continuous rotation potentiometer?
Archiver
Hello, does anyone know how to measure the position of a continuously
rotating wheel? Do I use a multi-turn potentiometer for that, and if
so, what's a good way to link the wheel to the pot? You can e-mail
nathanchronister@y... instead of posting on the group if you
like. Thank you for any suggestions.
http://www.allegromicro.com/sf/0645/index.asp
Nick
http://www.al-williams.com/pak11.htm and http://www.al-williams.com/gp5.htm.
You can also use the PAK-VI or GP-2 but they aren't optimized for that kind
of service.
Al Williams
AWC
> From: nathanchronister [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=RhTeFvjTCZr5fwLlU9bfQttPCfonoHMhICKhAgUyQJwo_2oR0piT6Rx0edDizgEGTibVU7e-ePL6pNlxnz4RIIviXw]nathanchronister@y...[/url
> Sent: Thursday, November 20, 2003 4:24 PM
> Subject: [noparse][[/noparse]basicstamps] continuous rotation potentiometer?
> from the same email address that you subscribed. Text in the
Do you need to know how fast (RPM's), angular displacement, direction, or
just that it is spinning?
Different approaches to all the above sensory input.
A magnet on the wheel with a hall sensor will give you RPM. Count the pulses
over time.
An Absolute Encoder will give angular displacement of the wheel. These are
expensive but output a code of the rotational angle of the wheel.
An A-B Differential Encoder will give you speed, direction and, if referenced
to an index mark, angular displacement. More expensive than a magnet/hall
sensor but cheaper than an Absolute Encoder.
Or you could use a cloths pin and clip a playing card to the frame so it
sticks into the spokes and if it is making noise, the wheel is spinning.
I am not trying to be a wise cracker but, without more information it is hard
to know where you want to go (Pun intended).
Its like asking how much a car costs, or how heavy is a tank of water.
Alan Bradford
Plasma Technologies
In a message dated 11/20/2003 5:53:05 PM Eastern Standard Time,
nathanchronister@y... writes:
