Parallax - New! Stamp PLC
New! Stamp PLC
#30064 $199
Hello Everyone,
Parallax has teamed up with Lawicel HB of Sweden to present you with an
industrial solution; the Stamp PLC. The Stamp PLC is a Program Logic
Controller that is perfectly sized (and priced) for automating small
machines. This merging of expertise has delivered a PLC that is ideal
for the small-scale PLC market. A 24-pin BASIC Stamp or Javelin Stamp is
required (sold separately).
Here is a list of primary features:
1) 8 Digital Inputs are grouped together courtesy of an on-board shift
register. BASIC Stamps and the Javelin Stamp have built-in commands to
read these with ease. Two additional digital inputs are read directly by
the Stamp. All inputs are optically isolated.
2) 8 Digital Outputs are optically isolated, electrically and thermally
protected.
3) Installing an optional A/D converter (sold separately #604-00026)
into its socket adds four analog input channels. Each channel can be
independently configured as 4-20mA, 0-5 VDC, -5 to +5 VDC, -10 to +10
VDC, and has 12-bits of resolution. Front Panel LEDs indicate the
status of all ten inputs and all eight outputs via a light-pipe array.
4) Heavy-duty power supply has built-in noise protection. RS-232 Serial
Port Once programming is completed, the on-board serial port can be used
to send and received data at any baud rate between 300-50K Baud.
5) 24-pin socket accommodates any 24-pin BASIC Stamp or Javelin Stamp
(both sold sepatately). This means that this PLC can do virtually
anything that your chosen Stamp can perform. Logic functions, numerical
computation, conditional branching, even non-volatile memory for
data-logging.
For ordering information and for complete specifications, please visit
this link: http://www.parallax.com/detail.asp?product_id=30064
Sincerely,
Erik Wood
ewood@p...
599 Menlo Dr. Ste. #100
Rocklin, CA 95765
www.parallax.com
New! Stamp PLC
#30064 $199
Hello Everyone,
protected.
data-logging.
Sincerely,
Erik Wood
ewood@p...
Rocklin, CA 95765
www.parallax.com
I ran a test and it works fine on our end.
If you're using less than Netscape v6.0 that may be the problem.
I'll email the documentation to you off list and see if there are any
other possible errors.
Erik Wood
ewood@p...
599 Menlo Dr., Suite #100
Rocklin, CA 95765
(916) 624-8003 Fax
(888) 512-1024
www.parallax.com
Original Message
From: goflo@p... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=15vXqB1X4O0C6ssPCC0cZVRmCVRtK9hUjSPoBcn8tIHirXkb9lL6IA4A4s_WBCl2RNLBp4qNDjyxRg]goflo@p...[/url
Sent: Thursday, September 25, 2003 3:35 PM
To: basicstamps@yahoogroups.com
Subject: Re: [noparse][[/noparse]basicstamps] Parallax - New! Stamp PLC
Hi Eric -
The link you mention works, but once you get there
the pdf link to specs does'nt. Looks like a great
product.
Jack
To UNSUBSCRIBE, just send mail to:
basicstamps-unsubscribe@yahoogroups.com
from the same email address that you subscribed. Text in the Subject
and Body of the message will be ignored.
Your use of Yahoo! Groups is subject to
http://docs.yahoo.com/info/terms/
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
product.
Jack
Time for an upgrade!
best regards, Jack
Erik Wood wrote:
> Hi Jack,
Is there a larger picture available than the little bitty one on the
website?
amg
On Thu, 25 Sep 2003 14:05:54 -0700 "Erik Wood" <ewood@p...>
writes:
> New! Stamp PLC
> #30064 $199
> Hello Everyone,
> an
> Logic
> small
> ideal
> Stamp is
________________________________________________________________
The best thing to hit the internet in years - Juno SpeedBand!
Surf the web up to FIVE TIMES FASTER!
Only $14.95/ month - visit www.juno.com to sign up today!
Yes, here is a larger picture
http://www.parallax.com/images/prod_jpg/30064_3views.jpg
Note on finding larger images at www.parallax.com
We maintain larger images of nearly all products on the web site. In
order to find the picture, you must access the product via the product
search function "Products & Part #'s". If you click on the "Go" button
without even entering information in the field box, you'll find nearly
400 products. By clicking on each individual thumb image that is
presented in the search results, you will see a large jpg image.
Enjoy,
Erik Wood
ewood@p...
Rocklin, CA 95765
(916) 624-8003 Fax
(888) 512-1024
www.parallax.com
Original Message
From: amg amg [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=tWcfZRab956b1i4uYdCCDeUtaBp2GxTLtDsrdwPYX4cEFP9OEAT7udJ83iWkG4YqlkizwahK5IzamHAxL3iZ_noZmg]controlsdude2000@j...[/url
Sent: Friday, September 26, 2003 10:22 AM
Erik,
website?
amg
writes:
> New! Stamp PLC
> #30064 $199
> Hello Everyone,
> an
> Logic
> small
> ideal
> Stamp is
The best thing to hit the internet in years - Juno SpeedBand! Surf the
web up to FIVE TIMES FASTER! Only $14.95/ month - visit www.juno.com to
sign up today!
abuse@p....
