another SHIFTOUT question
John Williams,
Is there any thought on making/updating the "shiftout"
function so that it shifts on an external clock?
-Beau Schwabe
-Beau Schwabe
Are you suggesting the Stamp become a slave device? If yes, what data
does the Stamp SHIFTOUT? What data type (how many bits)? When does the
Stamp know when to quit and move to the next instruction?
Of course I'm playing the devil's advocate -- it could be done in a
future product but not without significant thought. How do you envision
using such a feature?
-- Jon Williams
-- Applications Engineer, Parallax
-- Dallas Office
Original Message
From: Beau Schwabe [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=ky10oMHtGuf5d2y-IGgC-qhS57zOgRSbWkohu-93Se5OrXWcJ-kHamOgBd0qoRikgbyxshMNnGVuVkqMKKM]bschwabe@a...[/url
Sent: Wednesday, December 17, 2003 2:52 PM
To: basicstamps@yahoogroups.com
Subject: [noparse][[/noparse]basicstamps] another SHIFTOUT question
John Williams,
-Beau Schwabe
To UNSUBSCRIBE, just send mail to:
basicstamps-unsubscribe@yahoogroups.com
from the same email address that you subscribed. Text in the Subject
and Body of the message will be ignored.
Yahoo! Groups Links
To visit your group on the web, go to:
http://groups.yahoo.com/group/basicstamps/
To unsubscribe from this group, send an email to:
Your use of Yahoo! Groups is subject to:
http://docs.yahoo.com/info/terms/
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
Yes, the stamp would/could become a slave device with
an inherent flow control. This is exactly what I had
in mind. The command structure would be identical to
the current command with the exception of a 'software
mode switch' where you could specify the clock direction.
(perhaps where MSB/LSB is specified). Of course you would
need an optional 'timeout' built-in if it did not receive
a clock within a reasonable amount of time.
I have used this method more in PIC applications where
RS232 was not reliable due to either varying clock speed
applications or unreliable RC time bases due to temperature
drift etc. On several occasions over the years I have
come across applications where having this feature would
have been very useful.
example 1:
SHIFTOUT Dpin, Cpin, Mode, [noparse][[/noparse]Variable{\Bits}{,Variable{\Bits}...}]
Dpin - Same / 0-15
Cpin - Same / 0-15
Mode - Expanded / 0-1
* Bit0 = msb/lsb first
Bit1 = not used ; possible place holder for SHIFTIN
compatibility in example below.
Bit2 = Cpin direction internal/external
Bit3 = enable/dissable timeout
* = existing 1 Bit mode definition
Variable - Same / valid Stamp variable
Bits - Same / 1-16
example 2:
SHIFTIN Dpin, Cpin, Mode, [noparse][[/noparse]Variable{\Bits}{,Variable{\Bits}...}]
Dpin - Same / 0-15
Cpin - Same / 0-15
Mode - Expanded / 0-3
* Bit1 = data valid before/after clock pulse
* = existing 2 Bit mode definition
Variable - Same / Byte or Word variable
Bits - Same / 1-16
Thanks!
-Beau Schwabe
>Beahu:
>-- Jon Williams
>-- Dallas Office
Original Message
>From: Beau Schwabe [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=HmWMJdzUJgBZx0eOm4hd_Oof2fwIoA5P6oCMlz5PuFXexOwGU7szvvjIBocWuZG6Wnt77n2yb0bjhyVaMctiaNxd]bschwabe@a...[/url
>John Williams,
>Thanks
>-Beau Schwabe
