more memory
i need to use a 16k memory .
to storage sample configuration of some equipment .
somebody , please help ?????
victor
victor
victormedranop2000@y... writes:
Go to the Parallax site and look at their Serial EEPROM application. It uses
an 8K chip which will store 1024 bytes of data, and it is very easy to use.
I have a 512K EEPROM which is pin compatible with the application chip and by
just switching chips you can increase your data storage to 8192 bytes.
Sid Weaver
W4EKQ
Port Richey, FL
designated only for data storage (you cannot download and run programs
from these slots); that gives you 16K. Or you can go with any of the
various serial EEPROMs available, either in I2C or 3-wire modes. I2C
gives a lot of choices and the flexibility of the buss, but requires
more code unless you're using the BS2p or BS2pe.
-- Jon Williams
-- Applications Engineer, Parallax
-- Dallas Office
Original Message
From: victormedranop2000 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=62WHsnoyPeOZ8nG1bYm1uSmA-_Ly5UOUvpcTthf__XlG7TUKaWBaUKDOkZuvyQ1OGzPTV73tSvgu2b_YbVExQWlrE1k8qGs]victormedranop2000@y...[/url
Sent: Sunday, December 28, 2003 11:46 AM
To: basicstamps@yahoogroups.com
Subject: [noparse][[/noparse]basicstamps] more memory
victor
To UNSUBSCRIBE, just send mail to:
basicstamps-unsubscribe@yahoogroups.com
from the same email address that you subscribed. Text in the Subject
and Body of the message will be ignored.
Yahoo! Groups Links
To visit your group on the web, go to:
http://groups.yahoo.com/group/basicstamps/
To unsubscribe from this group, send an email to:
Your use of Yahoo! Groups is subject to:
http://docs.yahoo.com/info/terms/
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
regards .
Newzed@a... wrote:
In a message dated 12/28/2003 12:57:54 PM Eastern Standard Time,
Sid Weaver
W4EKQ
Port Richey, FL
from the same email address that you subscribed. Text in the Subject and Body of
Yahoo! Groups Links
Do you Yahoo!?
Free Pop-Up Blocker - Get it now
8k or 3 wire.
regards .
Jon Williams <jwilliams@p...> wrote:
If you use the BS2pe you get eight extra EEPROM slots (8 - 15) that are
-- Jon Williams
-- Dallas Office
Original Message
From: victormedranop2000 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=0soqgvvMxnVMR2nTx49lcbzwF9mrny9FBO0e-4Myv1nA4P8ta8oWqMqRU4osWdba0pvpFA0et2ZZ16HgA7kszHc7d668YA]victormedranop2000@y...[/url
victor
Yahoo! Groups Links
abuse@p....
Yahoo! Groups Links
Do you Yahoo!?
<victormedranop2000@y...> wrote:
> i'm using b2sx chip , can you tell me where can i buy i2c chip more
than
> 8k or 3 wire.
Digi-key
search for 'serial memory'
then follow your nose.
Dave
davemucha@j... writes:
> --- In basicstamps@yahoogroups.com, victor medrano
> than
> > 8k or 3 wire.
Digikey has a 512K 3 wire - AT25HP512-10PI2.7
Sid Weaver
W4EKQ
Port Richey, FL
how can i add more storage ( data storage ) to this IC.
Regards
than
> 8k or 3 wire.
Digi-key
Dave
Yahoo! Groups Links
Do you Yahoo!?
connection manually. It's not tough, in fact, it's done already. This
N&V article will help:
http://www.parallax.com/dl/docs/cols/nv/vol3/col/85.pdf
Let me remind list participants that our Nuts & Volts reprints (PDF) are
a great resourch for Stamp newcomers and experienced users alike.
-- Jon Williams
-- Dallas Office
Original Message
From: victor medrano [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=jtYxW0uyPqnBdKEarNTXj3ORVoIQuj9n9t_nZZH9fR4Bwl3idDnx4Wh8Mixeqk-RZQSBhGCHs0hedgLtVKWLkqxEjQ]victormedranop2000@y...[/url
Sent: Sunday, December 28, 2003 3:07 PM
Subject: Re: [noparse][[/noparse]basicstamps] Re: more memory
i am new with this , i'm using a bs2x , i dont have de i2c command ,
Regards
than
> 8k or 3 wire.
Digi-key
Dave
Yahoo! Groups Links
Do you Yahoo!?
Yahoo! Groups Links
abuse@p....
thanks
victor
You can use an I2C device with the BS2sx, you just have to code the I2C
-- Jon Williams
-- Dallas Office
Original Message
From: victor medrano [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=83sNP6VpBA7QBX3tGN5R_xAo6eyw-oWeppyhLyHVNoSo8z8relUBfWVbYDz-xw38QnSzEZ6JROpyRcIfpJPYI7jVPQ]victormedranop2000@y...[/url
Regards
than
> 8k or 3 wire.
Digi-key
Dave
Yahoo! Groups Links
Do you Yahoo!?
Yahoo! Groups Links
abuse@p....
Yahoo! Groups Links
Do you Yahoo!?
-Dave
to use.
chip and by
bytes.
> Sid Weaver
> W4EKQ
> Port Richey, FL
