dead BS2P24? — Parallax Forums
dead BS2P24?
edited 2003-10-30 15:36 in General Discussion
For a more elaborate project I had Parallax send me a BS2p, usually I use the
BS2.
Before I build a PC board to plug the little thing in I built the serial port
connection circuit (a DB9 plug and two capacitors, according to Parallax
documents) on my breadboard, connceted 5 V to VDD and ground to Vss and booted
up the DOS version of Stamp2p.
Unfortunately the program does not recognize my hardware and I don't know why.
The BS2p definetly is powered up, and my PC is definetly sending pulses, I can
see fleeting images on my scope, but something is wrong.
Does anybody have any idea what to test next?
TIA Uwe
    edited 2003-10-30 00:14
    Replace the BS2p with a known working BS2 and try to talk to it with
    STAMP.EXE. If that works, you'll know your connection is intact.
    -- Jon Williams
    -- Dallas Office
    From: othello159 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=7sivwsF8Flqh92Bq6e1NjH5-g6gtnUIRVjBrlGLgEB7KRJ9v3qxzc4J7pJhbhfAwK7mgvAxnZrQzk-y_8g]othello159@h...[/url
    Sent: Wednesday, October 29, 2003 5:12 PM
    Subject: [noparse][[/noparse]basicstamps] dead BS2P24?
    use the BS2.
    port connection circuit (a DB9 plug and two capacitors, according to
    Parallax documents) on my breadboard, connceted 5 V to VDD and ground to
    Vss and booted up the DOS version of Stamp2p. Unfortunately the program
    does not recognize my hardware and I don't know why. The BS2p definetly
    is powered up, and my PC is definetly sending pulses, I can see fleeting
    TIA Uwe
    Your use of Yahoo! Groups is subject to
    This message has been scanned by WebShield. Please report SPAM to
    abuse@p....
    edited 2003-10-30 01:51
    Yes, good idea, except my BS2's are the OEM version, they have the DB9 business
    permanently attached.
    Are you suggesting to pull the processor from the OEM board? What are the pin
    numbers for SOUT, SIN, ATN and VSS, VDD?
    > -- Jon Williams
    > -- Dallas Office
    > From: othello159 [noparse][[/noparse]mailto[noparse]:o[/noparse]thello159@h...]
    > use the BS2.
    > TIA Uwe
    > abuse@p...
    edited 2003-10-30 02:33
    No. If you are using a BS2p module, then dropping in just the PIC from
    an OEM board will not work.
    -- Jon Williams
    -- Parallax
    From: othello159 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=26X-xeHHYW9cNOPkciWolAs2LM4vBJTpwMEuCT0m2OB35x5cS8uszQMvzE0qTJje47DGAR6Gdw08u_Yx7RquNz8]othello159@h...[/url
    Sent: Wednesday, October 29, 2003 7:51 PM
    Subject: [noparse][[/noparse]basicstamps] Re: dead BS2P24?
    business permanently attached.
    the pin numbers for SOUT, SIN, ATN and VSS, VDD?
    > -- Jon Williams
    > -- Dallas Office
    > use the BS2.
    > serial port connection circuit (a DB9 plug and two capacitors,
    > according to Parallax documents) on my breadboard, connceted 5 V to
    > VDD and ground to Vss and booted up the DOS version of Stamp2p.
    > know why. The BS2p definetly is powered up, and my PC is definetly
    > sending pulses, I can see fleeting images on my scope, but something
    > is wrong.
    > TIA Uwe
    > abuse@p...
    abuse@p....
    It sounds like you forgot to loop the DB-9
    pin 6 to pin 7. This is what the compiler
    uses to detect if the cable is plugged in.
    So you need -- wired straight through:
    2, 3 -- TX and RX
    4 -- DTR, used to reset the stamp
    5 -- Ground
    6 -- RTS
    7 -- CTS -- RTS and CTS are wired together,
    so the compiler can detect connection.
    --- In basicstamps@yahoogroups.com, "othello159" <othello159@h...>
    I use the BS2.
    don't know why.
    pulses, I can see fleeting images on my scope, but something is wrong.
    > TIA Uwe
