Parse NMEA sentences — Parallax Forums
edited 2003-12-17 18:02 in General Discussion
Does anyone know the format to parse NMEA sentences for reading
serial GPS outputs to serial LCD'S Thanks
    edited 2003-12-17 05:16
    This article should help:
    http://www.parallax.com/dl/docs/cols/nv/vol3/col/83.pdf
    It specifically covers NMEA $GPMRC string receipt and parsing with a
    BS2p.
    -- Jon Williams
    -- Dallas Office
    From: mikey_118@y... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=UTRmt4RLvo_CBJWpr5RxR-4szYwajbTOWShDT3NpGEaFXVwmXwhz53D8-g1kNFl16p1ufKonmz0vgbU]mikey_118@y...[/url
    Sent: Tuesday, December 16, 2003 9:50 PM
    Subject: [noparse][[/noparse]basicstamps] Parse NMEA sentences
    Yahoo! Groups Links
    To visit your group on the web, go to:
    http://groups.yahoo.com/group/basicstamps/
    To unsubscribe from this group, send an email to:
    Your use of Yahoo! Groups is subject to:
    This message has been scanned by WebShield. Please report SPAM to
    abuse@p....
    edited 2003-12-17 07:06
    There are several methodsyou can use depending on whether you want a generic
    routine which can be used for any device's output (most effort) of if you
    simply want to write something simple that will get specific strings from a
    specific receiver.
    What do you want to accomplish?
    You might look up Jon's N&V article from earlier in the year (I think) where
    he covers a fairly entailed method for a Garmin receiver (again, AFAIR)
    Hi Mikey,
    This is how i read NMEA data from a GPS module:
    GPSQuality var byte ' GPS quality indicator
    TimeData var byte(4) ' UTC time data
    LatitudeData var byte(4) ' latitude data
    LongitudeData var byte(4) ' longitude data
    AltitudeData var word ' altitude data
    ' GPSReadData - Reads NMEA data from the GPS module
    GPSReadData: ' Set the default GPS data quality
    GPSQuality = 0
    ' Get NMEA data from the GPS module...
    SERIN 0,16572,2000,GPSReadDataFailed,[noparse][[/noparse]WAIT("$GPGGA"), SKIP 1, DEC2
    TimeData(0), DEC2 TimeData(1), DEC2 TimeData(2), SKIP 1, DEC2 TimeData(3),
    SKIP 2, DEC2 LatitudeData(0), DEC2 LatitudeData(1), SKIP 1, DEC2
    LatitudeData(2), SKIP 3, LatitudeData(3), SKIP 1, DEC3 LongitudeData(0),
    DEC2 LongitudeData(1), SKIP 1, DEC2 LongitudeData(2), SKIP 3,
    LongitudeData(3), SKIP 1, DEC1 GPSQuality, SKIP 8, DEC AltitudeData]
    GPSReadDataFailed: RETURN
    If valid GPS data is received then the value of the GPSQuality variable will
    be non-zero.
    And this is how i display NMEA data on a two line LCD:
    ' DisplayPosition - Displays the position on the LCD panel
    DisplayPosition:
    SEROUT 0,16468,[noparse][[/noparse]$FE, 128, "LAT ", DEC2 LatitudeData(0), %11011111, DEC2
    LatitudeData(1), ".", DEC2 LatitudeData(2), 39, " ", LatitudeData(3)]
    SEROUT 0,16468,[noparse][[/noparse]$FE, 192, "LNG ", DEC3 LongitudeData(0), %11011111, DEC2
    LongitudeData(1), ".", DEC2 LongitudeData(2), 39, " ", LongitudeData(3)]
    RETURN
    I hope this helps.
    Best regards,
    Russell Warburton
    email: russell@w...
    website: http://www.warburtech.com
    telephone: +44 (0)7814 044 754
    Sent: Wednesday, December 17, 2003 3:50 AM
    > Yahoo! Groups Links
