AD592 working?
I am working throught the series of experiments in the Earth
Measurements book and parts kit I bought. I have been enjoying it
very much. I have gotten to the experiment with the AD592 temp.
sensor. This is the first experiment I have not been able to get to
work. I have rechecked my circuit and program a number of times.
Yet, I get an rct value of 0 no matter what. Is there a simple
diagnostic I can do to validate that the AD592 is working? I read a
resistance across it of around 3Mohms. Is this normal?
Thanks for any help.
Mark
Mark
>Mark
If you substitute a 100kohm resistor in place of the AD592, you
should get a reading from the RCTIME command of about 3000 to 4000.
100k 0.22uF
+5
common x var word
| capacitor DO
| RCTIME 0,0,x
p0
/\/\--' LOW 0
100 DEBUG DEC x,cr
PAUSE 1000
LOOP
That should help to determine if the problem is with the sensor or
with the wiring.
-- Tracy
The AD592 supplies a current of 1 uA per degree Kelvin.
So at 20 degree C there should be a current of 293.15 uA. If you have a
meter with a mA range you will be able to check it.
The AD592 has a 'plus' and a 'minus' so there could be your problem.
Succes,
Klaus
Oorspronkelijk bericht
Van: mandsb00 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=LY23wDyXj7wAQCQWrWO3TBOhP_l-oZMYvvUwmnYfL7PmMzty2WJbcYwra_4Yh5QSUZ0dplAuCMP0W2iovsvfZrDP]mandsb@w...[/url
Verzonden: donderdag 11 december 2003 2:40
Aan: basicstamps@yahoogroups.com
Onderwerp: [noparse][[/noparse]basicstamps] AD592 working?
Mark
To UNSUBSCRIBE, just send mail to:
basicstamps-unsubscribe@yahoogroups.com
from the same email address that you subscribed. Text in the Subject and
Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
