"BACKPACK" LCD thingy
Hey guys,
I thought I had, either heard here OR, saw on the Net, something about an
"LCD BACKPACK" that would attach to your normal parallel LCD and you'd then
only have to send serial data. (hope that all makes sense!).
Where does one find these?
SB
SB
the first entry is an 'LCD Backpack'. $29.00.
--- In basicstamps@yahoogroups.com, "Brady,Steven [noparse][[/noparse]PYR]"
<steven.brady2@e...> wrote:
> Hey guys,
about an
you'd then
> Thanks
> SB
>Hey guys,
>Thanks
>SB
Steven -
The Serial Backpack (per se) can be found below, and is a product of Scott
Edwards Electronics:
http://www.seetron.com/slcds.htm
There is a single IC that can be used in a similar manner from Elab Inc:
http://www.elabinc.com/
and punch up the EDExx Series of ICs. The EDE700 or EDE702 are the ICs you
want to look at.
Bruce Bates
>To UNSUBSCRIBE, just send mail to:
>from the same email address that you subscribed. Text in the Subject and
>Body of the message will be ignored.
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
the ones to have.
> want to look at.
http://www.crystalfontz.com/products/index-ser.html
Rick
Original Message
To: "Basic Stamp List" <basicstamps@yahoogroups.com>
Sent: Tuesday, September 09, 2003 2:43 PM
Subject: Re: [noparse][[/noparse]basicstamps] "BACKPACK" LCD thingy
> And avoid the Wirz / MPJA ones like the plague. The Seetron units are
> the ones to have.
an
then
Scott
you
> > want to look at.
that work well. I have several of them in use.
They are under this link
http://www.kronosrobotics.com/cat_display.asp?txtsearchParamTxt=&txtsear
chParamType=ALL&txtsearchParamCat=13&txtsearchParamMan=ALL&txtsearchPara
mVen=ALL
Original Message
From: Brady,Steven [noparse]/noparse]PYR] [noparse][[/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=qRsIR8xUCj_t11JeiOQYiMLrir0RQlk2l9PwQsyY0-NQ6lRCYdnOIUZDlQFptNCG5IpukouTzYUqYCS_]steven.brady2@e...[/url
Sent: Tuesday, September 09, 2003 2:03 PM
To: 'basicstamps@yahoogroups.com'
Subject: [noparse][[/noparse]basicstamps] "BACKPACK" LCD thingy
Hey guys,
an
then
SB
and Body of the message will be ignored.
> Hey guys,
about an
you'd then
> Thanks
> SB
Although it is not on a PCB as with the Scott Edwards Backpack, I
recently finished the design of a $12.50 kit that provides the serial
LCD function. The LCD geometry may be set for 2X16, 2X20, 2X24, 2X40,
4X16 or 4X20 LCDs. The geometry, user defined characters, tab size
and cursor style are stored in EEPROM.
In addition, it provides two DS1820 runs where up to 16 DS18S20 or
DS18B20 may be accommodated on each run.
It also provides two 10-bit A/D converters, a counter and two TTL
outputs.
This is at http://www.phanderson.com/lcd105.html
I also have a similar assembled unit with a 2X16 LCD and a relay at
http://www.phanderson.com/lcd110/lcd110.html
Best wishes.
Peter H Anderson, http://www.phanderson.com/stamp/
Original Message
From: pha555 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=Eu7SL0w5GsxbNDpG9SYLhcGve8kryPqjef-q03o-GSsUFsgZawWXUnakEELr70R7egEW-oBzcHsrBg]pha@p...[/url
Sent: September 10, 2003 8:58 AM
To: basicstamps@yahoogroups.com
Subject: [noparse][[/noparse]basicstamps] Re: "BACKPACK" LCD thingy
> Hey guys,
about an
you'd then
> Thanks
> SB
Although it is not on a PCB as with the Scott Edwards Backpack, I recently
finished the design of a $12.50 kit that provides the serial LCD function.
The LCD geometry may be set for 2X16, 2X20, 2X24, 2X40, 4X16 or 4X20 LCDs.
The geometry, user defined characters, tab size and cursor style are stored
in EEPROM.
In addition, it provides two DS1820 runs where up to 16 DS18S20 or DS18B20
It also provides two 10-bit A/D converters, a counter and two TTL outputs.
Best wishes.
a MAX232 in a 16-pin DIP with associated capacitors and about eight
resistors.
> Looks kinda promising....no pictures? (other than the green display one)
Original Message
> From: pha555 [noparse][[/noparse]mailto[noparse]:p[/noparse]ha@p...]
