Cheap LCD Displays?
Hello Group, I was wondering if anyone had tried generating caller ID tones
using the Basic Stamp 2?
Wal Mart sell fully functional caller ID boxes for about $8.00 Canadian. If the
tones could be generated, maybe the caller ID circuitry and LCD's could be used
as very inexpensive output devices for stamp projects? Failing that, it might
just be fun to send false caller ID data to friends over the phone!
Scott.
Scott.
Looks like most use the 44780 controller which you can use the EDE
LCD to serial chip with these. They have 4X40 with LED backlight for
$29 bux which ain't too bad.
Jason
--- In basicstamps@yahoogroups.com, "Scott Lawson" <slawson@a...>
ID tones using the Basic Stamp 2?
Canadian. If the tones could be generated, maybe the caller ID
circuitry and LCD's could be used as very inexpensive output devices
for stamp projects? Failing that, it might just be fun to send false
> Scott.
> All Electronics just got in a bunch of different displays recently.
for
> Jason
got a link for the EDE chip ?
Dave
> Jason
You might look at my new LCD #105 kit. In addition to providing the
serial LCD functions with a rich command set, it also provides two
10-bit A/D, two TTL inputs, two TTL outputs, a counter and two runs to
Dallas DS1820s. Each run can accommodate up to 16 DS1820s with a
maximum of 200 feet of cable. $12.95.
This can be purchased with a Truly 20 X 4 LCD with LED backlight for
$24.95.
http://www.phanderson.com/lcd105.html
Peter H Anderson, http://www.phanderson.com
204A for $7 (supposed to be 44780 compatible).
http://www.halted.com/cgi-local/SoftCart.exe/cgi-local/smpagegen.exe?U+scstore+g\
vjb3835ff4fce4f+-c+scstore.cfg+-p+19399
elfa
--- Dave Mucha <davemucha@j...> wrote:
> --- In basicstamps@yahoogroups.com, "jbirnsch"
> displays recently.
> can use the EDE
> LED backlight
> for
> > Jason
> Dave
> To UNSUBSCRIBE, just send mail to:
> from the same email address that you subscribed.
> Text in the Subject and Body of the message will be
> ignored.
> Your use of Yahoo! Groups is subject to
> http://docs.yahoo.com/info/terms/
__________________________________
Do you Yahoo!?
Yahoo! SiteBuilder - Free, easy-to-use web site design software
http://sitebuilder.yahoo.com
a 4x40 is electrically 2 2x40 displays in one package.
Does Tanner's have a websight??? Kind of a long drive from WI.
Dave,
For the EDE702 serial LCD IC go to www.elabinc.com.
Jason
--- In basicstamps@yahoogroups.com, Bill Boyer <daweasel@s...> wrote:
> Keep shopping. Tanner's (Dallas, TX) had them for $9.95. Just
remember,
recently.
EDE
for
sales and usually carries the same stuff at a similar price.
> remember,
> recently.
> EDE
> for
But you have to call to see what they have at the moment.
www.allelectronics.com
www.bgmicro.om
www.jameco.com
www.kronosrobotics.com
they all sell inexpensive LCD's too.
Original Message
From: jbirnsch [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=YVBlzm2wIx1sp7hl9EyNBUWr9nZK3gtDA-4GpP2ByT2ZotDiAjU1MUaTBj5Ld6oO9w-_DVyG6g]jbirnsch@v...[/url
Sent: Tuesday, September 16, 2003 11:20 PM
To: basicstamps@yahoogroups.com
Subject: [noparse][[/noparse]basicstamps] Re: Cheap LCD Displays?
Bill,
Dave,
Jason
remember,
recently.
EDE
for
from the same email address that you subscribed. Text in the Subject
and Body of the message will be ignored.
may have korean characters too though.--- On Wed 09/17, Bill Boyer <
daweasel@s... > wrote:
From: Bill Boyer [noparse]/noparse]mailto: [url=http://forums.parallaxinc.com/group/basicstamps/post?postID=D8xX7MXLNk6xjcASCGKDfKz-OTa2L79pDcm7lUN584ii-8wFZNU0NoK9gIn7b0Ug9F1ubT4mDAeY06OxXtc]daweasel@s...[/urlTo:
basicstamps@y...: 17 Sep 2003 06:09:08 -0500Subject: Re:
[noparse][[/noparse]basicstamps] Re: Cheap LCD Displays?They don't do mail-order, but BG Micro,
also in Dallas, does onlinesales and usually carries the same stuff at a similar
price.> > Does Tanner's have a websight??? Kind of a long drive from
WI.> > Keep shopping. Tanner's (Dallas, TX) had them for $9.95. Just >
remember,> > a 4x40 is electrically 2 2x40 displays in one package. >
> recently. > > > Looks like most use the 44780 controller which you
can use the > EDE > > > LCD to serial chip with these. They have
4X40 with LED backlight > for > > > $29 bux which ain't too bad.To
UNSUBSCRIBE, just send mail to:basicstamps-unsubscribe@y... the
same email address that you subscribed. Text in the Subject and Body of the
message will be ignored.Your use of Yahoo! Groups is subject to
_______________________________________________
Join Excite! - http://www.excite.com
The most personalized portal on the Web!
