Encoder wheel?
I'm not sure this is the correct name but I'd like to find one of
the wheels with hundreds of tiny holes around the edge and an
optical sensor that counts the holes go by.
I have seen these in inkjet printers.
What are they called and where can I get one with the sensor?
- Robert
(No I don't mean rodents with various chemical addictions - keep focused,
people!)
Original Message
To: <basicstamps@yahoogroups.com>
Sent: Thursday, September 25, 2003 9:42 PM
Subject: [noparse][[/noparse]basicstamps] Encoder wheel?
> Thanks
> To UNSUBSCRIBE, just send mail to:
> from the same email address that you subscribed. Text in the Subject and
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
> Thanks
There are lots of variations of the wheel.
one is a clear plastic sheet with laser printing black areas. you
may get more holes per revolution that way.
another method is to use 2 wheels, or one wheel with 2 prints so that
you can tell which way you are moving.
And there even multiple printings for higher resoluiton.
And expired mouse is the easiest place to start.
Dave
http://www.seattlerobotics.org/encoder/200010/dead_reckoning_article.htm
l )
Original Message
From: ch2surf [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=Bkfoz0xF67VMEZe8pjey2RwA1PbnEGCkpD4NnJayjvMIzn9Q0yTct28BSKFtcaTfLod_UwL70vwllnm7p7aMCc0]sachacrompton@v...[/url
Sent: Thursday, September 25, 2003 10:42 PM
To: basicstamps@yahoogroups.com
and Body of the message will be ignored.
--- In basicstamps@yahoogroups.com, "Bryan Smith" <bsmith@w...>
wrote:
> Check out this site: (
htm
> l )
l
Original Message
From: ch2surf [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=q-b5sMNqh4M9rNaYY944kkyqez7Qo-owpSA3ZV7jAk75iVrivCPw7HSu_u8QWcjT5AY1QZ0FDrtRVENctcO_kQ]sachacrompton@v...[/url
Sent: Friday, September 26, 2003 3:29 PM
Subject: [noparse][[/noparse]basicstamps] Re: Encoder wheel?
The link doesn't work. Can you please correct it?
htm
> l )
like a clear plastic to it. It puszzled me when I started designing
encoders. The real effective one use solid material with holes. A real
good method is using a fiber glass PCB and etch your encoder on it.
The process is the same as making a photo etch PCB. The etched portion
would look transparent to the opto coupler.
Cheers,
- Johari Aziz
--- In basicstamps@yahoogroups.com, "Dave Mucha" <davemucha@j...> wrote:
> --- In basicstamps@yahoogroups.com, "ch2surf" <sachacrompton@v...>
> > Thanks
> Dave
> Thanks
> htm
> > l )
Worked for me.
200010/dead_reckoning_article.html
cut and paste, don't forget it ends in html
HREF="www.automationdirect.com">www.automationdirect.com</A>
They have glass wheels with from 100 to 2500 lines of resolution.
Hope this helps.
Alan Bradford
Plasma Technologies
sensors and can make your own mounts, I have a cheaper source for you.
> You can get Encoders from <A
functions built into stamp reading protocols. Or is this something you have
to write into the BS app itself?
Mike Sokol
www.modernrecording.com
mikes@m...
" One should not increase, beyond what is necessary,
the number of entities required to explain anything"...
-William of Occam-
Original Message
Sent: Friday, September 26, 2003 8:52 AM
> > Thanks
> Dave
<mikes@m...> wrote:
> On that note, I'm curious if there's any gray code to binary
conversion
you have
Need multiple sensors and a wheel with multiple levels. the grey
code is not that hard, but it does take some programming, We
discussed it on the list about a year or so ago. IIRC, Check for a
post from Tracy Allen (surprise, surprise).
Dave
