H-bridge driver
Hi all,
Does anyone have any suggestions on which IC to use for relatively
high-power MOSFET H-bridges? I plan on using 100A, 55V MOSFETs but there
are so many choices that i am having difficulty choosing one.
Chrisitian
_________________________________________________________________
Check your PC for viruses with the FREE McAfee online computer scan.
http://clinic.mcafee.com/clinic/ibuy/campaign.asp?cid=3963
Chrisitian
H-bridge driver chip.
www.semi.harris.com
+ read " N&V Column #52, August 1999 by Lon Glazner: Stamp-
Controlled High Power H-Bridge" for more info.
Arridh
--- In basicstamps@yahoogroups.com, "Christian Wentz"
<cwentz86@h...> wrote:
> Hi all,
relatively
but there
> Chrisitian
scan.
found for simplicity and reliability for our robotics motion
applications. its available at digikey for about $10, and here is
the data sheet:
http://www.national.com/pf/LM/LMD18201.html#Datasheet
Chris Schur
--- In basicstamps@yahoogroups.com, "Christian Wentz" <cwentz86@h...>
wrote:
> Hi all,
relatively
there
> Chrisitian
scan.
self. It is not ment as a mosfet driver. If you want an IC to handle
all the power requirements for your mosfets this is not the IC. Also
take a look at the OSMC (open source motor controller)
http://groups.yahoo.com/group/osmc
They have a well designed motor controller that has proven its self.
Arridh
--- In basicstamps@yahoogroups.com, "Chris Schur" <comets133@y...>
wrote:
> Christian, the National LMD18201 is by far the best driver we have
> the data sheet:
> Chris Schur
<cwentz86@h...>
> wrote:
> > Hi all,
> relatively
but
> there
> > Chrisitian
> scan.
