H-bridge driver — Parallax Forums
H-bridge driver
edited 2003-12-27 06:26 in General Discussion
Hi all,
Does anyone have any suggestions on which IC to use for relatively
high-power MOSFET H-bridges? I plan on using 100A, 55V MOSFETs but there
are so many choices that i am having difficulty choosing one.
Chrisitian
_________________________________________________________________
Check your PC for viruses with the FREE McAfee online computer scan.
http://clinic.mcafee.com/clinic/ibuy/campaign.asp?cid=3963
    edited 2003-12-27 00:17
    HIP4081A
    H-bridge driver chip.
    www.semi.harris.com
    + read " N&V Column #52, August 1999 by Lon Glazner: Stamp-
    Controlled High Power H-Bridge" for more info.
    Arridh
    --- In basicstamps@yahoogroups.com, "Christian Wentz"
    <cwentz86@h...> wrote:
    > Hi all,
    relatively
    but there
    > Chrisitian
    scan.
    edited 2003-12-27 05:22
    Christian, the National LMD18201 is by far the best driver we have
    found for simplicity and reliability for our robotics motion
    applications. its available at digikey for about $10, and here is
    the data sheet:
    http://www.national.com/pf/LM/LMD18201.html#Datasheet
    Chris Schur
    --- In basicstamps@yahoogroups.com, "Christian Wentz" <cwentz86@h...>
    wrote:
    > Hi all,
    relatively
    there
    > Chrisitian
    scan.
    The LMD18201 is a H-Bridge IC and is designed to drive the motor its
    self. It is not ment as a mosfet driver. If you want an IC to handle
    all the power requirements for your mosfets this is not the IC. Also
    take a look at the OSMC (open source motor controller)
    http://groups.yahoo.com/group/osmc
    They have a well designed motor controller that has proven its self.
    Arridh
    --- In basicstamps@yahoogroups.com, "Chris Schur" <comets133@y...>
    > the data sheet:
    > Chris Schur
    <cwentz86@h...>
    > wrote:
    > > Hi all,
    > relatively
    but
    > there
    > > Chrisitian
    > scan.
