Dual H Bridge Driver
I am looking for an IC H bridge that can handle at least 1.5 amps continuous.
Does any one have any experience or recommendations?
Tim
Tim
continuous.
> Tim
Check the specs on mosfet drivers. These can be controlled by 2
inputs and will control 2 outputs.
Digi-key has a simple search just put in -> mosfet driver
2 amps is not uncommon.
Also, it you want to roll your own, you can google H-bridge and find
a lot of schematics.
Dave
The following three chips may be suitable, check out the data
sheets. Personally I have only had experience with the 298 and I
feel it is a good chip for use with the stamp.
LM18200T
L298
SN754410
Arridh
continuous.
> Tim
jim
http://www.geocities.com/jimforkin2003/
Original Message
From: arridh_shashank [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=LnjD8P5Rz-XoS-ceTE3xckTOS01xEIRyue6Y2_tYr94-IRJzNSy8o9-w360Jk8R6THOro0EgfKVUCGZctn_jnt8Hs0FodA]arridh_shashank@y...[/url
Sent: Thursday, January 08, 2004 2:22 AM
To: basicstamps@yahoogroups.com
Subject: [noparse][[/noparse]basicstamps] Re: Dual H Bridge Driver
Hi
LM18200T
L298
SN754410
Arridh
continuous.
> Tim
To UNSUBSCRIBE, just send mail to:
basicstamps-unsubscribe@yahoogroups.com
from the same email address that you subscribed. Text in the Subject and
Yahoo! Groups Links
To visit your group on the web, go to:
http://groups.yahoo.com/group/basicstamps/
To unsubscribe from this group, send an email to:
Your use of Yahoo! Groups is subject to:
http://docs.yahoo.com/info/terms/
continuous.
The L298N can do that. We have a nice little kit with a circuit board
and all components (The L298 chip needs a circuit board due to its
unusual pinout):
http://www.hvwtech.com/pages/products_view.asp?ProductID=68
The chip is also available separately, if you prefer.
HVW Tech Sales
Tel: (403) 730-8603
http://www.HVWTech.com
Thanks everyone this is just what I was looking for.
Tim
Iam right now using set of 5 LM18200 with very good amperage
rating..., they are very good, but these chips don't come with
standard pin spacing...
Satya
--- In basicstamps@yahoogroups.com, "arridh_shashank"
<arridh_shashank@y...> wrote:
> Hi
> LM18200T
> L298
> SN754410
> Arridh
amps
> continuous.
> > Tim
