Does anyone know the format to parse NMEA sentences for reading
serial GPS outputs to serial LCD'S Thanks
To UNSUBSCRIBE, just send mail to: basicstamps-unsubscribe@yahoogroups.com
from the same email address that you subscribed. Text in the Subject
and Body of the message will be ignored.
There are several methodsyou can use depending on whether you want a generic
routine which can be used for any device's output (most effort) of if you
simply want to write something simple that will get specific strings from a
specific receiver.
What do you want to accomplish?
You might look up Jon's N&V article from earlier in the year (I think) where
he covers a fairly entailed method for a Garmin receiver (again, AFAIR)
TimeData var byte(4) ' UTC time data
LatitudeData var byte(4) ' latitude data
LongitudeData var byte(4) ' longitude data
AltitudeData var word ' altitude data
' GPSReadData - Reads NMEA data from the GPS module
GPSReadData: ' Set the default GPS data quality
GPSQuality = 0
http://www.parallax.com/dl/docs/cols/nv/vol3/col/83.pdf
It specifically covers NMEA $GPMRC string receipt and parsing with a
BS2p.
-- Jon Williams
-- Applications Engineer, Parallax
-- Dallas Office
Original Message
From: mikey_118@y... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=UTRmt4RLvo_CBJWpr5RxR-4szYwajbTOWShDT3NpGEaFXVwmXwhz53D8-g1kNFl16p1ufKonmz0vgbU]mikey_118@y...[/url
Sent: Tuesday, December 16, 2003 9:50 PM
To: basicstamps@yahoogroups.com
Subject: [noparse][[/noparse]basicstamps] Parse NMEA sentences
Yahoo! Groups Links
To visit your group on the web, go to:
http://groups.yahoo.com/group/basicstamps/
To unsubscribe from this group, send an email to:
Your use of Yahoo! Groups is subject to:
http://docs.yahoo.com/info/terms/
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
specific receiver.
This is how i read NMEA data from a GPS module:
GPSQuality var byte ' GPS quality indicator
GPSQuality = 0
' Get NMEA data from the GPS module...
SERIN 0,16572,2000,GPSReadDataFailed,[noparse][[/noparse]WAIT("$GPGGA"), SKIP 1, DEC2
TimeData(0), DEC2 TimeData(1), DEC2 TimeData(2), SKIP 1, DEC2 TimeData(3),
SKIP 2, DEC2 LatitudeData(0), DEC2 LatitudeData(1), SKIP 1, DEC2
LatitudeData(2), SKIP 3, LatitudeData(3), SKIP 1, DEC3 LongitudeData(0),
DEC2 LongitudeData(1), SKIP 1, DEC2 LongitudeData(2), SKIP 3,
LongitudeData(3), SKIP 1, DEC1 GPSQuality, SKIP 8, DEC AltitudeData]
GPSReadDataFailed: RETURN
If valid GPS data is received then the value of the GPSQuality variable will
be non-zero.
And this is how i display NMEA data on a two line LCD:
' DisplayPosition - Displays the position on the LCD panel
DisplayPosition:
SEROUT 0,16468,[noparse][[/noparse]$FE, 128, "LAT ", DEC2 LatitudeData(0), %11011111, DEC2
LatitudeData(1), ".", DEC2 LatitudeData(2), 39, " ", LatitudeData(3)]
SEROUT 0,16468,[noparse][[/noparse]$FE, 192, "LNG ", DEC3 LongitudeData(0), %11011111, DEC2
LongitudeData(1), ".", DEC2 LongitudeData(2), 39, " ", LongitudeData(3)]
RETURN
I hope this helps.
Best regards,
Russell Warburton
email: russell@w...
website: http://www.warburtech.com
telephone: +44 (0)7814 044 754
Original Message
To: <basicstamps@yahoogroups.com>
Sent: Wednesday, December 17, 2003 3:50 AM
> from the same email address that you subscribed. Text in the Subject and
> Yahoo! Groups Links
