7- Segment LED
I am using a PARA LIGHT C-5214 7 Segment LED. There are 5 Pins located
at the top and bottom of the device. I am trying to complete Stamp
works #8 but I can not seem to get the pin configuration right. Can
someone help?
Thanks Mark
someone help?
Thanks Mark
- to check this you will have to put a 150 ohm resistor on every
pin of the display and 5Vdc applied all at once to every resistor. Now one
by one remove 5Vdc and apply ground. if nothing happens remove the gound and
replace 5Vdc and continue on to the next resistor.
- if you light it up in this manner the pin tied to ground is your
common cathode pin and the rest are anodes. you would have a 8 Displayed on
your led display
- if nothing happens you will have to to the opposite. apply
ground to all the resistors and one by one remove ground and apply 5Vdc.
remove the 5vdc replace ground and continue on to the next resistor.
common anode pin and the rest are cathodes. you would have a 8 Displayed on
your led display
and from there if you get some results you can firgure out which segments go
to which pin.
i know this a long way but it works when experimenting. half of engineering
is trial and error.
lets see if this helps you.
Original Message
To: <basicstamps@yahoogroups.com>
Sent: Wednesday, November 12, 2003 3:57 PM
Subject: [noparse][[/noparse]basicstamps] 7- Segment LED
> someone help?
> Thanks Mark
> To UNSUBSCRIBE, just send mail to:
> from the same email address that you subscribed. Text in the Subject and
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
answer your question:
http://www.para.com.tw/pdf/E-Display/E04-CA501X,CA521X.pdf
If that link didn't work go to para's website and hunt it down.
Resc.
--- In basicstamps@yahoogroups.com, "Gary Denison" <gdii@c...> wrote:
> do you know if it is a common anode or common cathode display?
resistor on every
Now one
gound and
ground is your
Displayed on
> your led display
opposite. apply
5Vdc.
resistor.
ground is your
Displayed on
> your led display
segments go
> to which pin.
engineering
> is trial and error.
Original Message
> From: "MARK DEVINE" <mdevine@s...>
located
Stamp
Can
> > someone help?
> > Thanks Mark
Subject and
1-5 and 6-10 on the other side like an IC?
Mark
Original Message
From: rescme1 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=0NzIVQgk3t0PA4qF4j_UuqpZfVhoxSWpV2FQo61t2qNTPily4ZgGA6BIK-7lXHmgkhKA-p6B-OoCe3niRw]alram2@h...[/url
Sent: Thursday, November 13, 2003 8:45 AM
To: basicstamps@yahoogroups.com
Subject: [noparse][[/noparse]basicstamps] Re: 7- Segment LED
Here is the data sheet(s) to the part in question, this should
Resc.
resistor on every
Now one
gound and
ground is your
Displayed on
> your led display
opposite. apply
5Vdc.
resistor.
ground is your
Displayed on
> your led display
segments go
> to which pin.
engineering
> is trial and error.
Original Message
located
Stamp
Can
> > someone help?
> > Thanks Mark
Subject and
and Body of the message will be ignored.
Original Message
Sent: Wednesday, November 12, 2003 11:20 PM
Subject: RE: [noparse][[/noparse]basicstamps] Re: 7- Segment LED
> Am I correct to assume (bad word there) That the pins on that Led goes
> Mark
Original Message
> From: rescme1 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=5eE6ypc9_b34LT1S3KXNkHQF8PR5oEbdKIGP7OtHXh-KDH9xc2PVByWsnG7pO83TVjlxoiN478LtfJwA]alram2@h...[/url
> Resc.
> resistor on every
> Now one
> gound and
> ground is your
> Displayed on
> > your led display
> opposite. apply
> 5Vdc.
> resistor.
> ground is your
> Displayed on
> > your led display
> segments go
> > to which pin.
> engineering
> > is trial and error.
Original Message
> located
> Stamp
> Can
> > > someone help?
> > > Thanks Mark
> Subject and
I went to the web sight you posted for the 7 seg display. The device you have
is easy to hook up, but I need to know the exact part number you have. There
are four different 7 segs listed. Also, you can email me off list with your
phone number and I can call you. Or simply tell me the exact part number. Also,
do you have a digital volt meter (will explain later).
Ken
> Mark
jim http://www.geocities.com/jimforkin2003/
Original Message
From: MARK DEVINE [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=ja-MJeb-hFJW8TBcDxIbkFCwQToj79McgagsAiaCEmv4kROf2lEZrU0GzJR8ziFLARVtJThBoXg]mdevine@s...[/url
Sent: Wednesday, November 12, 2003 9:20 PM
Mark
Original Message
From: rescme1 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=RFdQ1eeGwYG2HNOcYGlHznPsEN4ATdg3mEakzbtqXt8S2ZeqLIsUHnOEQZMZJpAmWSUxQ1PIKvZujd7t0w]alram2@h...[/url
Resc.
resistor on every
Now one
gound and
ground is your
Displayed on
> your led display
opposite. apply
5Vdc.
resistor.
ground is your
Displayed on
> your led display
segments go
> to which pin.
engineering
> is trial and error.
Original Message
located
Stamp
Can
> > someone help?
> > Thanks Mark
Subject and
jim
Original Message
From: MARK DEVINE [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=bM-BBxoqDhux5HG6v3Bmc8FSaa7qsWCW7wkLH6cumj8EhYh-Ljs2LC6Q8DXpxA2tqd_yM8udYczZ4vM]mdevine@s...[/url
Sent: Wednesday, November 12, 2003 6:57 PM
someone help?
Thanks Mark
the data sheet, which was sent to the list in a recent message). Check the
data sheet yourself to see if this is clear there. It isn´t. My guess is
that yes, you read the pins as if it was a regular IC. But the data sheet is
not clear.
Regards.
Original Message
Sent: Thursday, November 13, 2003 11:58 AM
> do the words "data sheet" mean anything to you ??????
Original Message
> From: MARK DEVINE [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=j5JZDGxINLbtesu1AuIxElj4ivZEEvmKyFG5AQ2QXdXackDhY9EYQZ-FU44A8g4m6K4ZTk86qas_]mdevine@s...[/url
> Mark
Original Message
> From: rescme1 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=nuW9jxu9OEZBguQjOmvK8v5xdHg__wu3oMX1UALLJdSWd-AD0h7REv6-weGM0FD_ZHjWdIJPxKq3]alram2@h...[/url
> Resc.
> resistor on every
> Now one
> gound and
> ground is your
> Displayed on
> > your led display
> opposite. apply
> 5Vdc.
> resistor.
> ground is your
> Displayed on
> > your led display
> segments go
> > to which pin.
> engineering
> > is trial and error.
Original Message
> located
> Stamp
> Can
> > > someone help?
> > > Thanks Mark
> Subject and
right, pin 6 is upper right, pin 10 is upper left.
jim
Original Message
From: Pedro Drummond [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=wFoAGcfAvL3N-AS3b3L7Z7bzkJrK3Tu5zuOUD7HfzfghexRrvRlJKnwX7Xyu97QDNxMfv_THAY7vXpM]p.drummond@g...[/url
Sent: Thursday, November 13, 2003 12:00 PM
Subject: Re: [noparse][[/noparse]basicstamps] Re: 7- Segment LED
Jim, no need to get angry. His doubt is very understandable (he has checked
not clear.
Regards.
Original Message
Original Message
> From: MARK DEVINE [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=pXNkZOCsx6EqSuuS3OMnP5J0-VAWhtVKR1mzZDhpWf_1NYuxvgTKfrAnDyEPjmmoKPDlqNuskXt0F0tCoQ]mdevine@s...[/url
> Mark
Original Message
> From: rescme1 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=SDuW06iZO-yXqfoNAQQI5JgiOO0m1ij_WtKtj1YBnpEQWaBoe9oAXLQM2gHYPBPOZXeXY892e8t4rKY6Sg]alram2@h...[/url
> Resc.
> resistor on every
> Now one
> gound and
> ground is your
> Displayed on
> > your led display
> opposite. apply
> 5Vdc.
> resistor.
> ground is your
> Displayed on
> > your led display
> segments go
> > to which pin.
> engineering
> > is trial and error.
Original Message
> located
> Stamp
> Can
> > > someone help?
> > > Thanks Mark
> Subject and
