7- Segment LED — Parallax Forums
7- Segment LED
edited 2003-11-13 18:59 in General Discussion
I am using a PARA LIGHT C-5214 7 Segment LED. There are 5 Pins located
at the top and bottom of the device. I am trying to complete Stamp
works #8 but I can not seem to get the pin configuration right. Can
someone help?
Thanks Mark
    edited 2003-11-13 00:15
    do you know if it is a common anode or common cathode display?
    - to check this you will have to put a 150 ohm resistor on every
    pin of the display and 5Vdc applied all at once to every resistor. Now one
    by one remove 5Vdc and apply ground. if nothing happens remove the gound and
    replace 5Vdc and continue on to the next resistor.
    - if you light it up in this manner the pin tied to ground is your
    common cathode pin and the rest are anodes. you would have a 8 Displayed on
    your led display
    - if nothing happens you will have to to the opposite. apply
    ground to all the resistors and one by one remove ground and apply 5Vdc.
    remove the 5vdc replace ground and continue on to the next resistor.
    common anode pin and the rest are cathodes. you would have a 8 Displayed on
    your led display
    and from there if you get some results you can firgure out which segments go
    to which pin.
    i know this a long way but it works when experimenting. half of engineering
    is trial and error.
    lets see if this helps you.
    Sent: Wednesday, November 12, 2003 3:57 PM
    Subject: [noparse][[/noparse]basicstamps] 7- Segment LED
    > someone help?
    > Thanks Mark
    edited 2003-11-13 00:45
    Here is the data sheet(s) to the part in question, this should
    answer your question:
    http://www.para.com.tw/pdf/E-Display/E04-CA501X,CA521X.pdf
    If that link didn't work go to para's website and hunt it down.
    Resc.
    resistor on every
    Now one
    gound and
    ground is your
    Displayed on
    > your led display
    opposite. apply
    5Vdc.
    resistor.
    ground is your
    Displayed on
    > your led display
    segments go
    > to which pin.
    engineering
    > is trial and error.
    > From: "MARK DEVINE" <mdevine@s...>
    located
    Stamp
    Can
    > > someone help?
    > > Thanks Mark
    Subject and
    edited 2003-11-13 02:20
    Am I correct to assume (bad word there) That the pins on that Led goes
    1-5 and 6-10 on the other side like an IC?
    Mark
    From: rescme1 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=0NzIVQgk3t0PA4qF4j_UuqpZfVhoxSWpV2FQo61t2qNTPily4ZgGA6BIK-7lXHmgkhKA-p6B-OoCe3niRw]alram2@h...[/url
    Sent: Thursday, November 13, 2003 8:45 AM
    Subject: [noparse][[/noparse]basicstamps] Re: 7- Segment LED
    Resc.
    resistor on every
    Now one
    gound and
    ground is your
    Displayed on
    > your led display
    opposite. apply
    5Vdc.
    resistor.
    ground is your
    Displayed on
    > your led display
    segments go
    > to which pin.
    engineering
    > is trial and error.
    located
    Stamp
    Can
    > > someone help?
    > > Thanks Mark
    Subject and
    edited 2003-11-13 04:28
    If I were you I would test each pin/led with a resistor and a power supply.
    Sent: Wednesday, November 12, 2003 11:20 PM
    Subject: RE: [noparse][[/noparse]basicstamps] Re: 7- Segment LED
    > Mark
    > From: rescme1 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=5eE6ypc9_b34LT1S3KXNkHQF8PR5oEbdKIGP7OtHXh-KDH9xc2PVByWsnG7pO83TVjlxoiN478LtfJwA]alram2@h...[/url
    > Resc.
    > resistor on every
    > Now one
    > gound and
    > ground is your
    > Displayed on
    > > your led display
    > opposite. apply
    > 5Vdc.
    > resistor.
    > ground is your
    > Displayed on
    > > your led display
    > segments go
    > > to which pin.
    > engineering
    > > is trial and error.
    > located
    > Stamp
    > Can
    > > > someone help?
    > > > Thanks Mark
    > Subject and
    edited 2003-11-13 14:04
    Mark,
    I went to the web sight you posted for the 7 seg display. The device you have
    is easy to hook up, but I need to know the exact part number you have. There
    are four different 7 segs listed. Also, you can email me off list with your
    phone number and I can call you. Or simply tell me the exact part number. Also,
    do you have a digital volt meter (will explain later).
    Ken
    > Mark
    edited 2003-11-13 14:58
    do the words "data sheet" mean anything to you ??????
    jim http://www.geocities.com/jimforkin2003/
    From: MARK DEVINE [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=ja-MJeb-hFJW8TBcDxIbkFCwQToj79McgagsAiaCEmv4kROf2lEZrU0GzJR8ziFLARVtJThBoXg]mdevine@s...[/url
    Sent: Wednesday, November 12, 2003 9:20 PM
    Mark
    From: rescme1 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=RFdQ1eeGwYG2HNOcYGlHznPsEN4ATdg3mEakzbtqXt8S2ZeqLIsUHnOEQZMZJpAmWSUxQ1PIKvZujd7t0w]alram2@h...[/url
    Resc.
    resistor on every
    Now one
    gound and
    ground is your
    Displayed on
    > your led display
    opposite. apply
    5Vdc.
    resistor.
    ground is your
    Displayed on
    > your led display
    segments go
    > to which pin.
    engineering
    > is trial and error.
    located
    Stamp
    Can
    > > someone help?
    > > Thanks Mark
    Subject and
    edited 2003-11-13 15:10
    check out their web site for a data sheet. http://para.com.tw/
    jim
    From: MARK DEVINE [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=bM-BBxoqDhux5HG6v3Bmc8FSaa7qsWCW7wkLH6cumj8EhYh-Ljs2LC6Q8DXpxA2tqd_yM8udYczZ4vM]mdevine@s...[/url
    Sent: Wednesday, November 12, 2003 6:57 PM
    someone help?
    Thanks Mark
    edited 2003-11-13 16:59
    Jim, no need to get angry. His doubt is very understandable (he has checked
    the data sheet, which was sent to the list in a recent message). Check the
    data sheet yourself to see if this is clear there. It isn´t. My guess is
    that yes, you read the pins as if it was a regular IC. But the data sheet is
    not clear.
    Regards.
    Sent: Thursday, November 13, 2003 11:58 AM
    > From: MARK DEVINE [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=j5JZDGxINLbtesu1AuIxElj4ivZEEvmKyFG5AQ2QXdXackDhY9EYQZ-FU44A8g4m6K4ZTk86qas_]mdevine@s...[/url
    > Mark
    > From: rescme1 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=nuW9jxu9OEZBguQjOmvK8v5xdHg__wu3oMX1UALLJdSWd-AD0h7REv6-weGM0FD_ZHjWdIJPxKq3]alram2@h...[/url
    > Resc.
    > resistor on every
    > Now one
    > gound and
    > ground is your
    > Displayed on
    > > your led display
    > opposite. apply
    > 5Vdc.
    > resistor.
    > ground is your
    > Displayed on
    > > your led display
    > segments go
    > > to which pin.
    > engineering
    > > is trial and error.
    > located
    > Stamp
    > Can
    > > > someone help?
    > > > Thanks Mark
    > Subject and
    looking at the front of the display, pin one is lower left, pin 5 in lower
    right, pin 6 is upper right, pin 10 is upper left.
    jim
    From: Pedro Drummond [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=wFoAGcfAvL3N-AS3b3L7Z7bzkJrK3Tu5zuOUD7HfzfghexRrvRlJKnwX7Xyu97QDNxMfv_THAY7vXpM]p.drummond@g...[/url
    Sent: Thursday, November 13, 2003 12:00 PM
    Subject: Re: [noparse][[/noparse]basicstamps] Re: 7- Segment LED
    not clear.
    Regards.
    > From: MARK DEVINE [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=pXNkZOCsx6EqSuuS3OMnP5J0-VAWhtVKR1mzZDhpWf_1NYuxvgTKfrAnDyEPjmmoKPDlqNuskXt0F0tCoQ]mdevine@s...[/url
    > Mark
    > From: rescme1 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=SDuW06iZO-yXqfoNAQQI5JgiOO0m1ij_WtKtj1YBnpEQWaBoe9oAXLQM2gHYPBPOZXeXY892e8t4rKY6Sg]alram2@h...[/url
    > Resc.
    > resistor on every
    > Now one
    > gound and
    > ground is your
    > Displayed on
    > > your led display
    > opposite. apply
    > 5Vdc.
    > resistor.
    > ground is your
    > Displayed on
    > > your led display
    > segments go
    > > to which pin.
    > engineering
    > > is trial and error.
    > located
    > Stamp
    > Can
    > > > someone help?
    > > > Thanks Mark
    > Subject and
