Combining bits into a nib
Hi All,
I posted this yesterday, but didn't see it show up. I am being mailbombed
for some reason, so my mail has been weird. Here goes again:
I have run into this problem before, and never found a good way of doing it.
I need this code to be tight, so I ask here for the best method to solve
this.
I want to check the status of 4 I/O pins, and then combine the results into
one variable i.e. 0000, 0101, etc. I have to use pins X3-X6 for this,
so I cant use INA. Any easy and fast way to do this?
Jonathan
www.madlabs.info
this.
Jonathan
www.madlabs.info
myNib = INL >> 3
-- Jon Williams
-- Applications Engineer, Parallax
-- Dallas Office
Original Message
From: Jonathan Peakall [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=x0xh9laln35A6l_jc-uzW03-T5A-mpS3F8QWRC8V4QCmTaXTGGlhUN0d_LExNXqUx1qLoq9NGwM5OgkI]jpeakall@m...[/url
Sent: Saturday, October 11, 2003 9:17 AM
To: basicstamps@yahoogroups.com
Subject: [noparse][[/noparse]basicstamps] Combining bits into a nib
Hi All,
mailbombed for some reason, so my mail has been weird. Here goes again:
it. I need this code to be tight, so I ask here for the best method to
solve this.
into one variable i.e. 0000, 0101, etc. I have to use pins X3-X6 for
this, so I cant use INA. Any easy and fast way to do this?
Jonathan
www.madlabs.info
To UNSUBSCRIBE, just send mail to:
basicstamps-unsubscribe@yahoogroups.com
from the same email address that you subscribed. Text in the Subject
and Body of the message will be ignored.
Your use of Yahoo! Groups is subject to
http://docs.yahoo.com/info/terms/
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
jpeakall@m... writes:
Jonathan
__________________________
Jonathan,
I don't use the stamp much these days so my thought might be off, but here it
goes......
It does not look like the BS2 has a Rotate Right command, so maybe this will
work if you have two open output pins.
1) Read INL (pins 0 through 7)
2) SHIFTOUT - shift LSB first and shift only 3 bits (0, 1 & 2)
3) Then read the low nibble of the shifted out variable
It would be really cool if the stamp would allow you to not specify a Dpin
(data pin) or Cpin (clock pin), then you would not need to waste two output
pins, but I doubt the program would allow such......syntax error.
OR.....is there a rotate right command anybody? Have not seen it.
Are you going to use the numerical result directly, like flash a light the
number of times indicated by the nibble? If you are going to use a lookup table
of some sort based on the value of the nibble, an alternate approach would be
to;
1) Read INL
2) Mask the result with %01111000
3) Do your lookup table with the numerical result returned
Ken
jwilliams@p... writes:
Try this, Jonathat:
myNib = INL >> 3
-- Jon Williams
Jon,
is ">>" rotate right?
Ken
-- Jon
Original Message
From: smartdim@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=P43JeKjVOE5sHER1RveWGTPt3VV3DOwGJ2APm9iScIL4NIPjBtzZe20r5Mi2dxIay09Dt13DDPg]smartdim@a...[/url
Sent: Saturday, October 11, 2003 11:24 AM
Subject: Re: [noparse][[/noparse]basicstamps] Combining bits into a nib
In a message dated 10/11/2003 7:35:25 AM Pacific Daylight Time,
Try this, Jonathat:
myNib = INL >> 3
-- Jon Williams
Jon,
Ken
abuse@p....
Perfect, thanks!
Jonathan
www.madlabs.info
Original Message
To: <basicstamps@yahoogroups.com>
Sent: Saturday, October 11, 2003 7:34 AM
Subject: RE: [noparse][[/noparse]basicstamps] Combining bits into a nib
> Try this, Jonathat:
> myNib = INL >> 3
> -- Jon Williams
> -- Dallas Office
Original Message
> From: Jonathan Peakall [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=biRQuHbmRJhR2WlncRgGOTLC28fbhwEAJdKOB922VyQExrYIN70EUkKSXqNwuBmsyBpoxiNQnAx3ov4]jpeakall@m...[/url
> Hi All,
> solve this.
> Thanks,
> Jonathan
> www.madlabs.info
> abuse@p....
> from the same email address that you subscribed. Text in the Subject and
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
