Combining bits into a nib — Parallax Forums
edited 2003-10-11 19:42 in General Discussion
Hi All,
I posted this yesterday, but didn't see it show up. I am being mailbombed
for some reason, so my mail has been weird. Here goes again:
I have run into this problem before, and never found a good way of doing it.
I need this code to be tight, so I ask here for the best method to solve
this.
I want to check the status of 4 I/O pins, and then combine the results into
one variable i.e. 0000, 0101, etc. I have to use pins X3-X6 for this,
so I cant use INA. Any easy and fast way to do this?
Jonathan
www.madlabs.info
    edited 2003-10-11 15:34
    Try this, Jonathat:
    myNib = INL >> 3
    -- Jon Williams
    -- Dallas Office
    From: Jonathan Peakall [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=x0xh9laln35A6l_jc-uzW03-T5A-mpS3F8QWRC8V4QCmTaXTGGlhUN0d_LExNXqUx1qLoq9NGwM5OgkI]jpeakall@m...[/url
    Sent: Saturday, October 11, 2003 9:17 AM
    Subject: [noparse][[/noparse]basicstamps] Combining bits into a nib
    Hi All,
    mailbombed for some reason, so my mail has been weird. Here goes again:
    it. I need this code to be tight, so I ask here for the best method to
    solve this.
    into one variable i.e. 0000, 0101, etc. I have to use pins X3-X6 for
    this, so I cant use INA. Any easy and fast way to do this?
    Jonathan
    www.madlabs.info
    Your use of Yahoo! Groups is subject to
    This message has been scanned by WebShield. Please report SPAM to
    abuse@p....
    edited 2003-10-11 17:22
    In a message dated 10/11/2003 7:13:51 AM Pacific Daylight Time,
    jpeakall@m... writes:
    Jonathan
    __________________________
    Jonathan,
    I don't use the stamp much these days so my thought might be off, but here it
    goes......
    It does not look like the BS2 has a Rotate Right command, so maybe this will
    work if you have two open output pins.
    1) Read INL (pins 0 through 7)
    2) SHIFTOUT - shift LSB first and shift only 3 bits (0, 1 & 2)
    3) Then read the low nibble of the shifted out variable
    It would be really cool if the stamp would allow you to not specify a Dpin
    (data pin) or Cpin (clock pin), then you would not need to waste two output
    pins, but I doubt the program would allow such......syntax error.
    OR.....is there a rotate right command anybody? Have not seen it.
    Are you going to use the numerical result directly, like flash a light the
    number of times indicated by the nibble? If you are going to use a lookup table
    of some sort based on the value of the nibble, an alternate approach would be
    to;
    1) Read INL
    2) Mask the result with %01111000
    3) Do your lookup table with the numerical result returned
    Ken
    edited 2003-10-11 17:23
    In a message dated 10/11/2003 7:35:25 AM Pacific Daylight Time,
    jwilliams@p... writes:
    Try this, Jonathat:
    myNib = INL >> 3
    -- Jon Williams
    Jon,
    is ">>" rotate right?
    Ken
    edited 2003-10-11 17:32
    >> is shift right (lsb is lost, msb becomes 0).
    -- Jon
    From: smartdim@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=P43JeKjVOE5sHER1RveWGTPt3VV3DOwGJ2APm9iScIL4NIPjBtzZe20r5Mi2dxIay09Dt13DDPg]smartdim@a...[/url
    Sent: Saturday, October 11, 2003 11:24 AM
    Subject: Re: [noparse][[/noparse]basicstamps] Combining bits into a nib
    Try this, Jonathat:
    myNib = INL >> 3
    -- Jon Williams
    Jon,
    Ken
    abuse@p....
    Jon,
    Perfect, thanks!
    Jonathan
    www.madlabs.info
    Sent: Saturday, October 11, 2003 7:34 AM
    Subject: RE: [noparse][[/noparse]basicstamps] Combining bits into a nib
    > Try this, Jonathat:
    > myNib = INL >> 3
    > -- Jon Williams
    > -- Dallas Office
    > From: Jonathan Peakall [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=biRQuHbmRJhR2WlncRgGOTLC28fbhwEAJdKOB922VyQExrYIN70EUkKSXqNwuBmsyBpoxiNQnAx3ov4]jpeakall@m...[/url
    > Hi All,
    > solve this.
    > Thanks,
    > Jonathan
    > www.madlabs.info
    > abuse@p....
