyobond" which is made by Goodyear avalaible on almost
every hardware store.
Rene
altengnw32 a
    edited 2004-01-10 20:17
    I have trouble keeping the rubber band tires centered on the
    wheels and sometimes they come off.
    Has anyone tried gluing them on?
    If so, what glue did you use?
    Tbanks,
    Lawrence
    Alternative Enegy Now
    edited 2004-01-10 20:29
    In a message dated 1/10/2004 3:27:24 PM Eastern Standard Time,
    altengnw@c... writes:
    It's tough to get those rubber bands centered, but once you do they pretty
    well stay in place. If you want to use a glue, use regular contact cement, two
    little dots 180 degrees apart.
    Sid Weaver
    W4EKQ
    Port Richey, FL
    use rubber cement, it will hold the tires but can be removed
    if you need to.
    Regards
    Dave Evartt
    American Hovercraft
