Printing Aplication
Do you know, any aplication to make a print into the litle printer, because
i would like to make the printer with the PARALLAX System
I any need to print a small report into the thermal printer (I don't know
the cheaper and small printer) about the operation.., but i don't know the
system Printer to put with the parallax...
I appreciate, if you can help me about this...
Best Regards
Eng. Damian Trujillo G.
Venezuela, Caracas
Best Regards
Venezuela, Caracas
It is often possible to find small inexpensive thermal printers on
E-bay and other surplus equipment sites. You will probably want to get
one with a serial interface and use serout from the Stamp.
The printers will just take ASCII characters and print them out. You
will need to check the manual to see how it deals with special
characters. Hope this helps.
--- In basicstamps@yahoogroups.com, "dtrujillo_riese@c..."
because
know
know the
> Best Regards
> Venezuela, Caracas
Thank you by your support.... let me to sk a new question to you
Is posible to use the serial pin 1,2,3 of the BASIC STAMP (Pin to
programming this BASIC STAMP) and use the command DEBUG to put the
information into the Printer Thermal SERIAL Printer... If it posible because
i use the all pins in my BS2P24.......
I appreciate if you can help me about this
Best regards
Atentamente.
Ing. Damian Trujillo G.
RIESE & CIA, S.A.
Caracas - Venezuela
) +58-212-7934266/4377
7 +58-212-7940791/0908
+ dtrujillo_riese@c...
Original Message
Date: Jueves 04 de Septiembre de 2003 01:41:11 PM
To: basicstamps@yahoogroups.com
Subject: [noparse][[/noparse]basicstamps] Re: Printing Aplication
Damian,
because
know
know the
> Best Regards
> Venezuela, Caracas
To UNSUBSCRIBE, just send mail to:
basicstamps-unsubscribe@yahoogroups.com
from the same email address that you subscribed. Text in the Subject and
Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
programming port at 9600 baud.
-- Jon Williams
-- Applications Engineer, Parallax
-- Dallas Office
Original Message
From: Ing. Damian Armando Trujillo G [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=VZDQMi1wJPYmidf-fbN6oE8BXRjE7Y8YeewBWu3MU0-UQy6cjPP7vvuPTFE4WytVTnosSi5Djl-yqUlkQNb7MoI7]dtrujillo_riese@c...[/url
Sent: Thursday, September 04, 2003 1:31 PM
Subject: Re: [noparse][[/noparse]basicstamps] Re: Printing Aplication
Dear my friend,
because i use the all pins in my BS2P24.......
Best regards
Atentamente.
RIESE & CIA, S.A.
Caracas - Venezuela
Original Message
Damian,
because
know
know the
> Best Regards
> Venezuela, Caracas
and Body of the message will be ignored.
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
If posible to use this command DEBUG with serial printer thermal without
modification... Do you know if the serial printer use 9600 Baud
I appreciate your help and prompt response
Best Regards
Atentamente.
RIESE & CIA, S.A.
Caracas - Venezuela
Original Message
Date: Jueves 04 de Septiembre de 2003 03:03:10 PM
Subject: RE: [noparse][[/noparse]basicstamps] Re: Printing Aplication
If you do a DEBUG on pin 16 then the data will be transmitted on the
-- Jon Williams
-- Dallas Office
Original Message
From: Ing. Damian Armando Trujillo G [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=eVLGYg6Yf5KugV6JSLymbdfNA-W4vsf-LqNEK4SlchFSHfAmWzGwp4L0KIKqa7GOuQ-xwgYl7uzz834-uhvBp0s]dtrujillo_riese@c...[/url
Dear my friend,
Best regards
Atentamente.
RIESE & CIA, S.A.
Caracas - Venezuela
Original Message
Damian,
because
know
know the
> Best Regards
> Venezuela, Caracas
abuse@p....
-- Jon Williams
-- Dallas Office
Original Message
From: Ing. Damian Armando Trujillo G [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=Iu_SIBBonhEvWmY1Qg8Yw6znTYVE1K6CdRHCiw_vkcAGDT9fGKdjy_g-WLHSOK2L8D7ks9Q4xfP6lvlfbA_JuQR1]dtrujillo_riese@c...[/url
Sent: Thursday, September 04, 2003 2:25 PM
Dera Jon Willians
Best Regards
Atentamente.
RIESE & CIA, S.A.
Caracas - Venezuela
Original Message
-- Jon Williams
-- Dallas Office
Original Message
Dear my friend,
Best regards
Atentamente.
RIESE & CIA, S.A.
Caracas - Venezuela
Original Message
Damian,
because
know
know the
> Best Regards
> Venezuela, Caracas
abuse@p....
abuse@p....
port, not just 9600, by using the SEROUT 16,baudmode,... commmand.
The baudmodes are the same as all the other Stamp pins, except that
the p16 is always inverted (rests at a low level, goes high for
data.) DEBUG is a special 9600 baud only form of SEROUT.
-- Tracy
>-- Jon Williams
>-- Dallas Office
Original Message
>From: Ing. Damian Armando Trujillo G [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=Y-x2LCjUr-j0vnIQ8w5rjd7DqFeh4Ptz52uwJ6luPlWrh36oqhYnt8vRI0csgPj32LnR7lAwrZ4ypW5YBOmn25VVF_E]dtrujillo_riese@c...[/url
>Dear my friend,
>Best regards
>Atentamente.
>RIESE & CIA, S.A.
>Caracas - Venezuela
Original Message
a simple answer. Here's one:
InvertMode CON $4000
' You need invert mode if using 232 driver.
' Pin 2 and 3 HAVE a 232 driver on them.
9600Baud CON 84 ' See BS2 Manual 2.0c, pg 277 for codes.
I9600 CON 9600Baud + InvertMode
SerPin CON 16 ' ACTUALLY, is module pin 2 and 3
' 2 for output, 3 for input (?or other way around?)
' you MUST connect both, because the output
' uses the +12 on the input for its 232 drive.
' For each message to be sent to the printer:
SEROUT 16, I9600, [noparse][[/noparse]"Print this for me",10,13]
' ,10,13 are LineFeed and Carriage Return.
Serial printers USUALLY use something like
1200, 2400, or 9600. Sometimes 300 -- you'll
have to test it. You may have to put
'PAUSE' statements between output statements,
so you don't over-run the printer buffer --
it usually prints much slower than you can
send it data, even with a BS2.
--- In basicstamps@yahoogroups.com, "Ing. Damian Armando Trujillo G"
> Dera Jon Willians
without
> Best Regards
> Atentamente.
> RIESE & CIA, S.A.
> Caracas - Venezuela
Original Message
> From: basicstamps@yahoogroups.com
> -- Jon Williams
> -- Dallas Office
Original Message
> From: Ing. Damian Armando Trujillo G [noparse][[/noparse]mailto:dtrujillo_riese@c...]
> Dear my friend,
> Best regards
> Atentamente.
> RIESE & CIA, S.A.
> Caracas - Venezuela
Original Message
> Damian,
get
printer,
> because
don't
> know
> know the
> > Best Regards
> > Venezuela, Caracas
Subject and
> abuse@p...
Subject and
