ultra sonic range finder
my question is can basic stamp rev D support the rangefinder and have the
commands
Do you Yahoo!?
The New Yahoo! Shopping - with improved product search
commands
Do you Yahoo!?
inteface with the Devantech SRF04.
-- Jon Williams
-- Applications Engineer, Parallax
-- Dallas Office
Original Message
From: Kyle Cooper [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=OUEmw3DccrRHDd0OZn4dD9qY8xHcnbrFakQBK_I54_sTUDysilpcnrznX7kHJ2SjxpBY36_YZY5r3R2w]crazykurby@y...[/url
Sent: Wednesday, October 22, 2003 7:22 PM
To: basicstamps@yahoogroups.com
Subject: [noparse][[/noparse]basicstamps] ultra sonic range finder
the commands
Do you Yahoo!?
To UNSUBSCRIBE, just send mail to:
basicstamps-unsubscribe@yahoogroups.com
from the same email address that you subscribed. Text in the Subject
and Body of the message will be ignored.
Your use of Yahoo! Groups is subject to
http://docs.yahoo.com/info/terms/
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
from the SRF04 using a gate with an r/c network. This gave the stamp the
necessary uS's to advance to the command to read the return pulse. I only
needed to read relative distances, not absolute, so it worked fine for me.
actually, since the delay is constant, you could probably factor that into
the distance calc's to get the true distance, ofcourse you would be
sacrificing short distance readings.
d...
Original Message
> From: Jon Williams [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=tHsL0RjN3X_jf2s9XPbKNojio9RXtfCXqD5bziQMVHrK9LnGC2R7uDxFcwAq5xC6usVfT3hLsyUUjyaP]jwilliams@p...[/url
> Sent: Thursday, October 23, 2003 4:57 AM
> Subject: RE: [noparse][[/noparse]basicstamps] ultra sonic range finder
> The BS1 has PULSOUT and PULSIN commnands, but is not fast enough to
> -- Jon Williams
> -- Dallas Office
Original Message
> From: Kyle Cooper [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=Ak7xoo4oB2P9OtNJfmO20o448z5D5l46Vdjn3ZSMUHlPlnszFjTFxAGuSmpmvAlp_n3NCUO9xtc9Ku8pT6Q]crazykurby@y...[/url
> the commands
> Do you Yahoo!?
> abuse@p....
> Subject and Body of the message will be ignored.
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
schematic and bit of code in the files section. The BS1 will be
reintroduced soon (Rev Dx and a new BOE-type board) and your efforts
will probably benefit others.
-- Jon Williams
-- Dallas Office
Original Message
From: Dave [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=inqFNSUjpsqeDt0It_BO7W86U3FF7Au178oINVDQFp-Va3sukQEUGQCmyU753jUxLWwsYrOWpOCw3BTnK72AGLIQ]dokagaki@w...[/url
Sent: Thursday, October 23, 2003 9:37 AM
I got around that problem by introducing a small delay in the return
pulse from the SRF04 using a gate with an r/c network. This gave the
stamp the necessary uS's to advance to the command to read the return
pulse. I only needed to read relative distances, not absolute, so it
worked fine for me. actually, since the delay is constant, you could
probably factor that into the distance calc's to get the true distance,
ofcourse you would be sacrificing short distance readings.
d...
Original Message
> From: Jon Williams [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=JKHyL2MpIcMIHHKsKs6Y5RI7nGXLMXCx1E5_vu1_NCaLPniO2GQ-cHcrJXzmfD0kWoHrAa8_sc3CwsXRbGpbcw]jwilliams@p...[/url
> -- Jon Williams
> -- Dallas Office
Original Message
> From: Kyle Cooper [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=6hmRcjXL6_3f1RijaBexONtVTtK1hTuxDsJ52vS3dWJpRF7MsHkt4BElr1nUUji72R19mBptXfBf53o]crazykurby@y...[/url
> the commands
> Do you Yahoo!?
> abuse@p....
abuse@p....
Dave <dokagaki@w...> wrote:I got around that problem by introducing
a small delay in the return pulse
d...
Original Message
> From: Jon Williams [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=vVlkHu9EcU5TGRPHG6VVt3XPnClfivVx3hfR340lZvzeDZWsAC0q4Z_upe96XuPWjM2JMVRxiZcUn2b1]jwilliams@p...[/url
> -- Jon Williams
> -- Dallas Office
Original Message
> From: Kyle Cooper [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=ig0suUyeVvGtJA81MK8pam-OwHnzNm-9MwcO3qaXGIsSEIICdblTSPsnySlF8grrgf8CTmYE2HTIBish]crazykurby@y...[/url
> the commands
> Do you Yahoo!?
> abuse@p....
from the same email address that you subscribed. Text in the Subject and Body of
Do you Yahoo!?
Jon Williams <jwilliams@p...> wrote:The BS1 has PULSOUT and PULSIN
-- Jon Williams
-- Dallas Office
Original Message
From: Kyle Cooper [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=MAtQuwMjneKroHLSdIdQ2qdr-1gOhR7cMN-_ns0bE3gPrviyPsxwumJ9r9wSzzdGcqXXkpYii98eoQU]crazykurby@y...[/url
the commands
Do you Yahoo!?
abuse@p....
Do you Yahoo!?
sorry this took so long to post; lots of things going on. this kludge is
actually pretty simple (sorry about the exceptionally bad graphics...):
| ping--> |
p0 |
>|ping
"bs/1" | | "SRF04"
|echo
| \ | AND )
| R= 200 / | gate ))
| - c=10uF |
| V |
| gnd |
| <---echo |
p1 |<
The main problem is that the bs/1 is too slow to catch the rising edge of
the "echo" pulse from the '04 after sending the "ping" command; by the time
the stamp advances to the command to read the echo, the rising edge has
already happened, so the pulsin command doesn't have the transition it needs
to start timing. (sorry if this is all old stuff to people; it helps me
remember what I was doing-- getting old and stuff...)
The r/c network and the gate provide the necessary delay (about 200uS).
When the echo pulse goes high, the gate doesn't pass the signal on to p1 of
the stamp until the the delay has passed.
There are no significant changes to the controlling software beyond the
recognition that the stamp will not be able to resolve distances closer than
about 3 inches (73uS/inch, 200uS delay).
Hope someone finds this helpful.
d...
Original Message
> From: Jon Williams [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=L9_ZPO-1EVUTm3_bd40wnt3bID6zKnJGxtOzEW8H8hxhy2VeEJXStF-60oc8KQBdaPedscLubMd5XQ4Aaena5w]jwilliams@p...[/url
> Sent: Thursday, October 23, 2003 8:13 AM
> Excellent -- we're pleased you got it to work. Perhaps you could post a
> -- Jon Williams
> -- Dallas Office
Original Message
> From: Dave [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=HeVjtSS11LIifCmW1bLFkAKsyIl3oZ4WotBq-d4TDp64kmWCibMfX2MSnxBAlEnN3AgTMpJB2I5YMdIYP9_bTA]dokagaki@w...[/url
> d...
Original Message
> > -- Jon Williams
> > -- Dallas Office
Original Message
> > From: Kyle Cooper [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=5oeNxXc17qMXTHIBFX4ad_QIiezrRBxa81cWd2StU2lgC88WohAMg6NDV9l746BDBLn3eNTdLnBqpWZhjx8]crazykurby@y...[/url
> > the commands
> > Do you Yahoo!?
> > abuse@p....
> abuse@p....
