dead BS2P24?
For a more elaborate project I had Parallax send me a BS2p, usually I use the
BS2.
Before I build a PC board to plug the little thing in I built the serial port
connection circuit (a DB9 plug and two capacitors, according to Parallax
documents) on my breadboard, connceted 5 V to VDD and ground to Vss and booted
up the DOS version of Stamp2p.
Unfortunately the program does not recognize my hardware and I don't know why.
The BS2p definetly is powered up, and my PC is definetly sending pulses, I can
see fleeting images on my scope, but something is wrong.
Does anybody have any idea what to test next?
TIA Uwe
BS2.
TIA Uwe
STAMP.EXE. If that works, you'll know your connection is intact.
-- Jon Williams
-- Applications Engineer, Parallax
-- Dallas Office
Original Message
From: othello159 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=7sivwsF8Flqh92Bq6e1NjH5-g6gtnUIRVjBrlGLgEB7KRJ9v3qxzc4J7pJhbhfAwK7mgvAxnZrQzk-y_8g]othello159@h...[/url
Sent: Wednesday, October 29, 2003 5:12 PM
To: basicstamps@yahoogroups.com
Subject: [noparse][[/noparse]basicstamps] dead BS2P24?
use the BS2.
port connection circuit (a DB9 plug and two capacitors, according to
Parallax documents) on my breadboard, connceted 5 V to VDD and ground to
Vss and booted up the DOS version of Stamp2p. Unfortunately the program
does not recognize my hardware and I don't know why. The BS2p definetly
is powered up, and my PC is definetly sending pulses, I can see fleeting
TIA Uwe
To UNSUBSCRIBE, just send mail to:
basicstamps-unsubscribe@yahoogroups.com
from the same email address that you subscribed. Text in the Subject
and Body of the message will be ignored.
Your use of Yahoo! Groups is subject to
http://docs.yahoo.com/info/terms/
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
permanently attached.
Are you suggesting to pull the processor from the OEM board? What are the pin
numbers for SOUT, SIN, ATN and VSS, VDD?
--- In basicstamps@yahoogroups.com, "Jon Williams" <jwilliams@p...> wrote:
> Replace the BS2p with a known working BS2 and try to talk to it with
> -- Jon Williams
> -- Dallas Office
Original Message
> From: othello159 [noparse][[/noparse]mailto[noparse]:o[/noparse]thello159@h...]
> use the BS2.
> TIA Uwe
> abuse@p...
an OEM board will not work.
-- Jon Williams
-- Parallax
Original Message
From: othello159 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=26X-xeHHYW9cNOPkciWolAs2LM4vBJTpwMEuCT0m2OB35x5cS8uszQMvzE0qTJje47DGAR6Gdw08u_Yx7RquNz8]othello159@h...[/url
Sent: Wednesday, October 29, 2003 7:51 PM
Subject: [noparse][[/noparse]basicstamps] Re: dead BS2P24?
Yes, good idea, except my BS2's are the OEM version, they have the DB9
business permanently attached.
the pin numbers for SOUT, SIN, ATN and VSS, VDD?
> -- Jon Williams
> -- Dallas Office
Original Message
> use the BS2.
> serial port connection circuit (a DB9 plug and two capacitors,
> according to Parallax documents) on my breadboard, connceted 5 V to
> VDD and ground to Vss and booted up the DOS version of Stamp2p.
> know why. The BS2p definetly is powered up, and my PC is definetly
> sending pulses, I can see fleeting images on my scope, but something
> is wrong.
> TIA Uwe
> abuse@p...
abuse@p....
pin 6 to pin 7. This is what the compiler
uses to detect if the cable is plugged in.
So you need -- wired straight through:
2, 3 -- TX and RX
4 -- DTR, used to reset the stamp
5 -- Ground
6 -- RTS
7 -- CTS -- RTS and CTS are wired together,
so the compiler can detect connection.
--- In basicstamps@yahoogroups.com, "othello159" <othello159@h...>
I use the BS2.
don't know why.
pulses, I can see fleeting images on my scope, but something is wrong.
> TIA Uwe
