PAK-VIII Troubles
I bought a PAK-VIII, and I can't seem to get it working.
I've rewired the circuit many times, and checked voltages, etc.
I'm using code from ( http://www.al-williams.com/servo_bot.htm
<http://www.al-williams.com/servo_bot.htm> ), and the
code has not been modified ( i.e. BS2 Pin15 is Data and BS2 Pin 14 is
Clock ).
I am using a single LED on P0 of the PAK-VIII. P0 goes to a LED
which in turn goes to ground. There is a resistor between P0 and the
LED.
We have an oscilloscope and can see activity on the CLOCK and DATA pins.
I never see any activity on P0 of the PAK-VIII.
Any help would be appreciated.
Clock ).
LED.
Common problems include miswiring or failure of the oscillator to start.
Al Williams
AWC
http://www.al-williams.com/awce
Original Message
> From: Bryan Smith [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=qHFtRLO5iDAExhGFgAC4h3OWRxrQ0UueTknsrxqsnept_7USaBHuK_t2ArapxS5iAuRkcwD7ZPbmrw]bsmith@w...[/url
> Sent: Tuesday, December 02, 2003 1:42 PM
> To: basicstamps@yahoogroups.com
> Subject: [noparse][[/noparse]basicstamps] PAK-VIII Troubles
> etc. I'm using code from ( http://www.al-williams.com/servo_bot.htm
> Pin 14 is Clock ). I am using a single LED on P0 of the
> PAK-VIII. P0 goes to a LED which in turn goes to ground.
> There is a resistor between P0 and the LED.
> DATA pins. I never see any activity on P0 of the PAK-VIII.
> To UNSUBSCRIBE, just send mail to:
> from the same email address that you subscribed. Text in the
> Subject and Body of the message will be ignored.
> Your use of Yahoo! Groups is subject to
> http://docs.yahoo.com/info/terms/
