continuous rotation potentiometer?
Hello, does anyone know how to measure the position of a continuously
rotating wheel? Do I use a multi-turn potentiometer for that, and if
so, what's a good way to link the wheel to the pot? You can e-mail
nathanchronister@y... instead of posting on the group if you
like. Thank you for any suggestions.
http://www.allegromicro.com/sf/0645/index.asp
Nick
http://www.al-williams.com/pak11.htm and http://www.al-williams.com/gp5.htm.
You can also use the PAK-VI or GP-2 but they aren't optimized for that kind
of service.
Al Williams
AWC
Original Message
> From: nathanchronister [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=RhTeFvjTCZr5fwLlU9bfQttPCfonoHMhICKhAgUyQJwo_2oR0piT6Rx0edDizgEGTibVU7e-ePL6pNlxnz4RIIviXw]nathanchronister@y...[/url
> Sent: Thursday, November 20, 2003 4:24 PM
> To: basicstamps@yahoogroups.com
> Subject: [noparse][[/noparse]basicstamps] continuous rotation potentiometer?
> To UNSUBSCRIBE, just send mail to:
> from the same email address that you subscribed. Text in the
> Subject and Body of the message will be ignored.
> Your use of Yahoo! Groups is subject to
> http://docs.yahoo.com/info/terms/
Do you need to know how fast (RPM's), angular displacement, direction, or
just that it is spinning?
Different approaches to all the above sensory input.
A magnet on the wheel with a hall sensor will give you RPM. Count the pulses
over time.
An Absolute Encoder will give angular displacement of the wheel. These are
expensive but output a code of the rotational angle of the wheel.
An A-B Differential Encoder will give you speed, direction and, if referenced
to an index mark, angular displacement. More expensive than a magnet/hall
sensor but cheaper than an Absolute Encoder.
Or you could use a cloths pin and clip a playing card to the frame so it
sticks into the spokes and if it is making noise, the wheel is spinning.
I am not trying to be a wise cracker but, without more information it is hard
to know where you want to go (Pun intended).
Its like asking how much a car costs, or how heavy is a tank of water.
Alan Bradford
Plasma Technologies
In a message dated 11/20/2003 5:53:05 PM Eastern Standard Time,
nathanchronister@y... writes:
