another SHIFTOUT question — Parallax Forums
edited 2003-12-17 23:32 in General Discussion
John Williams,
Is there any thought on making/updating the "shiftout"
function so that it shifts on an external clock?
-Beau Schwabe
    edited 2003-12-17 22:22
    Beahu:
    Are you suggesting the Stamp become a slave device? If yes, what data
    does the Stamp SHIFTOUT? What data type (how many bits)? When does the
    Stamp know when to quit and move to the next instruction?
    Of course I'm playing the devil's advocate -- it could be done in a
    future product but not without significant thought. How do you envision
    using such a feature?
    -- Jon Williams
    -- Dallas Office
    From: Beau Schwabe [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=ky10oMHtGuf5d2y-IGgC-qhS57zOgRSbWkohu-93Se5OrXWcJ-kHamOgBd0qoRikgbyxshMNnGVuVkqMKKM]bschwabe@a...[/url
    Sent: Wednesday, December 17, 2003 2:52 PM
    Subject: [noparse][[/noparse]basicstamps] another SHIFTOUT question
    John Williams,
    -Beau Schwabe
    Yahoo! Groups Links
    To visit your group on the web, go to:
    http://groups.yahoo.com/group/basicstamps/
    To unsubscribe from this group, send an email to:
    Your use of Yahoo! Groups is subject to:
    This message has been scanned by WebShield. Please report SPAM to
    abuse@p....
    Jon Williams,
    Yes, the stamp would/could become a slave device with
    an inherent flow control. This is exactly what I had
    in mind. The command structure would be identical to
    the current command with the exception of a 'software
    mode switch' where you could specify the clock direction.
    (perhaps where MSB/LSB is specified). Of course you would
    need an optional 'timeout' built-in if it did not receive
    a clock within a reasonable amount of time.
    I have used this method more in PIC applications where
    RS232 was not reliable due to either varying clock speed
    applications or unreliable RC time bases due to temperature
    drift etc. On several occasions over the years I have
    come across applications where having this feature would
    have been very useful.
    example 1:
    SHIFTOUT Dpin, Cpin, Mode, [noparse][[/noparse]Variable{\Bits}{,Variable{\Bits}...}]
    Dpin - Same / 0-15
    Cpin - Same / 0-15
    Mode - Expanded / 0-1
    * Bit0 = msb/lsb first
    Bit1 = not used ; possible place holder for SHIFTIN
    compatibility in example below.
    Bit2 = Cpin direction internal/external
    Bit3 = enable/dissable timeout
    * = existing 1 Bit mode definition
    Variable - Same / valid Stamp variable
    Bits - Same / 1-16
    example 2:
    SHIFTIN Dpin, Cpin, Mode, [noparse][[/noparse]Variable{\Bits}{,Variable{\Bits}...}]
    Dpin - Same / 0-15
    Cpin - Same / 0-15
    Mode - Expanded / 0-3
    * Bit1 = data valid before/after clock pulse
    * = existing 2 Bit mode definition
    Variable - Same / Byte or Word variable
    Bits - Same / 1-16
    Thanks!
    -Beau Schwabe
    >Beahu:
    >-- Jon Williams
    >-- Dallas Office
    >From: Beau Schwabe [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=HmWMJdzUJgBZx0eOm4hd_Oof2fwIoA5P6oCMlz5PuFXexOwGU7szvvjIBocWuZG6Wnt77n2yb0bjhyVaMctiaNxd]bschwabe@a...[/url
    >John Williams,
    >Thanks
    >-Beau Schwabe
